Impressions of Tidal
245678
  • BlueFox
    BlueFox Posts: 15,251
    Someday I will have to try out streaming, but not yet. Between ripped CDs, and high res downloads I have more music than I need for many nonstop music sessions. Plus, the songs are at least 44/16, and downloads even better.
  • Had plenty of time with a free stab at Tidal and it was ok. With the massive library I have put together .. I now have what I like to call Tophattidal and it sounds a lot nicer to my ears. Setting up a list and hitting shuffle ..well that's tough....ahh not. Guess Tidal will have its place for some. Not here.
    audioluvr Posts: 5,908
    Just subscribed to Tidal when on vacation last month and loved their mobile app. Last night I remembered I had an account so I downloaded the desktop app and messed with it till midnight. Love the ease of navigation. Mainly used the "Similar Artists" feature to create an eclectic array of playlists in a very short time. This morning I was looking at all my CD's and thought WTF am I going to do with these things now???.
    There are 4 levels of quality with membership. Normal, High, HiFi and Master. I have it on High currently.
    What is everyone here using to connect their computer to their stereo? I'm currently using this:
    https://www.ebay.com/itm/Mini-Jack-3-5mm-to-Dual-RCA-Audiophile-Audio-Cable-PC-AUX-Amplifier-Headphone/173395128134?var=472104461700
    My computer has a very good quality sound card and it sounds really good this way but if anyone has any suggestions for a newbee let me know.
    Rob
  • rooftop59
    rooftop59 Posts: 8,121
    edited February 2019
    @audioluvr
    A PC is not the best source because of the noise. A used squeezebox touch is much better. If you’re going to use the pc, then as joe says run USB to an asynchronous usb dac. Tons of options. For a good entry level option try a iFi iDSD nano off eBay.
    Game Room 5.1.4:
    Bedroom 2.1
  • Joey_V
    Joey_V Posts: 8,600
    audioluvr wrote: »
    Rob
    I am using a bluesound node 2.
  • joecoulson
    joecoulson Posts: 4,943
    Joey. You gotta get a CXN. Your ears will thank you for streaming Tidal.
    rooftop59 wrote: »
    Noise?
    Thanks! I'll look into it.
    Joey_V wrote: »
    Cool! Thanks Joey. I'll check out one of those too!
    Also I noticed the blue node is bluetooth compatible. That would be good for my laptop because it has bluetooth. No cables! Does that feature degrade quality over the iFi iDSD Nano and a cable?
  • rooftop59
    audioluvr wrote: »
    rooftop59 wrote: »
    Noise?
    Joey_V wrote: »
    The noise floor is much higher on a pc. You won’t notice the difference until you try something better. Like I said, check out the squeezebox touch on eBay for a cheaper solution...
    Game Room 5.1.4:
    Bedroom 2.1
    Clipdat Posts: 13,095
    Joey_V wrote: »
    In my opinion you owe it to yourself and the rest of your system to upgrade to a better streamer. The measurements on the Bluesound are mediocre:
    "Bluesound specs the unit at 0.005% and measurements are actually better in both channels. Resulting SINAD though (signal over noise and distortion) is not great at just 88 dB. This is well short of the dynamic range of the CD so the statement that the unit supports high-resolution, 24-bit playback is moot. The SINAD lands in out lowest quarter as far as DACs/streamers tested"
    https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-bluesound-node-2i-streamer.6631/
  • Joey_V
    Joey_V Posts: 8,600
    Clipdat wrote: »
    Joey_V wrote: »
    For the price I think it is adequate
    Not my reference playback for digital anyway
    What would you recommend for similar cost?
  • steveinaz
    steveinaz Posts: 19,545
    (Reference the Bluesoud Node 2i review mentioned above)
    When the author of that test later tested the coax output, it measured far better; for those using the 2i as a transport only. He mentions that it's not capable of "true" 24 bit resolution....Newsflash: NO DAC on planet Earth resolves at the 24 bit level, at any cost. He later conceded that "it will measure as well as the DAC it is connected to." He also mentions that the 2i doesn't have the dynamic range of a CD...another newsflash: CD's don't have the dynamic range of the CD (redbook) standard in the real world.
    I haven't bought a streamer yet, so I have no skin in the game--but I thought this review had some holes in it and lacked supporting info on how some the measurements were done. I also was surprised at some of his commentary (see above) that seems to be pretty common knowledge in the audiophile world.
    I don't pretend to be smarter than the reviewer, but I ask you to read the review link and let me know what you think.
  • Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
  • rooftop59
    wow. you can get a Lumin M1 for less on the same site. Yes, must be a mistake surely...
    Game Room 5.1.4:
    Bedroom 2.1
  • Joey_V
    Joey_V Posts: 8,600
    steveinaz wrote: »
    If that’s the case, then what’s the harm of connecting the Node 2 via coax into my DAC?
  • steveinaz
    Exactly.
  • Tramsparent_
    Tramsparent_ Posts: 14
    I often hear about the noise floor of a PC (makes some sense) and it not being a good environment for a soundcard, etc; but honestly, I'm not hearing ANY noise.
    I'm using an ASUS STX-ii Soundcard (modified with Burson Op Amps) with an i3 processor and good power supply.
    I've tried digital output into a CHORD MOJO DAC and haven't heard ANY difference from the RCA outputs on the ASUS, into my Integrated.
    Maybe a more expensive DAC would provide a difference but I've always thought the MOJO was half-decent and the modified STX-ii outstanding.
    My 2 cents...
  • Mikey081057
    Mikey081057 Posts: 7,127
    I use an HP Slice with an SSD. Only problem I have with it is knowing if it is on or not.
    Garage | Polk Monitor 5B's
  • DSkip wrote: »
    You aren't going to hear NOISE as an audible artifact. It's going to show itself in the smearing of your soundstage and a loss in dimensionality. A streamer is nothing more than a digital transport. It's impact on the sound may not be as critical as the DAC but it still plays an important role. This is why, even when people used them as transports only, the Aries Mini still won.
    There is a reason you see high end streaming transports with no dacs. It isn't to take advantage of people but to actually elevate performance. Noise travels through a system and anything at the transport level will carry on through your system.
    Thanks for the additional information.
    I'm certainly not suggesting a Soundcard (mods or not) is a better way to go than a good DAC system. But as far as smearing and a loss of dimenionality, I don't feel I am losing to either of those, at all, and I'm super-happy with what I have (the main thing).
    I DO however hear an understandable difference between FLAC and streaming with the latter reminding me of listening to FM- compressed and boring; convenient though.
    Tidal is the best one I've heard (so far).
    As for mechanical system noise, I have none. Celeron (fanless) on one of my Servers with SSDs.
    The i3 system is super quiet as well with no fan noise.
    I'm not sure how much I'd have to spend on a good DAC to hear any difference between it and my current Soundcard with a high-quality source.
    Cheers
  • Tramsparent_
    DSkip wrote: »
    Thanks for the additional information, I appreciate your time.
    I'm not suggesting a Soundcard (modified or not) is a better way to go than a good DAC. However, I do not feel I'm losing to a compromised soundstage or a loss of dimensionality (at all). But I've been surprised in this hobby before!
    The SQ keeps increasing with better source materials and I'm more than satisfied with my current sound: (what really matters).
    Perhaps I haven't maxed-out my system yet; and the question now might be how much would I have to spend on a good DAC to begin to hear any differences over what I have now.
    Tidal is the best I've heard so far with others sounding rather boring (reminds me of FM); but the streamers are convenient which seems to be winning in the marketplace.
    PS- NO mechanical noises from my system that uses a fan-less processor and SSDs.
    Post edited by Tramsparent_ on
  • DSkip wrote: »
    I'm not suggesting a Soundcard (modified or not) is a better way to go than a good DAC. However, I do not feel I'm losing to a collapsed soundstage or a loss in dimensionality (at all). But, I've been surprised in this hobby before!
    The SQ keeps improving with well recorded source materials and I'm more than satisfied with my current sound; (what really matters).
    Perhaps I haven't maxed-out my system yet; and the question now might be how much would I have to spend on a good DAC to begin to hear any differences over what I have now. (?)
    Tidal is the best I've heard so far with others sounding rather boring (reminds me of FM); but the Streamers are convenient and that seems to be winning in the marketplace.
  • K_M
    K_M Posts: 1,632
    Ive tried Spotify and Tidal and thought they both sounded better than the actual CD....at times.
    ....Other times, not sure, and also at times, maybe a very slight softening of the sound, but never did a truly in depth comparison.
    I guess overall, easily good enough to not leave any bad impressions.
  • Tramsparent_
    I'm not suggesting a Soundcard (modified or not) is a better way to go than a good DAC. However, I do not feel I'm losing to a collapsed soundstage nor a loss in dimensionality, But, I've been surprised in this hobby before.
  • K_M
    K_M Posts: 1,632
    My 2 cents...
    There are so many variables to doing this, no simple one answer will apply.
    We have a few computers, and even between those, one older one sounds better, but no idea why.
    If anything it has more noise, and a lesser DAC, but still is more listenable.
  • rooftop59
    @Dskip said that this isn't a debate about DACs, its about the streaming source. I went from an albeit cheap intel celeron computer outputting through USB to an asynchronous DAC to a bryston BDP-1 streamer (no DAC) though the same external DAC and the difference clear and immediate: a MUCH blacker background (which is the result of a lower noise floor), better separation of instruments, and just better detail. You can enjoy either one, but a good dedicated streamer does make a difference, even into the same DAC.
    Grab a squeezebox touch on ebay and give it a try. Won't cost you much as you can resell it for about what you paid if you don't hear a difference...
    Game Room 5.1.4:
    Bedroom 2.1
  • Mikey081057
    One thing for sure, and not that I want to see it, is that physical media and devices are diminishing as a product group. Improvements in SQ in streaming are happening. Will it out perform physical media someday? Maybe? Maybe not... and how much will we be willing to pay for it? Who knows...
  • steveinaz
    I have actually preferred hard drive derived music more than a CD transport-->DAC solution for about 7yrs now. I realize this is subjective to each listener, but to me it was even more analog/natural sounding. I used a C.E.C. CD-3300 into a Benchmark DAC via digital AES/EBU cable just before transitioning to HDD-->transport-->DAC setup.
  • Joey_V
    Joey_V Posts: 8,600
    DSkip wrote: »
    The differences I notice are more dynamics and little more ease to the music. It’s very slight but enough to recognize. I simply don’t spin cds anymore though.
    Maybe the bluesound is the limiter
    But in my room, the emm transport beats out the bluesound through tidal both going into emm dac.
    Enough of a difference that through an iPhone video it can be discerned which is which
    ZLTFUL wrote: »
    I have a really nice laptop with no cooling fans (an "Ultrabook" if you will) and SSDs
    Trying to not sound like an idiot here but what is an SSD? AND WTF is the deal with all the quadruple posts of the exact same thing???
    tonyb Posts: 33,072
    Less noise floor also.
