Someday I will have to try out streaming, but not yet. Between ripped CDs, and high res downloads I have more music than I need for many nonstop music sessions. Plus, the songs are at least 44/16, and downloads even better.
Lumin X1 file player
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Magico S5 MKII Mcast Rose speakers, SPOD spikes
Had plenty of time with a free stab at Tidal and it was ok. With the massive library I have put together .. I now have what I like to call Tophattidal and it sounds a lot nicer to my ears. Setting up a list and hitting shuffle ..well that's tough....ahh not. Guess Tidal will have its place for some. Not here.
Just subscribed to Tidal when on vacation last month and loved their mobile app. Last night I remembered I had an account so I downloaded the desktop app and messed with it till midnight. Love the ease of navigation. Mainly used the "Similar Artists" feature to create an eclectic array of playlists in a very short time. This morning I was looking at all my CD's and thought WTF am I going to do with these things now???.
There are 4 levels of quality with membership. Normal, High, HiFi and Master. I have it on High currently.
What is everyone here using to connect their computer to their stereo? I'm currently using this:
My computer has a very good quality sound card and it sounds really good this way but if anyone has any suggestions for a newbee let me know.
Rob
Cambridge Audio 851N Streamer/DAC
Belles 350A Reference modded with Mundorf Supreme caps
Polk SDA 1C's modded
A PC is not the best source because of the noise. A used squeezebox touch is much better. If you’re going to use the pc, then as joe says run USB to an asynchronous usb dac. Tons of options. For a good entry level option try a iFi iDSD nano off eBay.
Living Room 2.1: Dynaudio Contour 1.3mkii; Martin Logan Grotto sub; Musical Fidelity A308; Marantz SA 14S1; Sony UBP-x1000es Game Room HT: Denon AVR-X4200w; Sony UBP-x700; Definitive Technology SM450; Definitive Technology LCR2000; Definitive Technology StudioMonitor350; Mirage Nanasats; Sub - HSU VTF-2 MK5 Master Bedroom
Cambridge Azur 551r; Definitive Technology promonitor 800; ACI Titan Subwoofer
Cool! Thanks Joey. I'll check out one of those too!
Also I noticed the blue node is bluetooth compatible. That would be good for my laptop because it has bluetooth. No cables! Does that feature degrade quality over the iFi iDSD Nano and a cable?
The noise floor is much higher on a pc. You won’t notice the difference until you try something better. Like I said, check out the squeezebox touch on eBay for a cheaper solution...
In my opinion you owe it to yourself and the rest of your system to upgrade to a better streamer. The measurements on the Bluesound are mediocre:
"Bluesound specs the unit at 0.005% and measurements are actually better in both channels. Resulting SINAD though (signal over noise and distortion) is not great at just 88 dB. This is well short of the dynamic range of the CD so the statement that the unit supports high-resolution, 24-bit playback is moot. The SINAD lands in out lowest quarter as far as DACs/streamers tested"
(Reference the Bluesoud Node 2i review mentioned above)
When the author of that test later tested the coax output, it measured far better; for those using the 2i as a transport only. He mentions that it's not capable of "true" 24 bit resolution....Newsflash: NO DAC on planet Earth resolves at the 24 bit level, at any cost. He later conceded that "it will measure as well as the DAC it is connected to." He also mentions that the 2i doesn't have the dynamic range of a CD...another newsflash: CD's don't have the dynamic range of the CD (redbook) standard in the real world.
I haven't bought a streamer yet, so I have no skin in the game--but I thought this review had some holes in it and lacked supporting info on how some the measurements were done. I also was surprised at some of his commentary (see above) that seems to be pretty common knowledge in the audiophile world.
I don't pretend to be smarter than the reviewer, but I ask you to read the review link and let me know what you think.
If that’s the case, then what’s the harm of connecting the Node 2 via coax into my DAC?
I often hear about the noise floor of a PC (makes some sense) and it not being a good environment for a soundcard, etc; but honestly, I'm not hearing ANY noise.
I'm using an ASUS STX-ii Soundcard (modified with Burson Op Amps) with an i3 processor and good power supply.
I've tried digital output into a CHORD MOJO DAC and haven't heard ANY difference from the RCA outputs on the ASUS, into my Integrated.
Maybe a more expensive DAC would provide a difference but I've always thought the MOJO was half-decent and the modified STX-ii outstanding.
The problems with using a computer for a transport usually stems from moving parts...things like fans, spinning discs...they create noise.
This can be lowered substantially with solid state drives and fanless computer systems.
But then you have to factor in power supplies. Consumer computer power supplies typically are not designed with quietness in mind. They have noisy pathways that always manages to find a way into the signal.
Ideally, if you are set on using a computer as a streaming transport, you can get significant noise reduction by using a laptop with no fans and a SSD. Running on battery, you remove the power supply noise from the equation.
*But*, I have a really nice laptop with no cooling fans (an "Ultrabook" if you will) and SSDs and it still doesn't come close to sounding as good as my Nativ Vita streaming transport. And the Vita is essentially an ARM Cortex based computer but without all the "things" that cause noise in a regular computer system.
This is why things like the HiFi Berry are so popular as a streaming device for audiophiles.
You aren't going to hear NOISE as an audible artifact. It's going to show itself in the smearing of your soundstage and a loss in dimensionality. A streamer is nothing more than a digital transport. It's impact on the sound may not be as critical as the DAC but it still plays an important role. This is why, even when people used them as transports only, the Aries Mini still won.
There is a reason you see high end streaming transports with no dacs. It isn't to take advantage of people but to actually elevate performance. Noise travels through a system and anything at the transport level will carry on through your system.
Thanks for the additional information.
I'm certainly not suggesting a Soundcard (mods or not) is a better way to go than a good DAC system. But as far as smearing and a loss of dimenionality, I don't feel I am losing to either of those, at all, and I'm super-happy with what I have (the main thing).
I DO however hear an understandable difference between FLAC and streaming with the latter reminding me of listening to FM- compressed and boring; convenient though.
Tidal is the best one I've heard (so far).
As for mechanical system noise, I have none. Celeron (fanless) on one of my Servers with SSDs.
The i3 system is super quiet as well with no fan noise.
I'm not sure how much I'd have to spend on a good DAC to hear any difference between it and my current Soundcard with a high-quality source.
Thanks for the additional information, I appreciate your time.
I'm not suggesting a Soundcard (modified or not) is a better way to go than a good DAC. However, I do not feel I'm losing to a compromised soundstage or a loss of dimensionality (at all). But I've been surprised in this hobby before!
The SQ keeps increasing with better source materials and I'm more than satisfied with my current sound: (what really matters).
Perhaps I haven't maxed-out my system yet; and the question now might be how much would I have to spend on a good DAC to begin to hear any differences over what I have now.
Tidal is the best I've heard so far with others sounding rather boring (reminds me of FM); but the streamers are convenient which seems to be winning in the marketplace.
PS- NO mechanical noises from my system that uses a fan-less processor and SSDs.
I'm not suggesting a Soundcard (modified or not) is a better way to go than a good DAC. However, I do not feel I'm losing to a collapsed soundstage or a loss in dimensionality (at all). But, I've been surprised in this hobby before!
The SQ keeps improving with well recorded source materials and I'm more than satisfied with my current sound; (what really matters).
Perhaps I haven't maxed-out my system yet; and the question now might be how much would I have to spend on a good DAC to begin to hear any differences over what I have now. (?)
Tidal is the best I've heard so far with others sounding rather boring (reminds me of FM); but the Streamers are convenient and that seems to be winning in the marketplace.
Ive tried Spotify and Tidal and thought they both sounded better than the actual CD....at times.
....Other times, not sure, and also at times, maybe a very slight softening of the sound, but never did a truly in depth comparison.
I guess overall, easily good enough to not leave any bad impressions.
I'm not suggesting a Soundcard (modified or not) is a better way to go than a good DAC. However, I do not feel I'm losing to a collapsed soundstage nor a loss in dimensionality, But, I've been surprised in this hobby before.
My 2 cents...
There are so many variables to doing this, no simple one answer will apply.
We have a few computers, and even between those, one older one sounds better, but no idea why.
If anything it has more noise, and a lesser DAC, but still is more listenable.
@Dskip said that this isn't a debate about DACs, its about the streaming source. I went from an albeit cheap intel celeron computer outputting through USB to an asynchronous DAC to a bryston BDP-1 streamer (no DAC) though the same external DAC and the difference clear and immediate: a MUCH blacker background (which is the result of a lower noise floor), better separation of instruments, and just better detail. You can enjoy either one, but a good dedicated streamer does make a difference, even into the same DAC.
Grab a squeezebox touch on ebay and give it a try. Won't cost you much as you can resell it for about what you paid if you don't hear a difference...
One thing for sure, and not that I want to see it, is that physical media and devices are diminishing as a product group. Improvements in SQ in streaming are happening. Will it out perform physical media someday? Maybe? Maybe not... and how much will we be willing to pay for it? Who knows...
My New Year's resolution is 3840 × 2160
ManCave:HT:Polk LSiM 706VR3 LSiM 703's LSiM 702's|| Marantz AV7002 AV PrePro Sunfire TGA-7401| Sony PS4 Pro| Sony PS4 Pro|SVS PB13 Ultra| Oppo UDP 203 | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Samsung 55" SUHD TV | Sony PS4
Garage | Polk Monitor 5B's
I have actually preferred hard drive derived music more than a CD transport-->DAC solution for about 7yrs now. I realize this is subjective to each listener, but to me it was even more analog/natural sounding. I used a C.E.C. CD-3300 into a Benchmark DAC via digital AES/EBU cable just before transitioning to HDD-->transport-->DAC setup.
"shrewd
Dictionary result for shrewd
/SHro͞od/
adjective
adjective: shrewd; comparative adjective: shrewder; superlative adjective: shrewdest
1.having or showing sharp powers of judgment; astute."
Yes, I agree. Plus, my name is inside it!
Sony XA-5400ES SACD
https://www.ebay.com/itm/Mini-Jack-3-5mm-to-Dual-RCA-Audiophile-Audio-Cable-PC-AUX-Amplifier-Headphone/173395128134?var=472104461700
Rob
Master Bedroom
I am using a bluesound node 2.
Current Gear:
Primary:
Digital: Torus RM15 -> Emm Labs TSDx/Bluesound Node 2 -> Emm Labs DAC2x
Analog: VPI Avenger Reference w/ Rim Drive w/ ADS + 12" Fatboy Dual Pivot + Lyra Etna
+ Audio Research Reference 40th Anniversary -> Boulder 2060 stereo amp (w/ Audioquest WEL Signature) -> new speakers + JL Audio F113v2 x2
Secondary:
Rotel RA1592 Super Integrated -> Sonus Faber Olympica 3
Tertiary:
Oppo 105D -> Rotel RC1570 preamp -> Rotel RB1582 amp -> Focal Kanta 2
Main speakers system evolution over the years:
Klipsch Promedia 4.1 -> Axiom M22ti -> Sonus Faber Concertino -> Sonus Faber Concerto -> Polk LSi7 -> Polk LSi9 -> Martin Logan Mosaic -> AV123 Onix Ref 1 -> Martin Logan Vantage -> AV123 Strata Mini -> Martin Logan Summit -> Sonus Faber Cremona Auditor -> BW 802D2 -> Sonus Faber Stradivari -> Rockport Avior -> BW 802D3 -> BW 800D3 -> ???
Old Gear:
Speakers:
BW PM1 (3.5/5), CM10s2 (3.75/5), BW800D3 (5/5), Rockport Aviors (5/5), Sonus Faber Stradivari (5/5), BW 802D2 (4.5/5), Martin Logan Summits (4.25/5), Martin Logan Vantage (4/5), Sonus Faber Cremona Auditor (3.75/5), AV123 Strata Mini (3.5/5), ML Mosaic (3.25/5), Onix Ref1 (3/5), Sonus Faber Concerto (2.75/5), SF Concertino (2.5/5), Axiom M22ti (2/5), Polk LSi9 (3/5), LSi7 (2.9/5)
Source:
Squeezebox 3 -> PS Audio Digital Link III -> Cary 306/200 CDP -> Cary 306 SACD -> EMM LABS DAC2X/TSDX
Preamplification:
Rotel RC1070 -> Rogue Perseus -> Cary SLP98 -> Cary SLP98F1 -> Cary SLP05 (sold and then repurchased) -> ARC 5se -> ARC Ref 40th Anniversary
Amplification:
HK AVR330 -> Rotel RB1070 -> Rotel RB1090 -> Plinius SA102 -> Cary 211FE -> Classe M600 -> Boulder 2060
Subwoofer:
Infinity Entra2 -> SVS 25-31PCi -> SVS 25-31PC+ -> Dual JL Audio F113v2
Thanks! I'll look into it.
Master Bedroom
https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-bluesound-node-2i-streamer.6631/
For the price I think it is adequate
Not my reference playback for digital anyway
What would you recommend for similar cost?
Current Gear:
Primary:
Secondary:
Tertiary:
Old Gear:
Speakers:
Source:
Preamplification:
Amplification:
Subwoofer:
Look at this for a Demo Mini. $2,199 must be a mistake.
https://sightandsoundgallery.com/products/auralic-aries-mini-wireless-streaming-transporter-demo?variant=18483307020386&utm_source=google&utm_medium=cpc&adpos=1o2&scid=scplpshopify_US_1950828167266_18483307020386&sc_intid=shopify_US_1950828167266_18483307020386&gclid=EAIaIQobChMI2Kfv8ubF4AIVLCCtBh0-XQxWEAQYAiABEgL-dPD_BwE
Musical Fidelity M6si, Yamaha Aventage RX-A 1060, Yamaha BD-S681, Cambridge Audio Azur 851N, Polk S60, Polk S30, Samsung 60" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables
wow. you can get a Lumin M1 for less on the same site. Yes, must be a mistake surely...
Master Bedroom
Current Gear:
Primary:
Secondary:
Tertiary:
Old Gear:
Speakers:
Source:
Preamplification:
Amplification:
Subwoofer:
My 2 cents...
Cheers
B+W-Sold
Electro Voice EV-SIX
Infinity-Sold
Advent-Now gone
Yamaha A-S801
Yamaha RX-V377
Yamaha RX-A860
Yamaha RX-A3060
Harman Kardon Hk-350i
Harman Kardon Hk-........
Harman Kardon PM-665
Harman Kardon HK-775
Pioneer.......Stereo Receiver
B+W-Sold
Infinity-Sold
Advent-Now gone
Yamaha A-S801
Yamaha RX-V377
Yamaha RX-A860
Yamaha RX-A3060
Master Bedroom
