mhardy6647 wrote: »Then I will definitely have to invest in some stands.
Amusingly enough, I was just broaching that concept (the stands, that is) to Mrs. H.
Well, you did mention the Carver Crimson 275 integrated to her and, IIRC, she gave you the green light. Since you've not yet made that purchase, I'd say you're good to go on the stands
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
Vanilla is acting glitchy. "Unkownkn column 'Active' in 'field list'
Anyone here speak "Vanilla?"
@KennethSwauger ?HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
@KennethSwauger ?
It's been glitchy ever since the new site went live...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
@KennethSwauger ?
Saw that earlier when trying to edit a post. It'll display that error, but if you navigate away to a new page, and then come back to the thread where you just made your post & edit, you'll see that the edit actually did save successfully, despite the error message.
But at least the Recent Discussions auto refreshes in Firefox now! Yay! -
Thanks Drew!HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Picked up a ModWright PH 9.0 Phono Stage, sounding very good right out of the gate, sporting some cheap stock tubes no less.
Mike Reeter wrote: »Picked up a ModWright PH 9.0 Phono Stage, sounding very good right out of the gate, sporting some cheap stock tubes no less.
Very nice! I used to own a ModWright modified Sony DVP-NS9100ES (Signature Truth Mod). Very solid piece of equipment with great sound. Congrats!!HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Thank you Victor, I have a ModWright LS 100 Line Stage also, one of the deciding factors on going with the Phono Stage. And yes, very solid equipment with great sound.
Got this hospital grade outlet for 4 bucks. Made by Cooper. Built like a tank - I expect better retention of the AC9's while plugged in!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Replacement Marantz CD-1 came today! Warming up (been on the porch all day) before I hook it up!
I just installed 2 Pangea Audio Premier AC Outlets (20 Amp White) I got here: https://www.amazon.com/dp/B01DV0LXKQ?ref_=pe_2640190_261118450_302_E_DDE_
I use them on my Cullen gold power cable and Signal power cable and they work very well, really hold the plugs into the outlet.
Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
Hmmm... I wonder if I have $2500 of saved-up opportunity by passing on that amplifier...
It is a testable hypothesis.
Yep. I had my eye on those as well. The hospital grade outlet retains much better after doing some static testing (not installed yet), hope to install it this weekend!
static testing...
LOL! Not that type of static testing, dear sir!
oh
Here I thought this was a fun hobby...
Well if the ones I got start losing their hold, I'll look for those.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
What did I do to my stereo rig today? Somehow managed to break/loosen one of the ceramic tube sockets on my Backert Labs Rhumba 1.2 Extreme.
See that center gold disc/slug that holds the white ceramic portion in place? Well there's now a slight amount of space between it and the ceramic part which allows the ceramic part to rotate slightly CW and CCW and make an unpleasant ceramic on metal sound. When you insert a tube and fully seat it, it doesn't rotate anymore. Functionality seems unaffected, but knowing it's messed up is irritating to me.
I blame this damn Upsale.. er Upscale Audio RCA tubes with excessive corrosion on the pins that I swapped in. Should've stopped when I felt how much resistance there was compared to the last tubes I had in, but NOOOO. Well now I have a loose tube socket to show for it.
I feel like I am too dumb for tube gear at this moment. Sigh. Oh well, life lesson. Good excuse to send the Backert in to get the socket fixed and to get the new version of the feet plus other "upgrades".
Except sending it in will mean I'm preamp-less.
Easily done. Almost did it with the Vincent right out of the box. Sorry Drew.
Just my 2 cents: Put the blame not on the tubes but the sockets. Sorry, but based on the description of what happened (and, based on everything @Clipdat's ever posted, I am sure he didn't go all orang-utan on insertin' tubes into them) -- this is symptomatic of poor quality sockets.
As the "hams" and DIY hifi crowd has known for decades, it is hard to beat NOS sockets. NOS ceramic sockets of high quality for 9 pin tubes are probably pretty pricey now, which is probably why equipment manufacturers are using modern "standard goods".
OMG Drew! Very sorry to hear. My EAR pre has a flimsy interface (PCB is unsupported) to the tube sockets, which concerns me.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
mhardy6647 wrote: »Just my 2 cents: Put the blame not on the tubes but the sockets. Sorry, but based on the description of what happened (and, based on everything @Clipdat's ever posted, I am sure he didn't go all orang-utan on insertin' tubes into them) -- this is symptomatic of poor quality sockets.
Oh no, make no mistake, I "orang-utan'd" the **** out of it. Boneheaded move.
This is why I shouldn't touch any audio gear when I'm tired and exhausted. Wasn't thinking clearly. -
Yikes. That happens. I’m sending my pre in to backert as well for a few upgrades and a look through to see if they can replicate my hiss problem. Might be a gain issue with my amp, we will see. Great cs as always from backertPost edited by stangman67 on2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
I agree, Zach. Andy emailed me back the same day just a few hours after I emailed him, and it was well outside of normal business hours.
And, I purchased the preamp used, not new directly from them. They are a real stand-up company. -
Spent $286 shipping 3 boxes from the west coast to the east coast. Yay egregious FedEx shipping rates.
Where do you live Clipdat?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Where do you live Clipdat?
SF bay area. -
Found these little guys to help with power cable routing (Pangea AC9).
Those are very useful
I have a coupe also.
