VTL 2.5 PreAmp in the House!
1235
  • verb
    verb Posts: 10,176
    GlennDog wrote: »
    The tube power amp/SS preamp is a pretty special combination as well. You should try that one some day as well. :pB):pB)
    I’ve got a SS pre that you can try, assuming you have a tubed amp . . .
    An Adcom GFA-750 w/ a passive setting, blue boards of course
    Folks @GlennDog is good people! One of many members that makes CP such a special place!
    pitdogg2 Posts: 27,334
    GlennDog wrote: »
    Yea that is one that got away from me years back. One of several i wanted to buy.
  • verb
    verb Posts: 10,176
    edited December 2018
    That's a nice looking piece! GFP-750.
    Tony M Posts: 11,732
    I agree with wanting one forever.
    Now that I have 555II's, the want is even greater. Maybe one day...
    Is there another color of board beside this blue?
    Tony M wrote: »
    yes I believe it may of been the parts they used on the board itself not the color of the board per-say .
    https://forum.polkaudio.com/discussion/99974/adcom-gfp-750-blue-boards
    Thanks!
    That link explained a lot for us looking to still purchase one on the used market.
    Go USA. ;)
  • verb
    verb Posts: 10,176
    Yesterday I was at our local electronics repair shop with my VTL, for a quick check, before I ventured into the relay switch replacement. Just wanted a second opinion before surgery, if you know what I mean.
    Well, he checked it out, and the diagnosis was a bad tube! The bias mismatch between the tubes was severe enough for the relays to act erratically. He popped in a set of shop tubes (12AU7's and 12AT7's), and the thing was operating normally!
    Everything was operating to specification, and received a compliment on how sweet this thing sounds!
    For me, some hints this newbie got, in retrospect.
    I noticed a slight hissing sound when the unit was powered on previously. Regardless of volume setting. I read a lot about it here on the forum, and attributed it to being normal. Probably a sign of a tube going bad?
    However today, when I put a full compliment of new tubes in (CBS 12AT7's from @heiney9 and the spare Mullards 12AU7's that came with it) it is now dead quiet.
    So far, so good. Happy camper now, albeit with a little anxiety while the unit is warmed up and playing.
    The learning continues! As always, thanks everyone for your advice and support!
    yep first thing on tube stuff rule out tubes, After all most are older that you ;)
    F1nut Posts: 52,009
    Ha sorry Dave, I should have asked if you tried changing the tubes.
    heiney9 Posts: 25,513
    Any tube gear issues, always, always start with the tubes. The number one thing is to clean the PINS. 95% of my issues (not as drastic as your issue) were solved by removing/replacing and/or cleaning the PINS on the same tube.
  • verb
    verb Posts: 10,176
    Yep. I'm gonna do that tonight. Clean the pins. Thanks!
    Nothing like tube rolling, under duress! :smile:
  • verb
    verb Posts: 10,176
    No worries Jesse! I got a learning going on! :smile:
  • verb
    verb Posts: 10,176
    Hehe! The CBS's are circa 1950! :smile:
    Man, we all fell flat on this one. Tubes should have been the first thing to look at, we just assumed you did.
    For future reference, most older tubed gear is built like a brick crap house, tubes are usually the only thing causing weird noises but that's not to say something else will never go bad either. Always change out tubes first, when trying to figure out whats up. We all knew better but somehow just never mentioned it. I have an excuse though, I'm old...maybe vintage is a better word. :p
    nooshinjohn Posts: 26,002
    Did you check the tubes to make sure they were up to snuff? Generally, the first thing to look at with tube gear would be the tubes.
    Captain obvious :D:D:D
    LOL
  • verb
    verb Posts: 10,176
    No worries @tonyb I attribute this to me being a newbie.
  • verb
    verb Posts: 10,176
    Ah, no. Dear Lord I gotta get a tube tester? Answer - yes. Last time I was in the drug store all the tube testers were gone! :smile:
    To be completely honest, I never heard of a bad tube causing a relay to "click" like you described, so I learned something new here myself.
    All is good so that's what counts. Hang on to the Cary and do a comparison. That puppy is no slouch in it's own right too.
    tonyb wrote: »
    Especially a signal tube. Signal tubes get noisy when they are worn out, rarely will it cause any sort of fuse, relay, protection issue. But there are always exceptions to the general rule.
    F1nut Posts: 52,009
    Brock brings up a valid point.
    Dave, can you put the original tubes back in to see if the issue still exists?
  • verb
    verb Posts: 10,176
    Yep. Will do. Right now just got back from running errands. VTL has been on the whole time. 2 hours at least. So far so good.
  • verb
    verb Posts: 10,176
    Newbie question. I’m assuming new tubes, either brand new or NOS, require some burn in time. Correct?
  • GlennDog
    GlennDog Posts: 3,158
    Dave, can you put the original tubes back AFTER cleaning the pins to see if the issue still exists?
    Fixed is for ya!
    Glad it was a simple fix, Dave
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    verb wrote: »
    Guaranteed brand new yes but tubes could actually have some hours on them and test as new.
  • verb
    verb Posts: 10,176
    Been running the VTL for past 2 weekends, maybe 4 hours total. No issues with the new tubes! VTL is running good! Happy camper here! :smile:
  • verb
    verb Posts: 10,176
    edited January 2019
    So I finally had a chance to compare @GlennDog Cary SLP-98L to my first, and beloved VTL 2.5 tube preamp!
    First and foremost, I'm an engineer, so design of experiments is what I do all day every day. I try to limit the number of variables, and iterate on them to collect data.
    In this test, everything else the same, the only variable was the preamp.
    My Rest Rig:
    EAD T-1000 transport
    Northstar Designs DAC
    Wireworld Oasis 8 IC's
    McIntosh MC300 Power Amp
    All being fed (amp is plugged into the wall socket) by a Furman PFi-15 elite power conditioner. Pangea AC14 SE MK2 power cords used throughout. Stock power cord for the amp.
    Music:
    Juno Reactor - Bible of Dreams
    Pet Shop Boys - Disco 3
    Deadmau5 - 4x4=12
    Tosca - Suzuki
    Another tool I use at work to collate data for easy comparison is called a Pugh matrix:
    Being a newbie to the Audiophile world, I chose certain parameters whose definition I could understand readily, for comparison. I gave an overall rating to each.
    So here the edge goes to the Cary. That was not totally unexpected, considering the prices they go for on the used market. Overall the Cary sounds a bit more tube-like than the VTL. However, the VTL is certainly no slouch. There are plenty of accolades out there from happy customers of both units.
    I am really enjoying the Cary in my rig right now! It is certainly a wonderful sounding and beautiful piece of equipment. Dog you may not get her back for some time! :smile:
    For me, I love the VTL. I'm gonna keep her. Got some tube rolling to do, perhaps dial it in a bit more to approach the Cary, if possible. Now that I know what I'm looking for.
    Just lastly wanted to mention a very special thanks to @GlennDog for his generosity in letting me play with the Cary. He is truly a special person, one whom I just recently met, but consider a cherished friend. Thank you Glenn! :smile:
  • marvda1
    marvda1 Posts: 4,963
    could it be the difference in tubes?
    Puritan PSM156
  • verb
    verb Posts: 10,176
    marvda1 wrote: »
    Yep that's my next iteration. :smile:
    I mean, they were both phenomenal, IMO. Being a tube newbie, I wanted to pick out as much difference as I could, albeit ever so slight.
    Clipdat Posts: 13,100
    edited January 2019
    I can't believe I just saw someone else using Juno Reactor - Bible of Dreams as a test CD. My eyes went like this O.O and I did a double take. This has been one of my favorite albums and a go-to test CD for me for years. Huge Juno Reactor fan, I own almost all of his releases.
    You gotta listen to some of his stuff on vinyl!
