VTL 2.5 PreAmp in the House!
1246
  • verbverb Posts: 10,203
    lightman1 wrote: »
    verb wrote: »
    tonyb wrote: »
    audioluvr wrote: »
    Ok you've had just about enough time to fiddle with your new toy... .
    Eh, maybe not. He's still looking for his left nut under the couch. Scratching his head about why he didn't do this sooner.
    Can’t find my right nut either! :smile:
    Been married for a while, I take it?
    Hehe! In the lockbox! :smile:
    Basement: Polk SDA SRS,Cary SLP-05 Pre,Enlightened Audio Designs CD Transport,Northstar Designs Excelsio DAC,Cambridge 851N streamer,Marantz SA-14 SACD,McIntosh MC300 Amp,Silnote Morpheus Ref2 Digital Cable,Furman 15PFi Power Conditioner,Pangea Power Cables,Wireworld Oasis 8 RCA IC's,MIT Shotgun S3 IC's,MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC,EAR Acute CD Player,EAR 834L Pre,Northstar Designs Intenso DAC,PASS ACA Monoblocks,Denon UDR-F10 Cassette,Acoustic Technologies Classic FR Speakers,SVS SB12 Plus sub,MIT AVt2 speaker cables,IFI Purifier2,AQ Cinnamon USB cable,Groneberg Quatro Reference IC's
    Spare Room: Antique Sound Labs Wave AV-8 Monoblocks,Tisbury Mini Passive Pre,Tjoeb 99 tube CD player (modified Marantz CD-38),Analysis Plus Oval 9's,Zu Jumpers,AudioEngine B1 Streamer,Klipsch RB-61 v2,SVS PB1000 sub,Blue Jeans RCA IC's
    Living Room: Peachtree Nova Integrated,Cambridge CXN v2 Streamer,Rotel RCD-1072 CD player,Furman 15PFi Power Conditioner,Polk RT265 In Wall Speakers,Polk DSW Pro 660wi sub
    tonyb wrote: »
    verb wrote: »
    tonyb wrote: »
    audioluvr wrote: »
    Pffft….what's an Almond Joy without the nut eh ? Throw up a review, maybe a comparison to something else your familiar with. The dogs are getting restless.
    Will do!
    So today, the VTL appears to have schiesse the bed. I turn the unit on, it powers on ok (fuse is good), but no signal to the amp. No sound. Tried multiple sources into the pre (CD, Aux1), nothing. Checked all cables to make sure everything was tight. Nothing. Dang.
    All the tubes light up as normal. Opened the hood, nothing looks out of ordinary. Everything is clean, in fact.
    So then I swapped in my Rotel pre into the main system, everything works as it should. Gotta be the pre.
    Any ideas? Thanks.
  • F1nutF1nut Posts: 44,797
    Bad relay. I believe there are 3 on the rear board. Try tapping on them one at a time.
  • marvda1marvda1 Posts: 4,052
    don't hit me, did you check the mute switch?
    Amplifiers: MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800,Kinki Studio EX-M1
    Transport/Dac: L.K.S MH-DA004, Cayin Venus cd-100i, Musical Paradise mp-d2 mkI,
    Musical Paradise mp-d2 mkIII
    Speaker Cables: Organic Audio Organic Reference 2, Analysis Plus Black Mesh Oval 9,
    Cerious Technologies Graphene Extreme
    Interconnects: Argento Organic Reference 2, Argento Organic 2, Gabriel Gold Reckoning
    Power Cables by: Cullen Cables, 6sons Audio, Swiss Cables
    marvda1 wrote: »
    Yep mute switch is off.
    I did notice an intermittent clicking noise coming from it. Could that be the relay?
    edited December 2018
    Here's a stock pic under the hood:
  • gmcmangmcman Posts: 1,573
    Do you have theater bypass activated?
    gmcman wrote: »
    Nope. Double checked all that.
    Tapped each one of relays. While the unit was on (yes I know). And tapped each one of them a little more aggressively unpowered and removed from the rack. Nada.
    Man, that sux....I never had any issues with it....so does it go through the normal delay start with the blinking light, then does it click or no click after the delay?
    Did you try the second pair of output RCA's?
    gmcman wrote: »
    Hey no worries. Yep normal startup. Flashing light stops, but no discernible click. I do get an intermittent clicking after it’s on though.
    Yep, like I said you've got a bad relay. You might as well replace all 3 as they are not expensive.
    Here you go, https://www.newark.com/omron-electronic-components/g5v-2-h1-dc5/relay-signal-dpdt-24vdc-1a/dp/35K4531
    Thanks Jesse! Now I gotta decide if I'm up to the challenge of replacing em. I've done some rudimentary soldering back in the day, and present, but not sure I have the confidence to mess with such an exqusite (and expensive) piece of gear! :smile:
    Piece of cake. You'll have to remove the selector pot extension collar and the support. Then loosen the board by freeing up all the RCA jacks then flip it up to access the back of it. You will not have to desolder any of the leads going to the board. Use a rag to support the board inside the case, then get to work replacing the relays. You will need a good solder sucker.
  • ZLTFULZLTFUL Posts: 5,412
    Just watch a few soldering/desoldering videos on YouTube.
    Take your time, go slow, and make sure you don't go aggressively too hot or too conservatively cold with your iron when soldering.
    My 12 year old nephew taught himself to solder using YouTube videos and some advice from me and now the kid can solder PC board stuff with the naked eye...my old a$$ has to use a magnifying glass.
    ZLTFUL wrote: »
    So easy even a 12 year old can do it! :smile: I feel ya on the magnifying glasses. Been wearing reading glasses for the past year. :cry:
    Bunch of old farts.
    So today, @GlennDog heard my plight (no tube pre, the world is ending) :smile: and offered up his absolutely beautiful Cary SLP-98 tube pre, as a loaner, while the VTL is going under repairs!
    All I can say is wow! Thanks very much Dog!
    This is one of the reasons (among many) as to why CP is such an awesome place. It's about helping each other out, in times of need.
    And, I get to put some ears on another tube pre! Pic of his baby:
  • stangman67stangman67 Posts: 1,328
    This place is pretty special in that regard! Why I will never move on to another forum regardless of if I have Polk stuff or not
    2 Channel - Dual Purpose system in the works
    Polk LSIM707 I Polk LSIM 706C I Modwright SWL9.0 Anniversary Pre I Marantz AV7707 I B&K Ref 200.7 I Rega P6 w/ Ania MC I Rega Fono MC I Audience Ohno ICs/Audience Forte F3 Power Chord/Acoustic Zen Satori I Cambridge 851N
    All warmed and ready to rock! :smile:
  • GlennDogGlennDog Posts: 2,284
    After the Cary SLP “sweet little pre“ and Reference Audio Labs umbilical cord settle-in, a comparison might be in order, Sir
    RAL is the real deal . . .
    Power Rogue M180 monos & Adcom GFA 5802
    PS Audio PerfectWave Power Plant 10
    Rears Salk SuperCharged Surrounds
    Source PSA PWT into NSD Supremo
    Pre/Pro Integra DHC 40.1
    LCD Samsung LN46B750
    Mains Salk HT2-TL
    Center Salk HT2C
    Pre Cary SLP-05
    Wires WW & MIT
  • ClipdatClipdat Posts: 8,291
    Hmm, Dave you might have a slight issue, I was just reading the operating manual for the Cary and under the "Initial Setup" section, it states that a "spiked rack" is required for optimum fidelity.
    Might want to take care of that before doing any critical listening.
    Yesterday during my troubleshooting process, I swapped in the Rotel Pre, just to make sure everything else was working. Confirmed. Coming from the VTL, everything being equal, all I can say is OMG! The soundstage was smaller, sounded thinner, and the highs were veiled compared to the VTL.
    I'm guessing most of you toobies already knew that! :smile:
    Without ever having run a tube pre, always been a SS guy, I am a true believer in the tube pre/SS power amp setup. I'll never go back!
    The Rotel while no slouch in it's own right, was out of place, posing for the VTL!
  • nooshinjohnnooshinjohn Posts: 22,770
    The tube power amp/SS preamp is a pretty special combination as well. You should try that one some day as well. :pB):pB)
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with Pass Labs Xono Phono Preamp, Walker Precision Motor Drive, ClearAudio Goldfinger Diamond v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X0.2 three chassis preamp, PS Audio PerfectWave DAC MkII, Krell Evolution 505 SACD Player, Pioneer Elite SC-LX701, Oppo UDP-205 4K Blu-ray player, Sony XBR70x850B 4k, Polk audio AB800 "in-wall" surrounds.
    I swear by my life and my love of it that I will never live for the sake of another man, nor ask another man to live for mine.” .
    “If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
    It's not just the tubes, there are many SS pre amps that easily outperform the Rotel.
    Are you making a statement? :smile:
    Early work on a second set... yes I am.
Howdy, Stranger!
