VTL 2.5 PreAmp in the House!
Been married for a while, I take it?
Hehe! In the lockbox!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Pffft….what's an Almond Joy without the nut eh ? Throw up a review, maybe a comparison to something else your familiar with. The dogs are getting restless.
Will do!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
So today, the VTL appears to have schiesse the bed. I turn the unit on, it powers on ok (fuse is good), but no signal to the amp. No sound. Tried multiple sources into the pre (CD, Aux1), nothing. Checked all cables to make sure everything was tight. Nothing. Dang.
All the tubes light up as normal. Opened the hood, nothing looks out of ordinary. Everything is clean, in fact.
So then I swapped in my Rotel pre into the main system, everything works as it should. Gotta be the pre.
Any ideas? Thanks.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Bad relay. I believe there are 3 on the rear board. Try tapping on them one at a time.Political Correctness'.........defined
President of Club Polk -
don't hit me, did you check the mute switch?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I did notice an intermittent clicking noise coming from it. Could that be the relay?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Here's a stock pic under the hood:
Do you have theater bypass activated?
Tapped each one of relays. While the unit was on (yes I know). And tapped each one of them a little more aggressively unpowered and removed from the rack. Nada.
Man, that sux....I never had any issues with it....so does it go through the normal delay start with the blinking light, then does it click or no click after the delay?
Did you try the second pair of output RCA's? -
Hey no worries. Yep normal startup. Flashing light stops, but no discernible click. I do get an intermittent clicking after it’s on though.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Yep, like I said you've got a bad relay. You might as well replace all 3 as they are not expensive.
Here you go, https://www.newark.com/omron-electronic-components/g5v-2-h1-dc5/relay-signal-dpdt-24vdc-1a/dp/35K4531Political Correctness'.........defined
Thanks Jesse! Now I gotta decide if I'm up to the challenge of replacing em. I've done some rudimentary soldering back in the day, and present, but not sure I have the confidence to mess with such an exqusite (and expensive) piece of gear!
Piece of cake. You'll have to remove the selector pot extension collar and the support. Then loosen the board by freeing up all the RCA jacks then flip it up to access the back of it. You will not have to desolder any of the leads going to the board. Use a rag to support the board inside the case, then get to work replacing the relays. You will need a good solder sucker.
Just watch a few soldering/desoldering videos on YouTube.
Take your time, go slow, and make sure you don't go aggressively too hot or too conservatively cold with your iron when soldering.
My 12 year old nephew taught himself to solder using YouTube videos and some advice from me and now the kid can solder PC board stuff with the naked eye...my old a$$ has to use a magnifying glass.
So easy even a 12 year old can do it!
I feel ya on the magnifying glasses. Been wearing reading glasses for the past year.
Bunch of old farts.Political Correctness'.........defined
So today, @GlennDog heard my plight (no tube pre, the world is ending)
and offered up his absolutely beautiful Cary SLP-98 tube pre, as a loaner, while the VTL is going under repairs!
All I can say is wow! Thanks very much Dog!
This is one of the reasons (among many) as to why CP is such an awesome place. It's about helping each other out, in times of need.
And, I get to put some ears on another tube pre! Pic of his baby:
This place is pretty special in that regard! Why I will never move on to another forum regardless of if I have Polk stuff or not2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
All warmed and ready to rock!
After the Cary SLP “sweet little pre“ and Reference Audio Labs umbilical cord settle-in, a comparison might be in order, Sir
RAL is the real deal . . .AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Hmm, Dave you might have a slight issue, I was just reading the operating manual for the Cary and under the "Initial Setup" section, it states that a "spiked rack" is required for optimum fidelity.
Might want to take care of that before doing any critical listening. -
Cary makes some spectacular equipment. Enjoy the loaner and, I agree with Glendog, a comparison is in order
HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Yesterday during my troubleshooting process, I swapped in the Rotel Pre, just to make sure everything else was working. Confirmed. Coming from the VTL, everything being equal, all I can say is OMG! The soundstage was smaller, sounded thinner, and the highs were veiled compared to the VTL.
I'm guessing most of you toobies already knew that!
Without ever having run a tube pre, always been a SS guy, I am a true believer in the tube pre/SS power amp setup. I'll never go back!
The Rotel while no slouch in it's own right, was out of place, posing for the VTL!
The tube power amp/SS preamp is a pretty special combination as well. You should try that one some day as well.
It's not just the tubes, there are many SS pre amps that easily outperform the Rotel.Political Correctness'.........defined
nooshinjohn wrote: »The tube power amp/SS preamp is a pretty special combination as well. You should try that one some day as well.
Are you making a statement?
Early work on a second set... yes I am.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I’ve got a SS pre that you can try, assuming you have a tubed amp . . .
An Adcom GFA-750 w/ a passive setting, blue boards of courseAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
