What speakers are these?
  • maingey
    maingey Posts: 632
    DaveHo wrote: »
    Pull those crossovers from the cabinet & spray them down with some CRC QD Electronics Cleaner. Won't harm a thing.
    I've done it a number of times when I've picked up gear with bad smoke odors & such. I've pulled boards out of pieces as well as sprayed down the entire interior when board removal was too difficult. They come out sparkling & any odor is gone. Just be sure to let it evaporate fully before firing up.
    ok I'll google. it. They actually don't really smell, and his home didn't smell like a cat was still there. The seller was moving so I think most of those factors are long gone.
    I was going to do the air can and rubbing alchohol on a q tip but I'll try your method if it is gtg.
    pitdogg2 Posts: 27,659
    DaveHo wrote: »
    great suggestion Dave I had forgot all about that. I too have used it on fan motors and other electronics. works darn good!
  • maingey
    maingey Posts: 632
    Not sure if anyone's mentioned it yet but, were I you, I'd proceed with caution in terms of any cleaning/maintenance of that PR. The passing years haven't been kind to those old flat laced PRs (IMO/IME). They tend to delaminate (again IME). That one in your photo looks quite good at this late date, but it may not be all that robust if'n you were to start scrubbin' on it or somethin'.
    Just thought that was worth mentioning. Apologies if it was mentioned in earlier chatter here & I missed it.
    FWIW, here's a photo of my erstwhile LF-14 subwoofer taken a few years back illustrating the deterioration of the PR.
    10729919005_c06dcb86a5_b.jpgDSC_1150 by Mark Hardy, on Flickr
    Thank you for this. I was just going to use distilled water and wipe up around the surrounds. I only gently pushed on the driver when I was buying them to determine if the basket or coil was shot.
  • DaveHo
    DaveHo Posts: 3,584
    Yep, that's the one!
  • maingey
    maingey Posts: 632
    @DaveHo awesome, there is a Walmart around the corner from my job. I'll grab a can @ lunch. Is there a repository on this forum with an exploded view of speaker so I know how to take the crossover out? I'll google it for now. You guys are getting me excited about this.
  • FestYboy
    FestYboy Posts: 3,861
    All of the XO sits on top, one 3 pin connector, disconnect the tweet, and 2 brass thumb nuts.
  • westmassguy
    westmassguy Posts: 6,850
    FestYboy wrote: »
    Not quite, the B/C revisions also have the filter for the other driver behind the binding post cup, couple of caps and coils. Only the original RTA-12 had everything on top.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • DaveHo
    DaveHo Posts: 3,584
    I don't see a need to clean the internal portion of the crossover. I was thinking the top would be easier to clean with the CRC QD spray. I'd probably still hit it with compressed air & a chip brush to get the worst off first.
  • maingey
    maingey Posts: 632
    Just found out what a 'chip brush'... Guess it is better than an old toothbrush.
  • maingey
    maingey Posts: 632
    DaveHo wrote: »
    The two red coils on the top have some kind of protective tape on them. Is it ok for the CRC to get on them also or should I avoid spraying them altogther?
  • maingey
    maingey Posts: 632
    Quick question related to all of this. How do I tell the right from left speaker?
    on the back of one of the tweeters the label is yellow while the other is white. Also
    with the yellow labeled SL2000 the HFOUT from the board is a white wire that goes left contact on the SL200 and the HF GND OUT black wire goes to the right.
    The white labeled SL2000 is vice versa with the connectors. I did look at the posted schematic but I only know a little of what I'm looking for. The speakers no longer have right/left tags on the rears and I don't see anything on the boars that indicate 'R' or 'L'
  • codycatalist
    maingey wrote: »
    Usually black is positive and white is negative. On the tweeter there should be a + carved by one of the terminals to indicate positive.
  • maingey
    maingey Posts: 632
    maingey wrote: »
    @codycatalist Thank you, that part I've got. I'm trying to determine which speaker is designated as a Right Speaker and Left, as RTA speakers are supposed setup a particular way.
    Tweeters on the 12 are wired opposite as the phase gets reversed in the xo. So white to positive and black is negetive
  • codycatalist
    My apologies, I misread the post. They will sound best in their correct positions, if possible just switch their positions and see which configuration sounds best and roll with it.
    I don't remember if the XOs have the designation, I believe they do not.
  • codycatalist
    Are the serial number indicators still on the back? Not the L or R stickers but if the serial numbers are on there is should indicate which is L and R by having that letter before the serial number.
  • maingey
    maingey Posts: 632
    @codycatalist there are still some level of print on the serial # indicators. I didn't think to look there as a lot Polks I've seen that required this attention had a 'left' and 'right' sticker on the back (google searching). Great idea. I'll take a peek later tonight after prepping the bird!
  • codycatalist
    maingey wrote: »
    Yeah report back, hopefully that helps you out. Happy Thanksgiving!
  • maingey
    maingey Posts: 632
    @codycatalist Happy Thanksgiving, and you are correct, the R and L designation comes up in the serial #
  • maingey
    maingey Posts: 632
    The odd thing is the serial # start as 12c?but the crossover board says 12bjmda83b748xk4.jpg
  • Faustin
    Faustin Posts: 1,151
    maingey wrote: »
    IIRC the board for the 12b and 12c is the same.
  • westmassguy
    I believe about the only difference, is the B had a fuse, and the C had a polyswitch
    Only thing i seen on the schematics the other day so i believe you are correct.
  • CH46E
    CH46E Posts: 3,595
    All the boards I've seen on 12c have different value caps from a 12b as well as different tweeters. But I think they use the same board.
    I still think you may have a 12c since you dont have the peerless tweeters.
    I think the 12b got a mid model revision where they removed or added the poly for the fuse and I dont think that was the difference from a b to c.
    edited November 2018
    CH46E wrote: »
    Did you read the schematics?
    What cap value was different?
  • CH46E
    CH46E Posts: 3,595
    CH46E wrote: »
    Those schematics are both for 12b. 1 with revision where the poly switch was removed. Not 12c. Try and find a schematic for the 12c not a revised 12b or 12a.
    I may be wrong but this is how I understand it to be.
  • CH46E
    CH46E Posts: 3,595
    This is a 12c crossover. Has a resistor and differant caps than a 12b. 12b do not have a resistor on the top board. The resistor for 12b in in the cab. The schematics you are talking about show no extra resistor. That is what leads me to believe both those schematics are for 12b with and without revisions aka poly switch vs fuse. Also still have never seen an oem 12b come with any tweeter other than the peerless with a hole in the dome. 5514 and or 7514.
  • CH46E
    CH46E Posts: 3,595
    Notice the first two pics above (last post) with a different crossover also have a non peerless tweeter. 3rd pic is a 12b with peerless. This photo below is my 12b crossover with the oem peerless.
    I'm almost certain he has the more sought after 12c.
    And this is a 12b serial number. Notice the b in place of his c.
