VTL 2.5 PreAmp in the House!
1246
  • verb
    verb Posts: 10,176
    lightman1 wrote: »
    verb wrote: »
    tonyb wrote: »
    audioluvr wrote: »
    Ok you've had just about enough time to fiddle with your new toy... .
    Eh, maybe not. He's still looking for his left nut under the couch. Scratching his head about why he didn't do this sooner.
    Can’t find my right nut either! :smile:
    Been married for a while, I take it?
    Hehe! In the lockbox! :smile:
  • verb
    verb Posts: 10,176
    tonyb wrote: »
    verb wrote: »
    tonyb wrote: »
    audioluvr wrote: »
    Pffft….what's an Almond Joy without the nut eh ? Throw up a review, maybe a comparison to something else your familiar with. The dogs are getting restless.
    Will do!
  • verb
    verb Posts: 10,176
    So today, the VTL appears to have schiesse the bed. I turn the unit on, it powers on ok (fuse is good), but no signal to the amp. No sound. Tried multiple sources into the pre (CD, Aux1), nothing. Checked all cables to make sure everything was tight. Nothing. Dang.
    All the tubes light up as normal. Opened the hood, nothing looks out of ordinary. Everything is clean, in fact.
    So then I swapped in my Rotel pre into the main system, everything works as it should. Gotta be the pre.
    Any ideas? Thanks.
    F1nut Posts: 51,918
    Bad relay. I believe there are 3 on the rear board. Try tapping on them one at a time.
  • marvda1
    marvda1 Posts: 4,958
    don't hit me, did you check the mute switch?
    Puritan PSM156
  • verb
    verb Posts: 10,176
    marvda1 wrote: »
    Yep mute switch is off.
  • verb
    verb Posts: 10,176
    I did notice an intermittent clicking noise coming from it. Could that be the relay?
  • verb
    verb Posts: 10,176
    edited December 2018
    Here's a stock pic under the hood:
  • gmcman
    gmcman Posts: 1,858
    Do you have theater bypass activated?
  • verb
    verb Posts: 10,176
    gmcman wrote: »
    Nope. Double checked all that.
  • verb
    verb Posts: 10,176
    Tapped each one of relays. While the unit was on (yes I know). And tapped each one of them a little more aggressively unpowered and removed from the rack. Nada.
  • gmcman
    gmcman Posts: 1,858
    Man, that sux....I never had any issues with it....so does it go through the normal delay start with the blinking light, then does it click or no click after the delay?
    Did you try the second pair of output RCA's?
  • verb
    verb Posts: 10,176
    gmcman wrote: »
    Hey no worries. Yep normal startup. Flashing light stops, but no discernible click. I do get an intermittent clicking after it’s on though.
    F1nut Posts: 51,918
    Yep, like I said you've got a bad relay. You might as well replace all 3 as they are not expensive.
    Here you go, https://www.newark.com/omron-electronic-components/g5v-2-h1-dc5/relay-signal-dpdt-24vdc-1a/dp/35K4531
  • verb
    verb Posts: 10,176
    Thanks Jesse! Now I gotta decide if I'm up to the challenge of replacing em. I've done some rudimentary soldering back in the day, and present, but not sure I have the confidence to mess with such an exqusite (and expensive) piece of gear! :smile:
    F1nut Posts: 51,918
    Piece of cake. You'll have to remove the selector pot extension collar and the support. Then loosen the board by freeing up all the RCA jacks then flip it up to access the back of it. You will not have to desolder any of the leads going to the board. Use a rag to support the board inside the case, then get to work replacing the relays. You will need a good solder sucker.
  • verb
    verb Posts: 10,176
    ZLTFUL wrote: »
    Just watch a few soldering/desoldering videos on YouTube.
    Take your time, go slow, and make sure you don't go aggressively too hot or too conservatively cold with your iron when soldering.
    My 12 year old nephew taught himself to solder using YouTube videos and some advice from me and now the kid can solder PC board stuff with the naked eye...my old a$$ has to use a magnifying glass.
    So easy even a 12 year old can do it! :smile: I feel ya on the magnifying glasses. Been wearing reading glasses for the past year. :cry:
    F1nut Posts: 51,918
    Bunch of old farts.
  • verb
    verb Posts: 10,176
    So today, @GlennDog heard my plight (no tube pre, the world is ending) :smile: and offered up his absolutely beautiful Cary SLP-98 tube pre, as a loaner, while the VTL is going under repairs!
    All I can say is wow! Thanks very much Dog!
    This is one of the reasons (among many) as to why CP is such an awesome place. It's about helping each other out, in times of need.
    And, I get to put some ears on another tube pre! Pic of his baby:
  • stangman67
    stangman67 Posts: 2,328
    This place is pretty special in that regard! Why I will never move on to another forum regardless of if I have Polk stuff or not
  • verb
    verb Posts: 10,176
    All warmed and ready to rock! :smile:
  • GlennDog
    GlennDog Posts: 3,157
    After the Cary SLP “sweet little pre“ and Reference Audio Labs umbilical cord settle-in, a comparison might be in order, Sir
    RAL is the real deal . . .
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    Clipdat Posts: 13,100
    Hmm, Dave you might have a slight issue, I was just reading the operating manual for the Cary and under the "Initial Setup" section, it states that a "spiked rack" is required for optimum fidelity.
    Might want to take care of that before doing any critical listening.
  • halo
    halo Posts: 5,618
    Cary makes some spectacular equipment. Enjoy the loaner and, I agree with Glendog, a comparison is in order :)
    HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
    HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10
  • verb
    verb Posts: 10,176
    Yesterday during my troubleshooting process, I swapped in the Rotel Pre, just to make sure everything else was working. Confirmed. Coming from the VTL, everything being equal, all I can say is OMG! The soundstage was smaller, sounded thinner, and the highs were veiled compared to the VTL.
    I'm guessing most of you toobies already knew that! :smile:
    Without ever having run a tube pre, always been a SS guy, I am a true believer in the tube pre/SS power amp setup. I'll never go back!
    The Rotel while no slouch in it's own right, was out of place, posing for the VTL!
    nooshinjohn Posts: 25,973
    The tube power amp/SS preamp is a pretty special combination as well. You should try that one some day as well. :pB):pB)
    F1nut Posts: 51,918
    It's not just the tubes, there are many SS pre amps that easily outperform the Rotel.
  • verb
    verb Posts: 10,176
    Are you making a statement? :smile:
    Early work on a second set... yes I am.
  • GlennDog
    I’ve got a SS pre that you can try, assuming you have a tubed amp . . .
    An Adcom GFA-750 w/ a passive setting, blue boards of course
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
