Okki Nokki mk2
2
  • joecoulson
    joecoulson Posts: 4,943
    msg wrote: »
    joecoulson wrote: »
    As far as the vacuum head brush, the felt gets just damp after initiating the vacuum but the dust is left behind. This is dramatically reduced by using the felt brush before the whole cleaning cycle. It means less times I need to remove the vacuum head and wipe/clean it.
    I'm not quote clear on this bit quoted above. Can you clarify?
    Yes
    Before I clean the record with the fluid/goat hair brush/vacuum, I use one of these brushes:
    To clean off loose dirt. This helps to keep larger debris out of the vacuum felt head.
    Make sense?
    msg Posts: 10,458
    You say the felt gets damp on the vacuum head, but the dust left behind - you mean on the record, or that it builds up on the vacuum head?
    Would the carbon fiber brush sweep help with this?
    SCompRacer Posts: 9,121
    edited August 2018
    My preference is Mofi brushes. To satisfy OCD I use one for scrub and one for rinse. I also have a couple different vacuum wands for wash vacuum and rinse vacuum. I swap the cork mat for the cleaned side of LP. I use Mofi sleeves.
    Before play I do a carbon fiber brush before dropping the needle. I avoid Cheetos and pizza rolls when handling records.
    I use a Tergitol/distilled mix to clean, distilled to rinse. I'll steam nasty ones, but you gotta be careful and keep moving with the steam or you'll warp the record. Steam won't fix a damaged record though, but it helps moisten and dislodge dried, stuck on biological whatever.
    Stanton makes a convex brush with holder. I got this with a purchase but never used it. Unsure if they offer replacement pads like the Mofi's do.
  • joecoulson
    msg wrote: »
    It helps to reduce build up on the vacuum head. Otherwise if you take a really dirty record, all the dust and dirt goes on the felt of the vacuum head.
  • joecoulson
    SCompRacer wrote: »
    Lol. I avoid them at all times. Awful tasting things.
    txcoastal1 Posts: 13,518
    edited August 2018
    joecoulson wrote: »
    SCompRacer wrote: »
    FYI, the original pizza rolls in the 80's were good. I hadn't eaten them since...until about 6 months ago my son had bought a bag...whollytastelikeshlt...yup
  • halo
    halo Posts: 5,618
    SCompRacer wrote: »
    That's good stuff right there! Thanks for sharing the knowledge Rich!
    HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
    HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10
    edited August 2018
    txcoastal1 wrote: »
    I agree!
    halo wrote: »
    That's good stuff right there! Thanks for sharing the knowledge Rich![/quote]
    OCD is good for some things.....lol
  • agfrost
    agfrost Posts: 2,474
    SCompRacer wrote: »
    To satisfy Rich's OCD I also use one Mofi brush to wash, the other to rinse.
    Jay
    agfrost wrote: »
    I love being an enabled enabler... B)
    edited August 2018
    DSkip wrote: »
    This thread just reminds me why I don't want to get into vinyl.
    I never got out so I didn't have to get back in.... B)
    Tony M Posts: 11,680
    edited August 2018
    I still have my first turntable installed in a home made upright audio cabinet I built out of solid Clear Fir wood.
    In fact, I just showed it to one of my old friends yesterday.
    His word...SWEET!
    I still have every record I bought or ordered from Columbia house records mail order club.
    The good ol' days. :)
  • joecoulson
    DSkip wrote: »
    Give it time. A lot of time! Whew
  • joecoulson
    Looking at your sig, I would have to agree with you:
    however I would love to see one of these in your setup:
    audioluvr Posts: 5,982
    edited September 2018
    joecoulson wrote: »
    (why goat hair?)
    14 yr old virgin pubic hair was their first choice but after getting the restraining order, opted for the goat hair
  • joecoulson
    Uh okki nokki then...
    DSkip wrote: »
    Actually, the financial obligation is what scares me most at this point. I know what it would cost me to feel like I'm playing at the level I should be and that is... insurmountable at this point.
    Sweet jebus, how much are you talking about? :o
  • joecoulson
    My guess is that if Skip were to venture down the rabbit hole, initial setup would run $20k+
  • halo
    halo Posts: 5,618
    joecoulson wrote: »
    That's a heck of a starter system!
    Why not grab a preowned/vintage Technics in decent shape (@mhardy6647 can make a suggestion or may even have a suitable candidate amongst his collection), a Schiit Mani, and a Nagaoka MP-110? That's not expen$ive but it'll sound pretty darn good for a minimum investment.
    Ya, you'll need something to clean the records (you can start with a Spin Clean), store the records (Mofi sleeves), a brush to wipe the records before play (Hunt EDA), and a stylus cleaner for before and after play (Mr. Clean Magic Eraser, or a stylus brush, or some AT liquid cleaner, or the Onzow).
    Still, not a huge investment to get really good quality playback for the investment and a good way for you to see if you really like it (and want to invest the time and energy on a regular basis).
  • joecoulson
    I know we are way off topic, but it’s my thread so fak it.
    I think my perfect setup would be a VPI scout, Nagaoka mp500 and keep my CA phono pre.
  • joecoulson
    So I have to be close to the 500th cleaning for this machine between myself and two others I have let use it. Still does a fantastic job
    Before
    After
  • verb
    verb Posts: 10,176
    Just read this thread. Ugh. Cleaning records! I love vinyl, but am a bit too lazy right now! Great review and update Joe! :smile:
    nooshinjohn Posts: 25,974
    DSkip wrote: »
    You are leaving money (a LOT of it) on the table as a hifi dealer by not offering vinyl. The markup on cartridges alone is stupid. Local dealer here told me his margins on turntables and related stuff is much higher than on anything else in his store.
  • Thorton
    Thorton Posts: 1,324
    Every time I heard a snap, crackle or pop at Axpona it made my skin crawl. I’ll stick with digital.
    Nice review Joe. Enjoy!
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • joecoulson
    Pops and clicks don’t bother me. As long as they are not embedded dust. Love me some vinyl. Best sounding format I own.
    There is always the Sugar Cube.
  • NotaSuv
    NotaSuv Posts: 3,871
    edited April 2019
    Fantastic review, my son had this on his I want list and after sending him your review he is ready to pull the trigger...wish the pro reviews were as in depth as yours...
  • joecoulson
    Why Thank You brother
  • jdjohn
    jdjohn Posts: 3,377
    I've logged some time cleaning a few dozen records on Joe's machine, and it works a treat. I had one record that I *thought* had a flaw in the vinyl (was skipping over a groove), but after cleaning with the Okki Nokki, the skip was gone...must have been some debris that I couldn't see with the naked eye.
    My thanks to Joe for letting me use so much of his cleaning fluid :)
  • joecoulson
    Anytime my friend.
