Equipment Racks
I think the fact that the columns are one long piece of threaded metal must be great for the structural rigidity of the rack.Jetmaker737 wrote: »This is the direction I think I'm headed once I convince myself to pull the trigger. I like the simplicity and it's adjustable. And stout.
http://www.mapleshadestore.com/customerphotos.php#prettyPhoto[gallery1]/15/
@Clipdat not necessarily...I use lay hardwood flooring and the bamboo that they're using now often ties doesn't look like bamboo. My sister is having a house built now, and, I was there the other day and she handed me a box of planks and asked me to pick out a few I liked. Two of the ones I picked out blew me away, one was bamboo that didn't look like bamboo, and, the other was a eucalyptus that didn't look like eucalyptus. these weren't engineered pieces. I'm not sure how they're processing this stuff now, but, they've reached new levels on how some of these woods are taking on stains. Surprisingly, the bamboo had a grain that resembled a cross between an ash and an alder, very clear and straight. The stain looked like a cross between a rich oak and a rich cherry. Ya gotta think outside the box nowdays.
I was basing my conclusions off their retail price sheet PDF, nowhere does it mention the bamboo being offered in a colored finish.
https://static1.squarespace.com/static/57a4acc7f7e0ab3289b844df/t/5911f643ebbd1a075435f685/1494349381113/Quadraspire+US+Retail+Price+List+1705.pdf -
Really hard to find a rack in L.A. on Craigslist. The recording biz defines an "audio rack" as something 19" wide that you can screw in any number of pro audio goodies used in recording studios like preamps, compressors, etc. "Stereo Rack" usually turns up cheap stuff and/or beat up consoles.
It's a tough life on the left coast ....Living Room (HT):Denon AVR X-3000 ; Ascend Acoustics Sierra 2s ; Ascend Acoustics Duo Center ; LSiFX Surrounds ; Sub – Rhythmik F12SE
2 Channel Studio: Marantz PM8004 Integrated ; Marantz SA8004 ; Music Hall MMF 7.3TT w/Ortofon Bronze; Schiit Bifrost DAC ; Monitor 7 Series 2 with RDO 198s; Rythmik F12SE
Don't cry
Don't raise your eye
It's only teenage wasteland -
I saw this ... an exception to the rule. Hoping it's still here when I get back in town next week! Also hoping none of my fellow So Cal Polkies see your post!Living Room (HT):Denon AVR X-3000 ; Ascend Acoustics Sierra 2s ; Ascend Acoustics Duo Center ; LSiFX Surrounds ; Sub – Rhythmik F12SE
Don't cry
Link redacted and fingers crossed!I saw this ... an exception to the rule. Hoping it's still here when I get back in town next week! Also hoping none of my fellow So Cal Polkies see your post!
Thanks! You're a Prince among men!Living Room (HT):Denon AVR X-3000 ; Ascend Acoustics Sierra 2s ; Ascend Acoustics Duo Center ; LSiFX Surrounds ; Sub – Rhythmik F12SE
Don't cry
Good choice. My Mapleshade rack weighs 500 pounds empty.
Three 20 amp circuits. -
Just to let y'all know, we are now an authorized dealer for some excellent SolidSteel racks and stands. If you are going to AXPONA we'll have 2 mono block systems on SolidSteel Hyperspike HF series racks and amp stands. Visit Room 2-Utopa A, the Legacy Audio/Raven Audio/Douglas Connection room if you are going.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
PIcked up the unit @Clipdat and I were discussing above. In very nice shape and a very solid steel frame that you could jack a car up on. 1/2 inch plywood shelves may not be the best, but thinking of adding sorbothane to the corners supporting the shelves. Will elevate the shelves slightly above flush, but may be worth it? Not sure if needed on all shelves or just the top, where my TT will be. Rack will be in my 2 channel room, with laminate flooring over concrete. Pics of the rack, shelf support where sorbothane would go, as well as Amazon link to the isolation tabs. Any thoughts / opinions welcome.
https://www.amazon.com/Isolate-Sorbothane-Vibration-Isolation-Circular/dp/B00X6R1CTC/ref=sr_1_11?ie=UTF8&qid=1522706022&sr=8-11&keywords=1+inch+sorbothaneLiving Room (HT):Denon AVR X-3000 ; Ascend Acoustics Sierra 2s ; Ascend Acoustics Duo Center ; LSiFX Surrounds ; Sub – Rhythmik F12SE
Don't cry
Woot, looks great! Glad that you scored it! I want it! And gimme some of that bottled water while you're at it!
Can you get some squares, and cut them into triangles?
I was actually thinking that might work as well, but not sure how hard the material is to cut.
You can have all the bottled water you want, IF you're in my 'hood AND there is an earthquake.
We prepare for these things!Living Room (HT):Denon AVR X-3000 ; Ascend Acoustics Sierra 2s ; Ascend Acoustics Duo Center ; LSiFX Surrounds ; Sub – Rhythmik F12SE
Don't cry
i had an older target stand and the top shelf floated on 4 spikes.
are those 4 holes in the top 4 corners, they may take spikes.
see if one of the 4 shelves has metal discs on the bottomAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Speaker Cables: Organic Audio Organic Reference 2
Interconnects: Argento Organic Reference 2, Argento Organic 2
Power Cables by: Argento Organic Reference, Triode Wire Labs, Swiss Cables
Wireworld Spaceport -
All of the shelves are the same I think but will re-check to be sure.
Don't cry
He informed me that unfortunately he will not be there in person.Doug, are you going to be at AXPONA?
Our cables will be in all 4 systems in room 2-Utopia A, along with Raven and Legacy. We will also have 2 of the systems on Solidsteel Hyperspike HF series racks and amp stands. Wish I could be there in person, but just can't. Maybe next year...Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
So just to be clear, after 15 pages you went with the one you mentioned in your very first post? Nice.
Close! That was the S2-5, this is the next model up which features additional niceties.So just to be clear, after 15 pages you went with the one you mentioned in your very first post? Nice.
Nice man!
The story isn't over...we have to wait for it to arrive. Once inspected and the realization sits in that it's not 123% perfect we'll have to listen to the **** session about his Chevy not being a Bentley. -
Wow Kerry, really? You know you don't have to read my threads.The story isn't over...we have to wait for it to arrive. Once inspected and the realization sits in that it's not 123% perfect we'll have to listen to the **** session about his Chevy not being a Bentley.
I've said it before, I wouldn't want to walk next to him during a lightning storm. That sure was a run of bad luck. If anything, this thread has at least shown a downward spiral of quality of VTI and how they aren't made the same way as they used to be. End caps threaded vs. glued....crookedly.
This. I hope that people searching for VTI equipment racks come across this thread and as a result don't buy their inferior products.If anything, this thread has at least shown a downward spiral of quality of VTI and how they aren't made the same way as they used to be.
So do you get to keep the VTI?
Anyone in the bay area is welcome to come take it from me for free. However I would feel awful knowingly handing off something of such poor quality to someone else. It would be like a curse to give it to someone, not a gift.So do you get to keep the VTI?
I was thinking you should sell it for the shipping cost to one of the guys here on the forum that works with metal. See if they can bend it.
Not a bad idea, I guess. But I doubt anyone is going to want to pay the $100-150+ it's going to cost to ship this heavy hunk of scrap metal.
It cost me $89 or something to ship the pair of TSi100 bookshelf speakers to the east coast that I Christmas Karma'd on here. Shipping prices are insane right now.I was thinking you should sell it for the shipping cost to one of the guys here on the forum that works with metal. See if they can bend it.
Do all shelf segments have issues or can you make a two shelf rack out of good parts of the VTI? Or make two separate amp stands, even though one will have longer legs. I remember you said you didn't have room for two racks but is there any sections salvageable?
