Equipment Racks
191012141518
  • marvda1
    marvda1 Posts: 4,389
    edited March 2018
    is there a picture of your setup anywhere ?
    post it and you can get suggestions.
    Transport/Dac: L.K.S MH-DA004, Cayin Venus cd-100i, Musical Paradise mp-d2 mkI,
    Musical Paradise mp-d2 mkIII
    Speaker Cables: Organic Audio Organic Reference 2
    Cerious Technologies Graphene Extreme
    Interconnects: Argento Organic Reference 2, Argento Organic 2, Gabriel Gold Reckoning
    Power Cables by: Argento Organic Reference, Cullen Cables, 6sons Audio, Swiss Cables
    Clipdat Posts: 9,781
    edited March 2018
    Not really. It's far too embarrassing to post for public consumption.
    Edit: I went through my old threads and I did post a pic at one point. This basically shows the space I'm working with. TV is not there anymore now, and speakers are 703s. *braces for impact*
    marvda1 wrote: »
  • delkal
    delkal Posts: 765
    Clipdat wrote: »
    I wonder what the functional/real world/rigidity/wobble/isolation/etc. difference is between these two:
    It would be interesting to see how the spikes are constructed and attached. For spikes to work they need to be well made and firmly attached to something rigid.
    Little spikes loosely screwed into a thin endcap on a hollow tube are decorative only. At best.
    edited March 2018
    It looks like the piece that they screw into is separate from the tubes:
    Better view of where the spikes are attached:
    delkal wrote: »
    edited March 2018
    According to the Solidsteel.it website, it sounds like custom column/shaft lengths are available. So instead of the standard 8" columns, I could get 5.7" columns - thus reducing the overall height of the rack, and hopefully increasing the rigidity by not making the center of gravity so high when the 30lb TT is placed on the top shelf. Interesting.
  • delkal
    delkal Posts: 765
    Clipdat wrote: »
    delkal wrote: »
    That design looks OK. Much better than trying to thread spikes directly into a 1/16 inch endcap.
    I have a cheapo Sanus rack (pic way back on page 5) and it is similarly designed ( but without any spikes). Screw a bolt into a leg, put a board between them, and screw on the next leg section. Even with a cheap China rack you can feel it firmly bottoming out when you tighten it and it is sturdy when you are done.
    Your pic said s series "starter kit". Can you give a link if they just sell the spikes? I am sure the treads on the post are the same as my cheap rack.
    Looks like they sold them on Music Direct at some point, but not anymore:
    https://www.musicdirect.com/vibration-control/solidsteel-8mm-spikes-set-of-3
    delkal wrote: »
  • verb
    verb Posts: 9,890
    verb wrote: »
    Tony M wrote: »
    Shipping just to me is over 50.00 each. So it's 120.00 a piece. Ouch.
    I like it, but, it's not for me.
    I'll have to stick with wood I guess.
    I’m negotiating shipping for 2 pieces, which will be cut in half for the legs. Yeah he’s pretty steep on shipping. We’ll see what he comes up with.
    So the guy came back with a shipping quote for about the same price. No relief. :disappointed:
    Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
    Garage: Cambridge Audio 640A Integrated Amp, Project Box-E BT Streamer, Polk Tsi200 Bookies, Douglas Speaker Cables, Shunyata Power Conditioner
  • verb
    verb Posts: 9,890
    I also found these and e-mailed them a few days ago. No response yet. These look much nicer.
    http://www.mesgate.com/aluminum-extrusions-80mm-40mm-square-l-shape-with-corner-radius.html
  • jdjohn
    jdjohn Posts: 2,098
    Some of these 'extra stock' extrusions look a lot like Salamander Designs core module designs https://www.salamanderdesigns.com/racks-stands/pro-audio-core-module/ With the right extra stock extrusion product, you might even be able to add these Salamander 'lacing bars' https://www.salamanderdesigns.com/accessories/rack-cartridge-lacing-bars/ I rather like the idea of a continuous pillar as opposed to stacked pieces. Of course there are still the shelves to consider, as well as the feet.
    I use a Salamander 36" version of this https://www.salamanderdesigns.com/racks-stands/audio-stands/ for storing my bullpen/testing gear. I got mine used off CL.
  • verb
    verb Posts: 9,890
    jdjohn wrote: »
    Yep. Not sure I would trust the lacing bars to support the component weight per shelf though.
  • verb
    verb Posts: 9,890
    edited March 2018
    A relentless search found these. I'm gonna go for it! Free shipping but the unit price is still a bit high. These are designed for a 30x30mm rail interface. I chose to go with a 40x40mm, so I'll have to do a bit of machining to get em to fit up.
    Edited to add 1000mm length!
    https://www.ebay.com/itm/3060DR-30x60mm-T-Slot-Aluminum-Extrusion-30-series-Length-100-200-300-400-500mm/132314685509?ssPageName=STRK:MEBIDX:IT&var=431639904980&_trksid=p2055119.m1438.l2649
  • verb
    verb Posts: 9,890
    Very nice!
    Got a mockup/drawing of what you're going to be using these for?
    verb wrote: »
  • verb
    verb Posts: 9,890
    Clipdat wrote: »
    verb wrote: »
    Yep working on it. In my head right now but will post soon. Got a parts list too.
    txcoastal1 Posts: 11,744
    YOU CAN DO IT!!!!
    If you go that route, start a new thread ...should be interesting
  • mikeyb128
    mikeyb128 Posts: 2,886
    750$ per level.....
    2 channel:
    Theater:
    Yeah, seems excessive.
    mikeyb128 wrote: »
    750$ per level.....
  • verb
    verb Posts: 9,890
    Hard to tell from the pics but the cross members seem thin. Some kinda steel, but plate stock. A c-channel or box section would be better for sag. Harder to machine for a DIYer. The Adona racks use a similar design, but welded box section for the cross members.
    edited March 2018
    Nice looking Quadraspire on eBay: https://www.ebay.com/itm/Quadraspire-SVT-5-Shelf-Rack-Black-Bamboo-w-Black-Hardware/112827056091
    Tempting.
    Edit: I don't know why the auction title and description says that the shelf material bamboo. I asked the seller about that, because they clearly look like the standard wood shelves with a black veneer.
    Edit2: The seller is going to take more photos of the shelves and the original box for me. This is a pretty slamming deal considering new this would go for "$2,245".
    I'll build you one just like it for 50% off...I promise ;)
    Hey, it's local! "Item location: San Francisco, California, United States"
    It's an art piece! I did read that a "hanging rack" is supposed to be good.
    Tony M wrote: »
    32,000.00 :o:s
  • verb
    verb Posts: 9,890
    Good for earthquakes out there! :)
    Guaranteed that your CD won't skip during an earthquake?
    verb wrote: »
