Equipment Racks
  • Joey_V
    Joey_V Posts: 8,521
    Yeah that’s a wobble alright
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • BlueFox
    BlueFox Posts: 15,251
    Clipdat wrote: »
    I thought the point of an audio rack was to reduce vibration.
    Actually, it’s purpose is to hold the gear. :).
    Vibration is a major issue in higher end, revealing systems, and a good rack should absorb vibrations, and keep it from the gear. However, that is easier said than done, as you are finding out. Good luck.
    Sometimes stuff happens. When I was putting together my Mapleshade rack some of the ‘nuts’ that go on the steel legs to support the shelves were improperly threaded, and wouldn’t go on. They sent out replacements, and all is well, but it still was an irritant at the time.
    Clipdat Posts: 12,608
    Emphasis on "audio" rack, versus just a regular piece of furniture or shelving. An "audio" rack should have a design goal to reduce vibration.
    That's what I meant.
    BlueFox wrote: »
  • Joey_V
    Joey_V Posts: 8,521
    Maybe it's time to return
    I couldn't find any terms and conditions on their site in regards to returns, but on another site that sells their stuff (standsandmounts.com) their terms mention no returns on opened/assembled products - exchanges only.
    So, don't think a "return" is an option at this point. Also neither me, nor VTI is going to want to foot the bill for return shipping, that's for sure.
    Joey_V wrote: »
  • kharp1
    kharp1 Posts: 3,453
    I know it's a PITA, but, I would totally disassemble and reassemble each tier, verifying as you go that they are square and true. I would get some shot and fill the tubes for added rigidity. If you have to keep it, might as well take the extra steps to make it the best it can be.
  • verb
    verb Posts: 10,176
    kharp1 wrote: »
    Agree.
  • BlueFox
    kharp1 wrote: »
    Yes. LOL
    I was so happy with my Mapleshade rack for the stereo, I bought a five shelf, single width, rack for the HT. Spent an hour or more assembling it, and it looked wrong, and it was wrong. Tilted to the right, and wobbly. Disassembled it and then slowly put it back together. The problem was the steel poles for the shelves screw into brass footers. If they all aren’t screwed into the same depth then you get a FUBAR rack.
  • kharp1
    kharp1 Posts: 3,453
    BlueFox wrote: »
    kharp1 wrote: »
    Yes. LOL
    I love the utilitarian, beefy look of the Mapleshade rack.
  • Joey_V
    Joey_V Posts: 8,521
    When I buy a rack I’m going to do my best to buy a Grand Prix Audio Monaco. When I grow up.
    F1nut Posts: 49,805
    When you grow up Joey you want an Adona rack. I'll argue there is none better and I've got nothing in the game.
    F1nut Posts: 49,805
    Clipdat wrote: »
    This is the wobble/oscillation I'm talking about. I'm lightly pushing on the column.
    https://www.youtube.com/watch?v=Owx0bDh9fWY
    Sledge hammer, video posted on YouTube. Buy an Adona.
    edited March 2018
    Kerry, there's literally nothing to "disassemble". It's just **** frames that sit on top of other **** frames. Nothing was "square and true" as it arrived from the factory. How am I supposed to make it "square and true" short of starting over from where it was flawed initially which is the factory worker welding them on the jig?
    It's not going to magically stop wobbling and oscillating rapidly if I adjust the frames a few millimeters. It's an inherently flawed design and it's a piece of ****. Filling the tiny section of tubes isn't going to do jack **** to add any "rigidity" to it.
    Sorry for the rant, but I'm beyond pissed off about this.
    kharp1 wrote: »
  • kharp1
    kharp1 Posts: 3,453
    The end caps screw on and off, so, I'd start by taking them off and checking threads to verify that none are cross threaded. Then, after doing that, I'd set each section down on something flat and level, and check the piece for trueness. If its true I'd fill it with shot. I'd do the same for each section. If there is one that's not right I would find out where it's out and gently persuade it back to true, fill it with shot and put it back together.
    edited March 2018
    The end caps don't screw on and off, they are press fit and/or glued. The only thing with threads that screws on or off are the spikes.
    Verifying that each section is true, flat, and level would not help align the rack. This is due to the spikes and cups being off as described in earlier posts on this thread. What I actually had to do to get each spike and cap to line up is align each frame section to it's adjacent frame.
    It already required several hours of bending/persuasion of the frame pieces, in order to get it how it is now with the spikes actually sitting in their respective cups.
    I appreciate your suggestions, but this thing is beyond any sort of repair at this point. It's a piece of junk that belongs in the garbage.
    kharp1 wrote: »
    Post edited by Clipdat on
  • kharp1
    kharp1 Posts: 3,453
    Their website even says they screw off for adding shot. Better check again.
    edited March 2018
    From their website:
    Q: How to fill sand or metal bits?
    A: Before you screw the spikes on, fill it with sand or metal bits. Screw the spikes on and turn the unit over.
    kharp1 wrote: »
    Anyway, why are you getting hung up on a technicality regarding how to fill the little poles with lead shot? That's not going to suddenly save the design and make it so it doesn't wobble excessively with a turntable on the top rack. It's a lost cause.
  • kharp1
    kharp1 Posts: 3,453
    Clipdat wrote: »
    From their website:
    kharp1 wrote: »
    No offense here, but, you're an IT guy with very limited skills in the construction area. That's not me, but, paraphrasing you. I, on the other hand, design and build all levels of electrical and robotic components, and all necessary hardware to install and support, as my career. I'm not hung up on anything except telling you how, exactly, I would go about diagnosing and fixing this problem. This isn't rocket science, and, shot is a universally know product used to aid in deadening. The added weight, along with proper aligning, squaring, and plumbing, would probably make for a very nice, solid rack.
    This is the last I will comment as you appear to have gotten the answer figured out on your own and seem somewhat irritated at, what to some, seems to be a simple task. Peace.
  • verb
    verb Posts: 10,176
    @kharp1 if you're willing I will pay for round trip shipping from @Clipdat to you!
    I would also give it a go but work is killing me right now!
    What d'ya say @kharp1 ?
    See @Clipdat Karma may befall you as well!
    edited March 2018
    Sorry Kerry, but even with your impressive credentials, not even you could polish this.
    kharp1 wrote: »
    Amusing suggestion, but that would be an epic waste of money.
    verb wrote: »
  • verb
    verb Posts: 10,176
    No waste my friend. I’ve reworked welded pieces before. Just need the right tools. The press on end caps will indeed come off. Etc. What do you have to lose?
    Might as well just directly Paypal me that $250+ that shipping would cost, so I can put it toward a legit audio rack from a reputable company with proper engineering/design, and made with accuracy and precision.
    verb wrote: »
  • kharp1
    kharp1 Posts: 3,453
    You're right, it's impossible, let's move on.
    A local shop carries Salamander and Core Audio Designs, so I might go check them out in person to see about their stability.
    http://coreaudiodesigns.com/products/component-racks/
  • verb
    verb Posts: 10,176
    edited March 2018
    Clipdat wrote: »
    Very nice! I like the Salamander's as they are infinitely adjustable.
    Do you have to level each shelf? Are the threaded posts one long continuous shaft?
    verb wrote: »
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    verb wrote: »
    Yep you would. You could mark the threaded rod, but any fine tuning to get em level would require turning the nuts a bit. I believe they are a continuous shaft.
    Interesting. Well, I have a bubble level like this that I got for my TT:
    https://cdn.shopify.com/s/files/1/0105/4542/products/ortofon-bubblelevel_1200x.jpg?v=1421686419
    verb wrote: »
    Viking64 Posts: 6,693
    verb wrote: »
    .....rod.......turning the nuts a bit.....a continuous shaft.
    ^^^^^ Absolute filth. :/
  • marvda1
    marvda1 Posts: 4,874
    here's the adona entry level racks.
    http://www.adonacorporation.com/modular.html
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
