SDA upgrade thread 2
12357…10
  • Nightfall
    Nightfall Posts: 10,083
    Do up your Oppo too. @lightman1 I took care of that for ya. B)
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 52,406
    edited April 2017
    Well again you don't have to cover the entire inside of it. A patch on each wall should be more than enough. It just looks good in pics when you overdo it by covering everything.
    While true a little goes along way, you have to put more on them than your first attempt.
    BTW, it's not that the adhesive was too old on that original Dynamat. It's that it never had good adhesion to begin with, hence it's replacement, Dynamat Xtreme.
  • Nightfall
    My Oppo picture made me miss my 2B's again. Damn fine speakers.
    afterburnt wrote: »
  • Nightfall
    edited April 2017
    la2vegas wrote: »
    Nightfall wrote: »
    Just don't put a picture of your old 1.2's otherwise I might have to borrow your box of tissues. :'(
    You keep saying that but I really mean it when I say I don't miss them.
    2B (more or less) = RTA12B > 1.2 > M5 > M4
    afterburnt wrote: »
  • westmassguy
    westmassguy Posts: 6,850
    No such thing as too much.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • honestaquarian
    honestaquarian Posts: 3,275
    Well I've done about as much glueing of the cabinet as I can do. The top front corner is a major b#$×+% to get to through the small woofer holes, so I left it alone.
  • honestaquarian
    edited April 2017
    Time to start drilling
  • honestaquarian
    edited April 2017
    Hey @Toolfan66 Were those slits in the PR template supposed to line up with something??
  • dkfreebird
    dkfreebird Posts: 1,189
    I believe those are there to allow for you to bend the ring when you have to mount it from the inside.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    Eversolo Dmp 8
    SVS SB3000 sub
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • honestaquarian
    Man these parts add up quick,fast and in a big hurry! :#
  • honestaquarian
    edited April 2017
    My next question once the dreadnought arrives will be which connections on the Speakons do the wires go to.........
  • dkfreebird
    Page 11 of dreadnought thread.
    Eversolo Dmp 8
    SVS SB3000 sub
    Oppo 103
    Pangea PC
  • honestaquarian
    Since the drill bit is exactly the same size as the hole in the template and does not actually pass through that hole. Does it matter that it will be interfering with the bit/getting cut up by it while drilling??
  • honestaquarian
    dkfreebird wrote: »
    You da man @dkfreebird !!
    Thanks for following my progress. I am asking some of these questions because I know I ain't the only one who will be wondering about this stuff.
    F1nut Posts: 52,406
    edited April 2017
    Thing is all this info is already posted here if one bothers to look. Most of it is common sense to those with some skills. Those without a basic skill set shouldn't be doing this work in the first place.
  • honestaquarian
    Well that part was quick and uneventful
  • honestaquarian
    I agree with you with the following caveats:
    1) Some of these threads are pages long (*like this one*) and it is very easy to lose track of where all of this information is. Assuming one even knows where to start looking.
    2) Since you work with the public like I do you know that common sense ain't so common anymore.
    Nothing wrong with asking questions. It's the reactions to the questions that can often be the problem.
  • honestaquarian
    edited April 2017
    Funny thing about the midwoofer template is that it's such a tight fit into the countersunk area where the midwoofers go. I really didn't need to use the clamps, as it wasn't moving around at all!
  • honestaquarian
    I got exactly one ring and one tweeter bracket in place without interference. ALL of the others will require cutting, trimming or wood chipping! :(
  • honestaquarian
    Yay my Dynamat came yesterday!
    I had it shipped to my job.
  • Nightfall
    Getting the glue out of the way is the worst part, PITA.
    afterburnt wrote: »
  • honestaquarian
    edited April 2017
    funnier thing is when it does move you just fouled up a hole. You are very lucky...
    No matter how tight it is best to hold it in place to keep from shooting up the bit or worse.
    @pitdogg2
    I literally had to bang the template into place after turning it over/rotating it several times for each hole.It did not want to go into place without a fight I actually only did the drilling without the clamps on the last one.
  • honestaquarian
    edited April 2017
    What about using a file to file down the edges of the rings to make them fit into place?
  • Nightfall
    You can dremel the rings if the brace is in the way but just chisel the glue.
    afterburnt wrote: »
  • honestaquarian
    Wow these tramsformers really are pretty heavy! :o
  • honestaquarian
    Now there's a bit of a surprise! :#
  • honestaquarian
    Now I can see why the case is so big. This thing is effing HUGE!
  • honestaquarian
    Trying to get some three dimensional perspective with a two dimensional pic is hard sometimes.
