SDA upgrade thread 2
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
honestaquarian wrote: »Well again you don't have to cover the entire inside of it. A patch on each wall should be more than enough. It just looks good in pics when you overdo it by covering everything.
While true a little goes along way, you have to put more on them than your first attempt.
BTW, it's not that the adhesive was too old on that original Dynamat. It's that it never had good adhesion to begin with, hence it's replacement, Dynamat Xtreme. -
My Oppo picture made me miss my 2B's again. Damn fine speakers.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
You keep saying that but I really mean it when I say I don't miss them.
2B (more or less) = RTA12B > 1.2 > M5 > M4afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
No such thing as too much.
Home Theater/2 Channel:
dhsspeakerservice.com/ -
Well I've done about as much glueing of the cabinet as I can do. The top front corner is a major b#$×+% to get to through the small woofer holes, so I left it alone.
Time to start drilling -
I believe those are there to allow for you to bend the ring when you have to mount it from the inside.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Man these parts add up quick,fast and in a big hurry!
My next question once the dreadnought arrives will be which connections on the Speakons do the wires go to......... -
Page 11 of dreadnought thread.2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Since the drill bit is exactly the same size as the hole in the template and does not actually pass through that hole. Does it matter that it will be interfering with the bit/getting cut up by it while drilling?? -
dkfreebird wrote: »Page 11 of dreadnought thread.
You da man @dkfreebird !!
Thanks for following my progress. I am asking some of these questions because I know I ain't the only one who will be wondering about this stuff. -
Thing is all this info is already posted here if one bothers to look. Most of it is common sense to those with some skills. Those without a basic skill set shouldn't be doing this work in the first place.
Well that part was quick and uneventful -
I agree with you with the following caveats:
1) Some of these threads are pages long (*like this one*) and it is very easy to lose track of where all of this information is. Assuming one even knows where to start looking.
2) Since you work with the public like I do you know that common sense ain't so common anymore.
Nothing wrong with asking questions. It's the reactions to the questions that can often be the problem. -
Funny thing about the midwoofer template is that it's such a tight fit into the countersunk area where the midwoofers go. I really didn't need to use the clamps, as it wasn't moving around at all! -
I got exactly one ring and one tweeter bracket in place without interference. ALL of the others will require cutting, trimming or wood chipping!
Yay my Dynamat came yesterday!
I had it shipped to my job. -
Getting the glue out of the way is the worst part, PITA.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
honestaquarian wrote: »Funny thing about the midwoofer template is that it's such a tight fit into the countersunk area where the midwoofers go. I really didn't need to use the clamps, as it wasn't moving around at all!
funnier thing is when it does move you just fouled up a hole. You are very lucky...
No matter how tight it is best to hold it in place to keep from shooting up the bit or worse.
@pitdogg2
I literally had to bang the template into place after turning it over/rotating it several times for each hole.It did not want to go into place without a fight I actually only did the drilling without the clamps on the last one. -
What about using a file to file down the edges of the rings to make them fit into place?
You can dremel the rings if the brace is in the way but just chisel the glue.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Wow these tramsformers really are pretty heavy!
Now there's a bit of a surprise!
Now I can see why the case is so big. This thing is effing HUGE!
Trying to get some three dimensional perspective with a two dimensional pic is hard sometimes.
