SDA upgrade thread 2
I am honored to have THE MAN HIMSELF @DarqueKnight chime in on my upgrade thread
Thank you sir!
Where is the best place to get some Dynamat btw? I totally forgot. -
honestaquarian wrote: »Where is the best place to get some Dynamat btw? I totally forgot.
I've always bought mine at Amazon.
https://www.amazon.com/Dynamat-10435-Self-Adhesive-Deadener-Xtreme/dp/B00020CAUG/ref=sr_1_5?ie=UTF8&qid=1489099557&sr=8-5&keywords=dynamat
If that is too much, they have smaller sizes available.
Proud and loyal citizen of the Digital Domain and Solid State Country! -
Thank you sir
You're right it is too much. Hey doesn't Best Buy carry this stuff in store? -
Go to the back of the BB building and ask the car stereo installation people if they have some scraps you could have or buy.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Okay now the wiring goes to @vr3 for my crossover upgrades -
Hey just curious
Do Larry's rings @Toolfan66 get glued into place or just pressed in? -
Pressed in.Political Correctness'.........defined
President of Club Polk -
If you're like me it will be the one size you don't have 9/32.
I'll be damned if you didn't hit the nail RIGHT ON THE FARGON HEAD!!!
Well back to the bloody hardware store AGAIN
It's good for the economy, we call it trickle down economics2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Yeah I have at least 3 drill bit sets and none of them contained that size bit
So across town I schlepped on the subway to the hardware store just to get this -
honestaquarian wrote: »So across town I schlepped on the subway to the hardware store just to get this
That's the wrong one
txcoastal1 wrote: »honestaquarian wrote: »So across town I schlepped on the subway to the hardware store just to get this
Aaaaaaaaahhhhh shaddap ya bastahd! -
More glue done and second BlackHole5 strip installed. -
Ah, resealing the enclosures. Lots of funMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Hey when it comes time to install these........
How do you get around these?
And those when they are right next to the opening??
If you mean fitting the rings. They have a flat spot that goes next to the support. You may need a wood chisel to remove glue and maybe a little of the support.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
https://us.v-cdn.net/5021930/uploads/editor/5x/105knit7rg76.jpg
2.3TL's not the same as yours but some of the supports were close to the tweeter rings and needed some tweaking.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Thanks @machone
Exactly what kind of tweeking did you have to do? -
If you look close at the photo (zoom in) the corners next to the tweeter rings have been removed. I used a wood chisel.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Don't use a wood chisel on the support only the excess glue, instead cut the ring itself if necessary.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Yes, probably the best way to provide clearance.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Thanks guys
Problem is I ain't got no table saw or any such tools as I'm doing this in my living room. -
I had good success with metal snips.
I FOUND IT !!
I KNEW I had some leftover Dynamat lying around here somewhere. -
That's not the Xtreme version. I wouldn't use the original in my gear.Political Correctness'.........defined
