SDA upgrade thread 2
13567…10
  • honestaquarian
    honestaquarian Posts: 3,275
    I am honored to have THE MAN HIMSELF @DarqueKnight chime in on my upgrade thread B)
    Thank you sir!
    Where is the best place to get some Dynamat btw? I totally forgot.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    I've always bought mine at Amazon.
    https://www.amazon.com/Dynamat-10435-Self-Adhesive-Deadener-Xtreme/dp/B00020CAUG/ref=sr_1_5?ie=UTF8&qid=1489099557&sr=8-5&keywords=dynamat
    If that is too much, they have smaller sizes available.
  • honestaquarian
    Thank you sir
    You're right it is too much. Hey doesn't Best Buy carry this stuff in store?
  • Nightfall
    Nightfall Posts: 10,083
    Go to the back of the BB building and ask the car stereo installation people if they have some scraps you could have or buy.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • honestaquarian
    Okay now the wiring goes to @vr3 for my crossover upgrades
  • honestaquarian
    Hey just curious
    Do Larry's rings @Toolfan66 get glued into place or just pressed in?
  • honestaquarian
    F1nut Posts: 52,382
    Pressed in.
  • honestaquarian
    Pressed in.
    What size drill bits do you use to enlarge the screw holes?
  • monepolk
    monepolk Posts: 1,154
    If you're like me it will be the one size you don't have 9/32.
  • honestaquarian
    edited March 2017
    monepolk wrote: »
    @monepolk
    I'll be damned if you didn't hit the nail RIGHT ON THE FARGON HEAD!!!
    Well back to the bloody hardware store AGAIN
    txcoastal1 Posts: 13,520
    monepolk wrote: »
    @monepolk
    It's good for the economy, we call it trickle down economics
  • monepolk
    Yeah I have at least 3 drill bit sets and none of them contained that size bit :/
  • honestaquarian
    So across town I schlepped on the subway to the hardware store just to get this
    That's the wrong one :)
  • honestaquarian
    txcoastal1 wrote: »
    Aaaaaaaaahhhhh shaddap ya bastahd! :(:p
  • honestaquarian
    More glue done and second BlackHole5 strip installed.
  • honestaquarian
  • machone
    machone Posts: 1,586
    Ah, resealing the enclosures. Lots of fun :#
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • honestaquarian
    Hey when it comes time to install these........
    How do you get around these?
  • machone
    If you mean fitting the rings. They have a flat spot that goes next to the support. You may need a wood chisel to remove glue and maybe a little of the support.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    https://us.v-cdn.net/5021930/uploads/editor/5x/105knit7rg76.jpg
    2.3TL's not the same as yours but some of the supports were close to the tweeter rings and needed some tweaking.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • honestaquarian
    Thanks @machone
    Exactly what kind of tweeking did you have to do?
  • machone
    If you look close at the photo (zoom in) the corners next to the tweeter rings have been removed. I used a wood chisel.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Nightfall
    Don't use a wood chisel on the support only the excess glue, instead cut the ring itself if necessary.
    afterburnt wrote: »
  • machone
    Nightfall wrote: »
    Yes, probably the best way to provide clearance. :)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • honestaquarian
    machone wrote: »
    Nightfall wrote: »
    Thanks guys
    Problem is I ain't got no table saw or any such tools as I'm doing this in my living room.
  • monepolk
    I had good success with metal snips.
  • honestaquarian
    I FOUND IT !!
    I KNEW I had some leftover Dynamat lying around here somewhere. :)
    F1nut Posts: 52,382
    That's not the Xtreme version. I wouldn't use the original in my gear.
