Let's see it!
  • recoveryone
    2 channel setup in living room
  • genjivn
    genjivn Posts: 101
    sandworms wrote: »
    Like those sound diffusers. Did you make them?
  • genjivn
    genjivn Posts: 101
    edited January 2017
    Another 2-channel system upstairs. Open space helps taming the bass of LSI-25 quite a bit. To open up the upper range of those vifa tweeters, I use solid copper with silver coating RCA interconnects.
  • Joey_V
    Joey_V Posts: 8,606
    genjivn wrote: »
    Mighty clean system. I even like the details like the cable elevators
  • mikeyb128
    mikeyb128 Posts: 2,885
    ^^lego cable elevator
    2 channel:
    Theater:
  • halo
    halo Posts: 5,619
    New additions to the family, the Dynaudio Focus 260
  • mikeyb128
    ^^^sweeet!
    2 channel:
    Theater:
  • ukcolin99
    ukcolin99 Posts: 286
    Thanks to halo for starting this thread, HNY to all, I love looking at people's set ups.
    Regular viewers will recall I used to have a but* ugly 6ft high metal shelf unit, now I have but* ugly 3ft high metal shelf unit.
    Sneaking in a question, pretty sure I reconnected all the components same as they were, only difference I used XLR cables balanced output from the 851D into the P5 vs Morpheus Ref Series II RCA. Would that cable change reduce the volume to the listener sitting same distance, same angle, same toe. I have plenty of power, seems I am having to turn up the volume, or I'm getting deafer..as always wit & wisdom appreciated.
    F1nut Posts: 52,406
    mikeyb128 wrote: »
    Do they come in black?
    F1nut Posts: 52,406
    ukcolin99 wrote: »
    Are those pieces truly balanced or so they simply have balanced connections? Are the new XLR cables the same brand/level of the RCA cables they replaced?
  • Nightfall
    Nightfall Posts: 10,083
    @ukcolin99 please tell me you don't turn on that Xbox with the PS4 completely covering its fan like that.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • ukcolin99
    Thanks F1, the XLR cables are cheaper, cables.com I believe. Gonna switch back to the RCA's thinking I'll hear a difference-suspect sounds may be tinnier with the XLRs. Nf no worries, my son dropped off his Xb so I stashed it. Gonna tidy up soon, I only play NfS on Ps4 no other games.
  • genjivn
    genjivn Posts: 101
    ukcolin99
    The Parasound combo looks so slick. Never heard the P5 but it looks so nice with the A21. I have had my eyes on the P5 for a while.
    I bought XLR cable from chromaleaf. You may want to check them out. Their XLR cables use Canare/Mogami/Sommer terminated with Neutrik. Decent price too.
  • GlennDog
    GlennDog Posts: 3,158
    This morning I received a pair of Dynaudio Contour S 3.4 LE's and rolled them into the mix.
    Hey Mike, nice set-up!
    Was wonder'n if you ever had a chance to audition the Salks and . . .
    How do the Contours pair with the Rogue M-180s ?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • mikeyb128
    GlennDog wrote: »
    I love that setup! Looks even better with the dyns in place
    2 channel:
    Theater:
    txcoastal1 Posts: 13,520
    GlennDog wrote: »
    I can't answer about the Rogue, but my first encounter with the Dyn's was the S1.4 and a Primaluna Integrated. The combo produced a very holographic sound, I've been hooked on Dyns ever since.
    F1nut Posts: 52,406
    ukcolin99 wrote: »
    Ok, usually the XLR output will be higher than the RCA. That said, any real benefit from using XLR cables is negated if the circuits in the gear are not truly balanced. I seriously doubt the Cambridge is and I'd be surprised if the Parasound is.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    GlennDog wrote: »
    Glenn, I didn't have the opportunity to get an ear on any Salk's. I was also kinda bummed about the 3-4 month lead time on getting a pair built.
    I did make the trip to a Dynaudio Dealer and auditioned the new Contour 30's (the new replacement for the 3.4's) and was very impressed with their presentation and their tone.
    The new Contours are exceptional in every way, but at a price, one that I couldn't afford. So, I opted for a NOS pair of the S 34 LE's instead. The Dyn's literally disappear, and throw a very realistic stage.
    Paired with the M-180's the 3.4's are revealing without being bright or fatiguing in any way, detailed yet smooth as Buttah. I love the Dyn sound and will enjoy them for some time to come!
  • footwedge
    footwedge Posts: 475
    ukcolin99 wrote: »
    I learned something today which is always a good thing.
    I assumed if a unit had xlr out/inputs it was balanced. So @F1nut, how does one determine if a unit is truly balanced?
    F1nut Posts: 52,406
    Read the literature and if the answer isn't there, ask the manufacturer. You're looking for the term fully balanced.
  • ukcolin99
    Thank you gj, very pleased with the A21, P5 is great for analog (not digital), I use the 851 as a DAC into the P5. F1 and/or tonyb guided to Pre-amp enjoyment.
    My but* ugly shelves (that I love) combine 2 channel & HT components, little messy but very efficient for viewing & listening.
  • halo
    halo Posts: 5,619
    ukcolin99 wrote: »
    I find that I like the built-in DAC in the P5 but that could be the synergy in my setup. I tried out the Rotel RDD-1580 DAC in my setup and I actually preferred the DAC in the P5.
  • GlennDog
    GlennDog wrote: »
    I Know! I placed an order for a sub on Oct 5th hoping to have it by Turkey Day . . .
    Jim said closer to X-mas!
    I'm still waiting
    "Paired with the M-180's the 3.4's are revealing without being bright or fatiguing in any way, detailed yet smooth as Buttah. I love the Dyn sound and will enjoy them for some time to come!"
    Your advise has been spot-on so far, so Ill make a point to visit the only dealer here in Mich
    Enjoy the Tunes!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    GlennDog wrote: »
    GlennDog wrote: »
    I'm still waiting
    Enjoy the Tunes!
    Just an FYI- I purchased my DynC4's from Hanson AV (Ohio) because I didn't like the Dyn dealer here in Texas...Hanson was great to deal with a got a real nice price. They will also sell you demo stuff.
    Cheers Guys
    http://www.hansonav.com/
  • Mike Reeter
    GlennDog wrote: »
    GlennDog wrote: »
    I'm still waiting
    Enjoy the Tunes!
    The Salk's have to be an exceptional line, Jim has built a very good business on the delivery of "Perfection". You can't rush that concept.
    I listened to Some Revel F208's, KEF R900's, a couple of Focal models and some Klipsch towers. To my ears the Dynaudio had the edge in "Holographic Imaging", as mentioned in a previous post.
    I would recommend getting to a dealer, or a show that has the new Contour line and get your listen on.
    They could be described as a little "laid back", I think that's why they are such a good match up with the M-180's that can have a tendency to be a little "forward" in their presentation.
  • Mike Reeter
    txcoastal1 wrote: »
    GlennDog wrote: »
    I'm hooked also, the Dyn's are a very good match up with my gear and room, really enjoying their sound!
    mikeyb128 wrote: »
    GlennDog wrote: »
    Thanks! I spend a lot of time there, especially this time of year.
  • mikeyb128
    GlennDog wrote: »
    GlennDog wrote: »
    "the 3.4's are revealing without being bright or fatiguing in any way, detailed yet smooth as Buttah. I love the Dyn sound and will enjoy them for some time to come"
    This description almost matches how I feel about my focal electras. Most that have heard them in shops think they are a forward/bright speaker, but what they really need To do is listen to them with some tube gear in front of them.
    2 channel:
    Theater:
  • ukcolin99
    halo wrote: »
    ukcolin99 wrote: »
    Absolutely, took me a little while to realize this hobby (obsession) should be about what you love.
