Let's see it!
2 channel setup in living room
Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX -
Another 2-channel system upstairs. Open space helps taming the bass of LSI-25 quite a bit. To open up the upper range of those vifa tweeters, I use solid copper with silver coating RCA interconnects.
Mighty clean system. I even like the details like the cable elevatorsMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
^^lego cable elevator
2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
New additions to the family, the Dynaudio Focus 260
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
^^^sweeet!2 channel:
Theater:
Thanks to halo for starting this thread, HNY to all, I love looking at people's set ups.
Regular viewers will recall I used to have a but* ugly 6ft high metal shelf unit, now I have but* ugly 3ft high metal shelf unit.
Sneaking in a question, pretty sure I reconnected all the components same as they were, only difference I used XLR cables balanced output from the 851D into the P5 vs Morpheus Ref Series II RCA. Would that cable change reduce the volume to the listener sitting same distance, same angle, same toe. I have plenty of power, seems I am having to turn up the volume, or I'm getting deafer..as always wit & wisdom appreciated.
President of Club Polk -
no, but if you could find some of that fabled black paint...
Are those pieces truly balanced or so they simply have balanced connections? Are the new XLR cables the same brand/level of the RCA cables they replaced?Political Correctness'.........defined
@ukcolin99 please tell me you don't turn on that Xbox with the PS4 completely covering its fan like that.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Thanks F1, the XLR cables are cheaper, cables.com I believe. Gonna switch back to the RCA's thinking I'll hear a difference-suspect sounds may be tinnier with the XLRs. Nf no worries, my son dropped off his Xb so I stashed it. Gonna tidy up soon, I only play NfS on Ps4 no other games.
ukcolin99
The Parasound combo looks so slick. Never heard the P5 but it looks so nice with the A21. I have had my eyes on the P5 for a while.
I bought XLR cable from chromaleaf. You may want to check them out. Their XLR cables use Canare/Mogami/Sommer terminated with Neutrik. Decent price too.
Mike Reeter wrote: »This morning I received a pair of Dynaudio Contour S 3.4 LE's and rolled them into the mix.
Hey Mike, nice set-up!
Was wonder'n if you ever had a chance to audition the Salks and . . .
How do the Contours pair with the Rogue M-180s ?AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I love that setup! Looks even better with the dyns in place2 channel:
Theater:
I can't answer about the Rogue, but my first encounter with the Dyn's was the S1.4 and a Primaluna Integrated. The combo produced a very holographic sound, I've been hooked on Dyns ever since.
Ok, usually the XLR output will be higher than the RCA. That said, any real benefit from using XLR cables is negated if the circuits in the gear are not truly balanced. I seriously doubt the Cambridge is and I'd be surprised if the Parasound is.Political Correctness'.........defined
Glenn, I didn't have the opportunity to get an ear on any Salk's. I was also kinda bummed about the 3-4 month lead time on getting a pair built.
I did make the trip to a Dynaudio Dealer and auditioned the new Contour 30's (the new replacement for the 3.4's) and was very impressed with their presentation and their tone.
The new Contours are exceptional in every way, but at a price, one that I couldn't afford. So, I opted for a NOS pair of the S 34 LE's instead. The Dyn's literally disappear, and throw a very realistic stage.
Paired with the M-180's the 3.4's are revealing without being bright or fatiguing in any way, detailed yet smooth as Buttah. I love the Dyn sound and will enjoy them for some time to come!
I learned something today which is always a good thing.
I assumed if a unit had xlr out/inputs it was balanced. So @F1nut, how does one determine if a unit is truly balanced? -
Read the literature and if the answer isn't there, ask the manufacturer. You're looking for the term fully balanced.Political Correctness'.........defined
Thank you gj, very pleased with the A21, P5 is great for analog (not digital), I use the 851 as a DAC into the P5. F1 and/or tonyb guided to Pre-amp enjoyment.
My but* ugly shelves (that I love) combine 2 channel & HT components, little messy but very efficient for viewing & listening. -
I find that I like the built-in DAC in the P5 but that could be the synergy in my setup. I tried out the Rotel RDD-1580 DAC in my setup and I actually preferred the DAC in the P5.P5 is great for analog (not digital)
I Know! I placed an order for a sub on Oct 5th hoping to have it by Turkey Day . . .Mike Reeter wrote: »Mike Reeter wrote: »This morning I received a pair of Dynaudio Contour S 3.4 LE's and rolled them into the mix.
Jim said closer to X-mas!
I'm still waiting
"Paired with the M-180's the 3.4's are revealing without being bright or fatiguing in any way, detailed yet smooth as Buttah. I love the Dyn sound and will enjoy them for some time to come!"
Your advise has been spot-on so far, so Ill make a point to visit the only dealer here in Mich
Enjoy the Tunes!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
I'm still waiting
Enjoy the Tunes!
Just an FYI- I purchased my DynC4's from Hanson AV (Ohio) because I didn't like the Dyn dealer here in Texas...Hanson was great to deal with a got a real nice price. They will also sell you demo stuff.
Cheers Guys
http://www.hansonav.com/
I'm still waiting
Enjoy the Tunes!
The Salk's have to be an exceptional line, Jim has built a very good business on the delivery of "Perfection". You can't rush that concept.
I listened to Some Revel F208's, KEF R900's, a couple of Focal models and some Klipsch towers. To my ears the Dynaudio had the edge in "Holographic Imaging", as mentioned in a previous post.
I would recommend getting to a dealer, or a show that has the new Contour line and get your listen on.
They could be described as a little "laid back", I think that's why they are such a good match up with the M-180's that can have a tendency to be a little "forward" in their presentation.
txcoastal1 wrote: »Mike Reeter wrote: »This morning I received a pair of Dynaudio Contour S 3.4 LE's and rolled them into the mix.
I'm hooked also, the Dyn's are a very good match up with my gear and room, really enjoying their sound!Mike Reeter wrote: »This morning I received a pair of Dynaudio Contour S 3.4 LE's and rolled them into the mix.
Thanks! I spend a lot of time there, especially this time of year.
"the 3.4's are revealing without being bright or fatiguing in any way, detailed yet smooth as Buttah. I love the Dyn sound and will enjoy them for some time to come"
This description almost matches how I feel about my focal electras. Most that have heard them in shops think they are a forward/bright speaker, but what they really need To do is listen to them with some tube gear in front of them.2 channel:
Theater:
Absolutely, took me a little while to realize this hobby (obsession) should be about what you love.
