This joint needs some more vintage hifi
  • sucks2beme
    sucks2beme Posts: 5,701
    The AU-999 cleans up pretty well. It's mostly modular and you can pull
    all the cards and recap it pretty easily. There's also a mod from audiokarma
    that cleans up the preamp section nicely. It's just changing a few resistors to
    correct a design shortcoming. It also increases the clean power output 15-20 WPC.
  • codycatalist
    codycatalist Posts: 2,661
    This is my first and only turntable. Picked it up at a thrift store for $10, cleaned it up and put an Ortofon on it. It makes my Monitor 5s sing!
  • boston1450
    boston1450 Posts: 7,758
    Nightfall wrote: »
    @boston1450 That is too cool.
    i will post pictures when it is finished being restored. I was told its over 100 years old. But im not too sure
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • MrBuhl
    MrBuhl Posts: 2,419
    Whelp, pulled the 8" drivers from my son's BA A70's last night and got down to some serious Dynamat Action on the baskets, they really did ring like bells, solid "thunk" now...
    Also picked up some new binding post cups with better binding posts (replacing the spring terminals) to go along with my crossover refresh parts (new Mills MRA resistors and Sonicap Gen 1 caps). Can't wait to hear these babies.
    As you can see - I have a good use for the foam surround replacements that I picked up as well - these are slightly tired...
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • MrBuhl
    MrBuhl Posts: 2,419
    I hope DIY is still Vintage HiFi appropriate when working on monkey coffins - thought you all might enjoy the refurb of the Boston Acoustics A70's for my kid...
    First up tonight - driver surrounds... Clean and replace.
    Next up - Crossovers/Binding Post Cups as they are basically one in the same. Decided to make up my own stand alone crossovers vs. trying to make them fit the backs of the new binding post cups. Not pretty but functional (I hope!)
    Finished surrounds with trim installed.
    Monkey coffins set up awaiting full dry time on the surround adhesive on the stands that came with them. Pretty pleased for the $10 investment originally. Can't wait to hear them tomorrow!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • pumpkinman
    pumpkinman Posts: 10,431
    @MrBuhl
    Nice job :) hope your son appreciates your fine work.
    Because I am The Pumpkinking
  • [Deleted User]
    [Deleted User] Posts: 10,716
  • MrBuhl
    MrBuhl Posts: 2,419
    Thanks gents - and especially you @pumpkinman for the ideas, links, and nudges in the right direction! These things are burning a hole in my pocket waiting to put power to them!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • voltz
    voltz Posts: 5,384
    WTG ED! See all the life you put back into those speakers. B)
  • MrBuhl
    MrBuhl Posts: 2,419
    Thanks Darryl - maybe good for another 30 years! :)
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • pumpkinman
    @MrBuhl
    So is it soup yet ;)
  • highway_chile
    Very cool, Mr Buhl. I refoamed some A60's and A70 Series II's last fall. Same surrounds. I did not recap, though. They both sounded pretty nice afterwards.
    Power Amps: Luxman M-02, Luxman M-2000, Luxman M-300
    Preamps: Luxman CX-100, Luxman C-1010, Luxman C-120A
    Speakers: Polk Audio SDA-2B's (no mods...yet), Klipsch KG4's (Crites Crossovers and Titanium Tweeters), Genesis 1's
    Digital Front End: Marantz CD6005, Denon DVD-2200, Fiio X5 II
    Headphones: Sennheiser RS180, Sennheiser HDR170 w/Fiio E12 Montblanc (home). Sennheiser HD449 w/Fiio E12 Montblanc (portable)
    EQ: SAE 180 Parametric
    mhardy6647 Posts: 35,501
    Those ol' Boston Acoustics loudspeakers are pretty darned respectable, IMO.
  • MrBuhl
    MrBuhl Posts: 2,419
    edited May 2016
    Honestly, I'm shocked. And not even that I got the crossovers right :blush: but by how nice they sound. Burn in has commenced (via long play ipod with 1800 songs on it) but sitting here listening to the shuffle of songs they are really musical. It's a nice room filling sound.
    Imaging is pretty good - can locate specific instruments in the decently wide sound field. Bass for an 8" sealed is pretty good really, and the tweeters are nice and clear with good top end sparkle. Might tend a bit toward the bright end compared to my Polks right now (probably a combo of new Sonicap/Mills resistors burning in, the HK AVR, ipod source, & the lamp cord speaker cable) but they are overall really pleasing honestly.
    They seem to excel at good old rock-n-roll, he's going to love them I think. the HK came with a small powered HK sub, I can't help but think with that in the mix he's going to be very very pleased indeed - heck they sound plenty good enough without it! :smiley:
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • pumpkinman
    I just picked up a pair of Boston Acoustics A150's series 1 bad thing is that the woofers where replaced with junk from Radio Shack. Don't sound to bad but I want an original set of woofers.
  • MrBuhl
    MrBuhl Posts: 2,419
    I may look for another set of the larger ones for myself, if this is what the baby brothers sound like... well... I think the biggies must be heard!
    Beatles on right now - amazing!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • MrBuhl
    MrBuhl Posts: 2,419
    Check these out - hows that for vintage hi-fi!
    http://washingtondc.craigslist.org/nva/atq/5581608078.html
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • pumpkinman
    Can anyone help me out ?? The A150's have a 10" woofer but when I try to find the woofer specs on the net it's confusing. I've read both 4ohm and 8ohm for the woofer. On eBay there's a pair of refoamed woofers that claim 8ohm. Simply Speakers has an after market drop in replacement for $65 each but says it's 4ohm. I can't find anything from BA. any help would be appreciated.
  • pumpkinman
    Never mind I found exact replacements that were refoamed for $75. All is right with the world. :)
  • MrBuhl
    MrBuhl Posts: 2,419
    I'm imagining the A150's are the sweet spot in this lineup? Three-way and not overly large, 10" vs. the 8" in the A70, etc?
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • pumpkinman
    @MrBuhl
    I'll let you know what I think about the A150's. Right now I'd go with the A200's in my listening area. The A400's were to much speaker for my small-ish area. Next up I'd like to find a pair of A100's. If I find a pair of A100's I'll have all the Boston Acoustics I need. :)
  • boston1450
    edited May 2016
    ADS L300c w/brackets. Add a sub & they sound BIG fxm6xrio5axj.jpeg
    Post edited by boston1450 on
    Randy-Maine
    by David WMG
    ads minispeakers -- always in good taste (indoors or out)!
  • MrBuhl
    MrBuhl Posts: 2,419
    I have looked at several sets of a/d/s home speakers over the years, never heard them though. I take it they are worth a listen?
    I knew a guy that had them in his Jeep back in the 80's (with a Nakamichi car stereo as I recall) - I thought in the 80's that was as bad-**** as I had ever heard LOL.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    umm... in a word... yeah.
  • highway_chile
    highway_chile Posts: 37
    edited June 2016
    My latest acquisition: Luxman M-300. And yes, at 40wpc in Class A mode it seems to be feeding the SDA-2B's just fine. I'm not trying to blow the roof off because the wife is home, but I'm playing louder than I normally do when she's here and it's sounding quite nice.
  • Gunther16
    Gunther16 Posts: 243
    Holy crap this thread takes me back to my youth!
    edited June 2016
    Another (classic) flavor of coaxial driver: this is one of a pair of 12 inch, cast-frame Tannoy coaxial drivers temporarily removed from its natural habitat (a pair of 1970s Tannoy Devon loudspeakers).
    27385469892_510ff6c324_b.jpg005 by Mark Hardy, on Flickr
    27207647030_da2851b9d4_b.jpg016 by Mark Hardy, on Flickr
    In the UK, "Tannoy" is a generic term for loudspeakers (especially, and a bit unfairly, particularly of the public address kind) in the same way that "Kleenex" is generic for paper tissues.
    EDIT: This is what the innards of one of these drivers looks like:
  • pumpkinman
    While out and about today Cathy and I ended up in Adamstown, PA. While looking at antiques at Reddingers. I came across a pair of ADS L470's. After a little haggling I got them for $40.
  • lightman1
    lightman1 Posts: 10,800
    Gawd you suck, Bill!!
    Throw some of that shite luck my way. ;)
