Which would yield the better performance gain-high end interconnects or spk.wire?
Answers
  • OleBoot
    OleBoot Posts: 3,135
    lightman1 wrote: »
    OleBoot wrote: »
    afterburnt wrote: »
    I am a bit confused, what kind of hot dogs should I try?
    If you look at the nutritional information on the back of the pack, and it is similar, the hot dogs will taste exactly the same. I have never eaten a hot dog.
    Then you, sir, have no qualifications to to judge the finer points of hot dog consumption.
    Begone, Judas!
    Allegorical.
  • lightman1
    lightman1 Posts: 10,800
    OleBoot wrote: »
    lightman1 wrote: »
    OleBoot wrote: »
    afterburnt wrote: »
    Begone, Judas!
    Allegorical.
    Only to bee stings. But thanks for asking! ;)
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Well, it was only a matter of time. :s
  • motorhead43026
    motorhead43026 Posts: 4,067
    I like watching sausage being made.
  • ken brydson
    ken brydson Posts: 9,077
    afterburnt wrote: »
    Costco, $1.50 for a dog or polish and a pop. Best budget meal ever...
  • erniejade
    erniejade Posts: 6,321
    Vienna beef dogs for us Chicagoans.
    If your ears cant hear the difference, it might not be your equipment but your own ears. Im not trying to come across harsh but I do jave some friends that cannot hear the difference on cables or even preamps when others in the same room say the difference on this or that is dramatic.
    I'm not saying you don't have a point for yourself or for some that can't hear a difference but to make that type of generalization of there is no difference because good wire transfers the signa and should be colorless is crazy. Even the best of the best amp or pre even though it should have no color still has a flavor of the manufacturer. Same with wire. It shouldn't make a difference and pass through the signal but other factors come into play. Otherwise we would all be running 22 gauge rat shack wire.
    Now I want a freaking hotdog thanks. Im trying to get into bikini shape for the summer!
  • afterburnt
    afterburnt Posts: 7,892
    That reminds me I have to renew my membership and buy some big ticket item to justify it.
  • erniejade
    I knew my maker put me next to a portillos for a reason.
    F1nut Posts: 52,250
    You said sausage, I'm telling!
  • lightman1
    Sausage pie..... :o
  • ken brydson
    lightman1 wrote: »
    Sausage pie..... :o
    Ohhh, you're in BIG trouble now. A 2fer...
  • lightman1
    erniejade wrote: »
    I like Makers Mark. It's next to me now! >:)
  • K_M
    K_M Posts: 1,631
    erniejade wrote: »
    Back to the subject at hand.
    If you frequent many audio/sound/pro-sound/recording forums, you will find that every forum has a different take on this tired subject.
    He is saying, here is what Physics says, and here is what Blind test results are.
    Not sure if the burden of proof, lies on him really, or those saying they do hear meaningful changes?
  • afterburnt
    Those Boars Head are really good but those old style Hebrew Nationals were big fat juicy dogs!
  • Nightfall
    Nightfall Posts: 10,083
    If you're happy with your coat hangers, awesome. I like my new MIT StyleLines. Dim the lights, get comfortable, put on a record, and enjoy. That's all that really matters.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • machone
    machone Posts: 1,576
    I am happy with Wireworld IC's and 10ga Belden speaker cables for now.
    Next, I am going to spend my money on improving the acoustics in my listening room as I believe this is the best bang for the buck for my system.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • vmaxer
    vmaxer Posts: 5,121
    Me wants a hot dog too.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ken brydson
    vmaxer wrote: »
    Reported, I'm offended....
  • [Deleted User]
    "He is saying, here is what Physics says, and here is what Blind test results are."
    Which two do you want?
    Then you would agree that different metals have different conductive
    properties right?
  • ken brydson
    properties right?
    A blind physicist should have the bases covered, no?
  • vmaxer
    vmaxer Posts: 5,121
    vmaxer wrote: »
    Think I offended meself.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • lightman1
    F1nut Posts: 52,250
    It may be 1% to some, but they would be sadly mistaken.
  • Nightfall
    Going by MSRP...
    $1.5k speakers cables, $500 interconnects, $1k speakers, $1.2k preamp, $1.3k amp
    Don't look at it in percentages, look at your system as a whole. All of it matters.
    afterburnt wrote: »
    David7544 wrote: »
    Tony, yes your question was good. I didn't see it on my computer at first. Seems like there's a delay until posts appear when I'm online.
    You're right, I have not experimented with a lot of wires. I have tried a few. I don't hear any difference between wires.
    My experience has been that if I don't know which wire I'm listening to, there is no difference. My buddy demonstrated for me an expensive audioquest interconnect and a cheap monster interconnect without telling me which was which.
    I couldn't hear any difference.
    My opinion is based mostly on common sense.
    Thing is, digital audio is a binary number stream. There is no "sound quality". It's a sequence of ones and zeros. Ones and zeros are all the same, would you agree?
    No, I would not agree. While in theory the 1's and 0's are the same, it's the transfer and converting to analog that makes a difference. We weren't even talking digital cables, just analog.
    Your analogy of a cable being defective if it sounds like something is wrong. Some suggest that if a cable transfers a signal from point A to point B, their is nothing more it can do. By the same token, do all cdp's sound the same, all blu-ray players look the same, all speakers sound the same ?
    Of course not, different parts used, different designs and build quality, many variables go into making one product sound different than another. Cables are no different.
    Cables are one of those things that everyone argues over. Mainly between those with experience with various brands and price points and those without. It's one of those things that you have to experience before passing judgment. The best way to do that is get yourself to a Polk get together in your neck of the woods. I can tell you in all honesty, that many here thought as you did, then they had an ah-ha moment in their journey and never looked back.
    Audio is one of discovery, a constant learning and listening experience. Don't limit your knowledge with others who have no intentions of discovering anything.
  • K_M
    K_M Posts: 1,631
    tonyb wrote: »
    David7544 wrote: »
    Respectfully disagree.
    The debate is far simpler! <3
    Person "XYZ" makes a claim that is unsubstantiated, on an audio internet forum.
    Person "ZYX" Says that without more in depth proof, the claim does not hold a lot of water"
    Person "XWZ" then goes on a "Internet Tirade" about how they know for sure what they hear is real, person ZYX must bad hearing, unable to hear what they hear, or having mediocre equipment that is unable to showcase the differences, or simply are a hater, troll, a non believer, or worse.....
    Sound Familiar?
    It is internet bickering at it's simplest. Nothing more.
    ....and I would respectfully disagree. Simply way too many variables for blanket statements and when asked about details all you get is crickets.
    The devil is always in the details, which naysayers are always willing to leave out. Sometimes it is indeed their gear is simply not revealing, hearing compromised, or lack of training to even know what they are listening for. Sometimes even, the source material is MP3's and the listening environment is casual, in which case most anything won't make too much a difference under those conditions.
    We all hear differently no doubt, and seemingly won't admit we lose some as we age. Ask my wife, she'll tell ya about my selective hearing.
    Audio is not a glove that fits everyones needs, not a one size fits all thing. That's why we have such a variety of gear, speakers, and yes....cables. You can't justify a stance with blanket statements for all to adhere to.
  • Jimbo18
    Jimbo18 Posts: 2,351
    The movie Somm is about a small group of people trying out for the title of Master Sommelier. There is an extremely difficult taste test as well as written exams. Anyone can read the source materials and study for the written exams, and potentially pass them. But the tasting is where the real test begins.
    Everyones tastes are different, but it was amazing to see how many of the applicants separately described a wine, in a blind taste test, with the exactly the same adjectives. One of them was asked how they could use terms like "tastes like laurel petals" or "tastes like new leather and juniper berries". Their answer was that you can only describe it that way if you have tasted every one of those things.
    Just trying to use this to possibly illustrate @tonyb 's point above. I can enjoy wine as it is, but my examples of the flavors and aroma are limited to those I have experienced.
  • tratliff
    tratliff Posts: 1,862
    David7544 wrote: »
    tratliff wrote: »
    David7544 wrote: »
    I've been an audiophile for 40 years, and I can't think of any scientific reason why separate amp/pre should sound better than a good AVR. Or why my system sometimes sounds real good and sometimes it sounds like crap. Unlistenable crap. I suspect there is a lot more going on in our heads than we think, or are aware of. This is why differences in sound quality tend to disappear in blind testing. Also humans have poor auditory memory. Our visual memory is good, but we have almost zero auditory memory. Iv'e tried to compare CD to SACD by playing each one after the other, and my brain just can't do it. I suspect that those who claim to hear a difference are simply not aware of their own preconception bias. But maybe their ears are better than mine. I still love gear, and my next purchase is gonna be Martin Logan electrostatics. Maybe the superior resolution of the new speakers will reveal these differences in sound quality? My current ones are Polk Rtia5's. Also I wan't to order a Marantz reference integrated. Is anyone here familiar with this amp?
    This one is also pretty classic. From discussion:
    http://forum.polkaudio.com/discussion/comment/2181795/#Comment_2181795
    My work here is done. I will sit back and watch for now. Good times....
    and......your point was what?
    David, my point was that your level of experience as an audiophile shines thru in the previous posts and discussions.
    You stated that you have limited time in researching and testing different cables. Your opinion was made up pretty quickly.
    The forum has been down this discussion path many times. Check previous post and you will see. Majority of the time it is a member with limited knowledge that questions, or states as fact, that cables are just cables.
    I suggest offering your opinion but back it up with the facts available. Not just make blanket statements that are unsupported. Many on this site will try to help guide you thru the journey.
    I try not to participate in the cable discussions but one thing is for sure. I could see where this was going yesterday when I made my posts.
