Parasound vs Emotiva
245678
  • vmaxer wrote: »
    Emotiva is in a different league, entry level at best. Yes, I have owned one and anything & everything I have had since beat it to death for music.
    I guess we have different experiences.
  • lightman1
    lightman1 Posts: 10,796
    edited November 2015
    Some mornings my my prostate feels right for an unobstructed bladder evacuation. Most mornings it just doesn't seem to work.
    Audio. The same... Depends on me.
    I feel like I have to take a Capri now.
    tonyb Posts: 33,072
    lightman1 wrote: »
    I need a Captain Crunch decoder ring for that one Russ...lmao
    nooshinjohn Posts: 25,916
    vmaxer wrote: »
    Or better hearing... o:)
    I thought the amp didn't matter until I tried one. Then I just built my own. The amp makes as much difference as everything else in the setup does. Every piece matters.
  • vmaxer
    vmaxer Posts: 5,120
    vmaxer wrote: »
    Spot on dude.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer wrote: »
    So you're saying that you can build a better amp than the engineers at emotiva, or ATI. Come on man...you all have to a least acknowledge that a 73lb mono's with a 60w class A designed in TN is in the same class as any other $2000 amp.
    I know your not that naive.
    txcoastal1 Posts: 13,512
    vmaxer wrote: »
    WOW you're going to be in for a big surprise....John show him, this is gonna be funny
  • vmaxer
    vmaxer Posts: 5,120
    txcoastal1 wrote: »
    vmaxer wrote: »
    Yes it will be super funny, go John.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • lightman1
    John..... Show him what you have done with an amp.
  • I'm only having fun here fellas. I never said amps don't matter, if I thought that I would be using an rxv371 still. But I am saying Emotiva is the best for the money, new with a warranty. I firmly believe I couldn't have gotten better for $2000 new with warrenty.
  • BlueFox
    BlueFox Posts: 15,251
    Is Emotiva still in business? I haven't seen any ads for a while, and newbies aren't showing up saying they now have a high-end stereo as good as any other stereo.
  • ken brydson
    ken brydson Posts: 9,002
    BlueFox wrote: »
    They're making 8 tracks now. Didn't you hear?
  • gumbay13
    gumbay13 Posts: 360
    slbenz wrote: »
    [quoteThanks for sharing your insight between the two!
    As i contemplate between Rotel, Parasound and Emotiva for my next audio outlay in the coming months, this certainly helps!
    Having owned all three, here is what I experienced with my Magnepans: Emotiva XPA-5 has lots of power, is the brightest of the three and has a more upfront sound stage than the other two. Parasound HCA-1205A is warm, has a deeper sound stage than the Emotiva but less than the Rotel. Instruments and voice sound more realistic than the Emotiva. Rotel RMB-1565 has a similar deep sound stage as the Parasound. Brightness/warmth is between the Emotiva and Parasound and is very neutral. Instruments and voice sound slightly more realistic than the Parasound.
    Disclosure: I liked the Parasound and owned it for over ten years as its original owner. I did have one channel go out but was repaired under warranty. Currently using the Rotel and like it as well. Especially since it is a Class D amp and doesn't generate near the amount of heat my Parasound (most) nor the Emotiva did since I use an enclosed cabinet.
    [/quote]
    Thanks for taking the time to share your experience with them.
    As subjective as this hobby can be , this is still very useful info.
    AMP/Pre Pro: Outlaw 7000x, Marantz AV7703
    Speakers: Fronts:LSiM 705s/ Center: LSiM 706c / Surrounds: LSim 703s
    SUB: Rythmik LV12R x2
    Source:OPPO UDP-203
  • Its ok I used to drink the Emotiva cool-aid.
    Polk SDA 1C Upgraded, Eastern Electric Minimax Supreme DAC, Parasound HCA 1200ii, Belles 21a Preamp, Rotel RSX-1056, Matricom G Box Q, Blue Jean & Signal Cable interconnects, Sonographe SG-3 TT, Panamax M4300-PM
    F1nut Posts: 51,756
    Seriously!?!
    WAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    txcoastal1 wrote: »
    vmaxer wrote: »
    Yes... I am saying that. 400 plus watts of Carver designed tube power smokes anything Emotiva has to offer. That is why Big Dan bought the company Bob built when they were thinking about doing high end tube stuff. Thankfully the deal went south... 8o7sbj1cci96.jpg
    Those that have heard them consider them to be among the best they have ever heard.
  • No it's okay...I would upset too if I couldn't sell my overpriced used gear at top dollar cause some company decided to be realistic. WAAAAAAA
  • So beautiful :'(
  • txcoastal1 wrote: »
    vmaxer wrote: »
    Those are pretty impressive, but my point still stands.
    txcoastal1 wrote: »
    vmaxer wrote: »
    Dan couldn't do anything close. That's why he tried to buy Bob out. Your point is about as valid as the claim that God Himself could not sink the Titanic.
  • Show me the 600w mono you built with a 60w class A, with balanced inputs, circuit protection, and 30lb toroidal tranny. Come on tube amps been diy projects for decades.
    Get me the schematic and I will build a better one. It would not be that hard to do.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Improving on someone else's design isn't doing anything. The engineering team can always do better, but they have a cost margin to consider. My point stands. You claim to know more than a team of engineers, at two respectable companies, but yet you need their drawings.
    I respect your accomplishments, don't get me wrong, but your claim is outrageous.
    Why reinvent the wheel? You guys all seem to be under the delusion that all amps sound the same anyway.
  • Straw man diversion. If one can no longer support their argument, one attempts to minimize the credibility of the opponent.
    It's okay
  • skrol
    skrol Posts: 3,449
    Can you feel the Parasound Love! With all the good press Parasound get around here, they should give us all a nice discount... or at least free T-Shirts.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    vmaxer wrote: »
    1st, you asked if John could build a better amp, he's built one and he answered
    2nd, You answered your the question to your own statement
  • lightman1
    Who wants to set the point spread between John and Jerry. $50 in here, double down on John.
  • BlueFox
    What is the issue here? Wasn't it that the Parasound sounds better than the Emotiva? Then it seemed to have morphed into an old Emotiva is the best, and anything else is a waste of money thread.
    While I have never heard the Emotiva amps, I would have no problem buying one for a starter system. For most people, it is probably more than they will ever need. Of course, there is always something better, and that is where music stops, and the hobby starts. :)
  • Is that it?
    I'm not going to debate semantics or fight to support my previous claims taken out of context
