Warm up time or is it my ears?
These 707s have certainly opened up with some time one them but it sure seem like I don't like what I hear from them for almost the first hour of letting them play. what the hell is wrong with me? Wait that is another conversation lol. Should stuff take that long to warm up???
«13456
  • mikeyb128
    mikeyb128 Posts: 2,885
    I honestly feel that both my systems don't start sounding there best for about 2 hours. The longer they are on, the better they sound. I have 705's in my main system. Bought in April of this year, they keep sounding better and better, I haven't done anything special to break them in, just using them, not leaving them on all day for the dogs. Been thinking about running them for a week straight to see what happens.
    2 channel:
    Theater:
    nooshinjohn Posts: 25,928
    My amps need at least an hour of idle time before I sit in the sweet spot
  • afterburnt
    afterburnt Posts: 7,892
    Funny I run my gear for the dog too lol. Anyway the last memory of the sound kinda blows compared to the first memory of the last listening session. I am becoming too much of a curmudgeon about my own stuff lol.
  • afterburnt
    I guess it makes sense since I have been running Playschool gear to start out. this is too much fun and too damned expensive, but what the hell I am enjoying it lol
    F1nut Posts: 51,786
    afterburnt wrote: »
    I get the impression you power up your gear just before listening, so try this instead. Leave all the gear powered up while you are at work, sleeping or whatever you do when not listening. That way when you are ready for the next listening session you should be able to tell if it is gear warm up time or your ears.
    I agree with Jesse, but if you are running tube amps, it may not be practical to do that. I could watch my power meter roll if I left my amps on all the time.
  • afterburnt
    No tubes here. I turned everthing on when I got up this morning then reflexively turn them off as I walked out the door duh lol
  • fmw
    fmw Posts: 90
    afterburnt wrote: »
    You could tell if you compared two identical systems side by side. But it isn't possible to remember sonic characteristics through a work day. Hearing bias, on the other hand, can convince you that hear nearly anything.
    F1nut Posts: 51,786
    fmw wrote: »
    If you truly believe that I suggest you get rid of whatever audio system you have. I mean, it's obvious you can't be sure of what you're hearing, so why bother.
  • fmw
    fmw Posts: 90
    Sorry but I know exactly what I can and cannot hear. I spent two years doing bias controlled comparisons. Since you don't know what I can and can't hear a better comment would be that you disagree with me. That would make sense since you have never done a bias controlled comparison.
    F1nut Posts: 51,786
    Ummmm....you just told us that you can't trust YOUR ears. Hello!
    Yet, you're going to tell the collective what they can or can't hear? LMAO!!!
  • fmw
    fmw Posts: 90
    Not at all. I am simply explaining why you hear what you year. Just say you don't disagree. Attacking me won't change the truth.
    F1nut Posts: 51,786
    Your truth is not my truth, so don't try to push your thoughts on the matter on me or others.
    BTW, I'm not attacking you. I'm pointing out the problems with your blanket statements.
  • BlueFox
    BlueFox Posts: 15,251
    fmw wrote: »
    afterburnt wrote: »
    Great, another troll throwing out opinion as fact, and knows more than anyone else.
    tonyb Posts: 33,072
    fmw wrote: »
    [it isn't possible to remember sonic characteristics through a work day. .
    Maybe if you have Alzheimer's, because I can remember sonic characteristics of pieces I've heard from years ago. My house/car keys is another matter.
  • fmw
    fmw Posts: 90
    Rudeness and insults are the methodology here, it appears. Very sad. Anybody up for a bet?
    tonyb Posts: 33,072
    Sure, I'm a gambling man, whats the bet ?
  • fmw
    fmw Posts: 90
    The bet. We set up two identical systems. We test them with a bias controlled comparison to ensure they sound the same. We allow one to warm up all day and the other one for 10 minutes. Then we repeat the bias controlled test. If you can identify a difference, you get $5000. If you can't, I get $5000.
    I have never tested this concept before so I am applying common sense to the issue. I did do a bias controlled test of speaker "break-in" once. We compare a pair B&W Matrix 801 speakers a dealer had had on demo for about three months to a brand new pair he unboxed to deliver to a customer. None of the 5 testers was able to distinguish between the two pairs.
    I'm betting $5000 warm up of electronic audio gear will go the same way. Do you know where we can find two identical systems in the same room that can be switched to play through the same speakers?
  • polrbehr
    polrbehr Posts: 2,842
    Only if the test is carried out with Ethernet cables... paging @ZLTFUL :)
    tonyb Posts: 33,072
    fmw wrote: »
    I'm betting you can't get 2 separate systems in the same room with the same placement in that room on the exact same gear and cables.
    BTW....who were these 5 testers ? Did they even know what they were listening for, or were they just friends with a passive interest ?
    Your premise is that nobody should be able to hear a difference because to you they don't exist. Because they don't exist to you, then they don't exist to anyone else. Sound logical to you ? If that's how you approach audio in general, your going to be stuck in the mud where your at.
  • fmw
    fmw Posts: 90
    ZLTFUL wrote: »
    fmw wrote: »
    Merely stating a fact. It was not meant to be rude or insulting in any way. No need to get defensive if you have chosen to cast your lot in with a known schizophrenic sociopath. (jinjuku and habanero are quite literally the same person...and he has conversations with himself/agreeing with himself. If that isn't a sign of severe mental illness then cables don't matter).
    Apparently you don't have the ability to detect rudeness and insults. You did it again. In a back handed way you referred to me as schizophrenic sociopath. I don't know these people but I can assure you haven't cast my lot with anyone, let alone schizophrenic sociopath. I'm not a member of your faithful so attack away. It doesn't really matter to me and it makes you look bad.
  • BlueFox
    I will take the bet. Duplicate the gear in my sig and we will set it up on the wall opposite my current setup. Then using my office chair I can be spun around to face one setup or the other. Of course you will have to pay for the gear, and the three additional 20 amp lines required. At least you will have a nice stereo at the end of the test, but be $5000 poorer. I get to keep the additional 20 amps lines.
    My setup sounds much better after being on 48 hours compared to just being turned on.
  • polrbehr
    fmw wrote: »
    ZLTFUL wrote: »
    fmw wrote: »
    There is no faithful here. Other than a (reasonable?) expectation for people to discover on their own whether there are differences, subtle or not, in what they hear with their own ears in their own audio systems. With different pieces of gear, speaker placement, and on and on it goes; not something you read somewhere or heard about.
    It's just a hobby, it's supposed to be enjoyable, and finding out things you didn't know existed is part of that enjoyment.
    F1nut Posts: 51,786
    fmw wrote: »
    The bet.
    Typical naysayer BS. Throw out a challenge that you know isn't going to happen for any number of reasons and then say, but nobody took my bet. It's a pathetic desperation move on your part.
    Rude and insulting? Yes indeed, all of your posts have been, so stop trying to spin it around. You're not that good, not even close.
  • afterburnt
    holy cow, what happened here?
  • afterburnt
    I tried a cold start and a 2 hour warm up. I am not sure I could tell the difference however once I ran higher volume and then backed it off a bit it sure seemed like these 707s played more to my liking. I sort of think that simply leaving my equipment on with nothing playing did not make as much of a difference as warming things up with a load. I don't want to belabour the point but so far playing the same track I can tell that these speakers need to run a bit on higher volume before they start to open up which was not the case with the Monitor 70s as the fronts.
    I am lactose intolerant so I have a cow bias but I don't think my ears are lying to me.
  • afterburnt
    BTW the bottoms that these 707s kick leaves no need for a sub
  • Keiko wrote: »
    Obi Gyn juju has taught him well.
    Obi-Jin juku was a fool, and weak minded like his master. I sense a disturbance in the Force. A presence I've not felt since...................
    F1nut Posts: 51,786
    Makes perfect sense, the 707's are a larger speaker with more drivers.
    F1nut Posts: 51,786
    WAAAAAAAAAAAAAAAAAAAA
