Bi-Wiring, what exactly is it doing?
123468
    tonyb Posts: 33,072
    Kevin, sorry pal....you couldn't be more wrong about so much. I get you did your tests years ago and no differences were heard. Normally I'd let that slide and say well ok then, they don't matter to YOU. However, if you can name these cables and the gear it was used on along with speakers, we'd appreciate it.
    Even if they don't matter to YOU, doesn't mean that everyone else has to hear what Kevin hears.
    I also don't subscribe to this "pass the signal unaltered" stuff. Everything alters the signal to some degree, for better or worse. That's why pre amps don't all sound the same, speakers, amps, cdp's, cables, dacs....you name it. It also doesn't matter either, as everyone will buy what suits their own preferences. Piecing together all the different sound signatures or characteristics is called synergy, has absolutely zero to do with passing a signal unaltered as we all play to our own personal preferences.
    If cables didn't matter, I'm guessing your using all monoprice stuff ? If not, why not ? Or are all their cables somehow broken ? I won't even get into the different sound signatures of metallurgy. Make up a couple sets of IC's using the same plugs on each. Make up pairs with copper, silver, brass, aluminum....gold may be too expensive, and tell me you can't hear a difference.
  • tratliff
    tratliff Posts: 1,784
    I have watched this thread grow for the past couple of weeks. Really funny and laughable. If you don't see the need to spend excessively on cables then be happy with the ones you have.
    I feel that cables are an extension of the complete system. My cables represent an expenditure of about 25% of my system. With the investment being made I do not find that out of the question.
    I would also like to understand the equipment that was used in this blind test. But my expectation of the list would be a system that cannot resolve to the level needed to tell the difference.
    If you would like you can come visit my system and exchange the SC's. I have 3 sets. One set of Doug bi-amp/bi-wires, a set of AQ and a set of monster. You change them out as you feel and I bet $100, on each set, I can tell you which ones are connected.
  • vmaxer
    vmaxer Posts: 5,120
    tratliff wrote: »
    Bingo!!
    There was a time that I couldn't really tell a difference, but the more I have upgraded my equipment the more difference cables make. I am not talking slight differences either.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • tratliff
    Kevin. So let's make sure I read your post correctly. You said they could make a "tiny" difference. Correct??
    If that is correct then I can hear the difference on my system as stated by you. That is exactly what is being discussed. With the investment I have made and the extremes I go to for better results I will continue to travel down the road to better cables when I think the investment is necessary.
    We can state opinions all day but until you provide sufficient information to back up your claims I will continue to shake my head every time you make a response.
  • headrott
    headrott Posts: 5,496
    headrott wrote: »
    kevintomb wrote: »
    Disagree.
    The best cable is one that transfers a signal fully intact.
    kevintomb wrote: »
    Yes, actually the WHOLE object is to pass a signal unaltered, when dealing with speaker cables. It is not a purest mentality, but a logical mentality. Cables do nothing more than "Pass a signal"
    There is no audio cable in existance (created with the technology we posess) that will pass an audio signal (made up of electricity) fully intact. There will be degredation to the signal no matter what wire (brand, metal(s), dialectric, configuration, and termination) is used. This includes both analog and digital cables.
    That said, different cable configurations (geometry), dialectrics, metal(s), and terminations can degrade the signal less (or more). With lower degredation, the better the audio that ends up at your speakers, amp, DAC, pre-amp, etc.
    This is why some cables sound better than others.
    I should clarify (in reading back my post) that when I say fully intact, I mean completely unaltered. All electric signals are altered going through any wire in existance. Hopefully, that is more clearly stated.
  • headrott
    kevintomb wrote: »
    You guys are completely missing the point.
    What I think, what comparison I did several years ago, and what my friends thought, none of that matters. What equipment I used, AND subsequently they used to do the same comparisons, none of that matters.
    Those are just tests, fun and frustrating.
    But what matters is reality. Subjective impressions and tests are fine, but they do not always predict reality. Reality is what matters.
    No one is saying exactly "Cables do not matter", but something even simpler and totally based in reality, science and simple electronics.
    They matter immensely to conducing the signal from amp to speaker, but beyond that, the actual choices made as far as MOST amp and speaker combos, and the short lengths we mostly use, and the very fact that we are dealing with fairly low audio frequencies, determines what amount of interaction they CAN have.
    Those factors limit the inherent interaction.
    Nothing to do with me, nor what 15 other guys on a forum say, nor what a cable ad says, or even what we wish or hope they might do or change.
    It is not a battle of "Naysayers" versus "Believers", or "Haters of cables" versus "Those that love them".
    The ideal connection would be a speaker with the amp output hooked right to the speaker input. That would eliminate all cable degradation.
    The problem is, that ideal connection in reality, is not much better than even a mediocre cable can provide. Therefore, there are only tiny gains to be made.
    We are barking up the wrong tree.
    The reality is, you are missing the point and trying to pass it off onto us. ALL cables degrade the sound passed from one component to another. Some cables dgrade the audio less than others. That is the reality (and the point). The lower the degredation factor, the more improved the audio will become. The greater or lesser degree of degredation is/are the reason for differences in audio cables (for both analog and digital cables).
    Perhaps the electronics involved in audio is not as "simple" as you perceive them to be.
  • BlueFox
    BlueFox Posts: 15,251
    headrott wrote: »
    And when it occurs in every cable thread, and over and over in the same thread, it is called 'Trolling'.
    F1nut Posts: 51,763
    Tony said it best, "you couldn't be more wrong about so much"
    You are barking up the wrong forum.
    nooshinjohn Posts: 25,917
    DSkip wrote: »
    Others on this forum are in the same boat. Don't be mistaken - we can eliminate bias. Hell, most of us can probably tell you a handful of differences between the cables.
    I eliminated bias by placing the biased on ignore...
    F1nut Posts: 51,763
    LMAO
    tonyb Posts: 33,072
    xcapri79 wrote: »
    DSkip wrote: »
    Now that's biased, don't you think?!
    Nope, that's called preference. ;)
  • tratliff
    edited June 2015
    kevintomb wrote: »
    Pointless to talk logic basically.
    Yep, pointless
    Post edited by tratliff on
  • vcwatkins
    vcwatkins Posts: 1,993
    kevintomb wrote: »
    Nor will I even bother going down the road about my cable tests I did years ago.
    Why not share the info? I'd be very interested to see details. Is it posted elsewhere?
  • vc69
    vc69 Posts: 2,500
    edited June 2015
    You guys would be horrified to know what I am using for speaker cable right now.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
    vcwatkins wrote: »
    kevintomb wrote: »
    He cant post what he has never done, and it's too much work to do to cover up his lies.
  • BlueFox
    edited June 2015
    kevintomb wrote: »
    tratliff wrote: »
    Tiny difference...correct.
    I have made no "Claims". Nor will I even bother going down the road about my cable tests I did years ago.
    I realize some are simply happy believing what they believe, and simply do not want to know or hear the truth.
    Anyone with even the simplest knowledge of basic electronics, and speakers and audio realize the speaker cable thing, is a dead end. A non issue mostly.
    Attacking my credibility, along with other forum members, simply shows a lack of a real argument.
    As far as providing more information. I will decline. I see where ALL these "Audio Myth" debates go.
    First attack the messenger directly, then attack their hearing, then attack how the test was done, then attack the equipment used, then attack even the credibility of doing a blind test.
    Then start silly comments, then attack the messenger. Then make more silly comments.
    I have to quote this for posterity, as it is an excellent example of a troll post. Line after line of opinion stated as fact, and written simply to inflame, aggravate, and start arguments.
    For example:
    “I have made no "Claims" ".
    Yet, in the same post we see the same ‘Claims’ as in numerous previous posts, which are also repeated in multiple threads.
    “I realize some are simply happy believing what they believe, and simply do not want to know or hear the truth.”
    and
    “Anyone with even the simplest knowledge of basic electronics, and speakers and audio realize the speaker cable thing, is a dead end. A non issue mostly.”
    Then when people ask basic questions regarding the veracity of these ‘Claims’, we get
    “Nor will I even bother going down the road about my cable tests I did years ago. ”
    and
    “As far as providing more information. I will decline.”
    LOL.
    tonyb Posts: 33,072
    Kevin, even those with a basic knowledge of common sense know when to stop digging a hole.
    I suppose all those people who make cables, speakers, amps, etc, have no basic knowledge of electronics ? That's a pretty bold statement there chief, I'll give ya a chance to retract it.
    Speaking for myself, I've never walked into a hi-fi shop, gone to audio shows, or visited anyone who has a midrange system on up, who use a basic cable such as Monoprice. I've never seen or heard of a band worth their salt using basic cables. Nor have I heard of any musician, late night talk show bands, or anyone else who has been into music or audio for any length of time.
    Now, that's not to say there isn't any either, but I would also say that's certainly a minority. So all these highly educated people who build this stuff, must all be somehow compromised...crazy....idiots ? People with far more credentials than you ?
    I also find it funny that X has bought some Monster cables in the FM. All those lessor brands must be broke I guess. Ahh....but he only paid 20 bucks, and that's the crux of the matter right there. A lot of times peoples opinions follow their wallet.
  • vc69
    vc69 Posts: 2,500
    I wish my wallet could follow my opinions.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • tratliff
    edited June 2015
    tonyb wrote: »
    Tony. I think you have hit the nail on the head. I have a feeling that some have wallets that cannot afford them the luxury of high quality cables. Therefore they don't know what they don't know because they have never been exposed to the better cables.
    That's not to say that cables must cost big $$$'s to be great but you have to be open to spending the $$$'s to see the difference.
  • BlueFox
    tonyb wrote: »
    I will take this opportunity to plug Shunyata. :)
    As an engineer, I appreciate the engineering, science, and patents behind Shunyata products. As a customer, I have discovered that their products have greatly improved the resolution of my system, with both current and previous gear.
    The founder, Caelin Gabriel, seems to have a basic grasp of electronics.
    “Within the audio-video industry, there is no engineer with a more complete understanding of the scientific tenets critical to signal isolation and current delivery. These unique work related experiences at the highest levels of government and computer science led Caelin Gabriel to develop a series of fundamental precepts for the patented technologies and custom-designed parts that form the cornerstone of Shunyata Research products.”
    http://www.shunyata.com/about-shunyata/people
    A list of manufacturers and others who are fooled by Shunyata snake-oil.
    Audio Research Corporation
    Balanced Audio Technology
    Bel Canto Design
    Focal France
    Meridian-America
    VTL Audio
    Wilson Audio
    http://www.shunyata.com/reviews-all/manufacturer-endorsements
    Studios, etc. that use Shunyata products.
    http://www.shunyata.com/reviews-all/pro-users
    When Kevin and ‘X-man’ start a successful company based on their ‘engineering’ then they might acquire some credibility.
  • tratliff
    Kevin -
    Just for sh*ts and giggles give us some insight into the cables that were used and also the equipment. I am certain that my statements would be proven true when that information is provided.
    Help us understand your thoughts????? Don't just feed us techno babble. I can state specs all day. Real life scenarios work better.
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2015
    Deleted - will try the quote thing again later...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    kevintomb wrote: »
    YET, at the same time.....
    No one can pass a blind test and pick out their "Better cables"
    I do not have a dog in the fight.
    I am not looking to convince people to spend their money.
    I am willing to bet that I can pick between my MIT's and Audioquest Diamondback I/C cables every time on my system....
    You in?? We can meet up and set the system up - you can switch all you want without my knowledge.
    Make it a substantial amount so it isn't a waste of my time and we'll do it!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    tonyb Posts: 33,072
    kevintomb wrote: »
    No, your looking to convince people to not spend their money.....on something you know nothing about yet. Is that not why you and a few others always jump on cable threads ? Just asking is all, you keep saying you have no dog in this fight yet you keep posting in it.
  • tratliff
    vmaxer wrote: »
    I'll take a piece of that bet. My money is on VMAXER.
  • concealer404
    concealer404 Posts: 7,440
    You guys sure like to care about what others think a lot, don't you?
  • vmaxer
    vmaxer Posts: 5,120
    tratliff wrote: »
    vmaxer wrote: »
    I really think either he has never had a good enough system to tell or just another troll.
    There was a time I couldn't tell the difference, but as I have upgraded over the years it is almost unbelievable how much difference cables can make. I love the hobby (if that's a correct way to say it). I just wish I could afford the really high end.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ukcolin99
    ukcolin99 Posts: 286
    10 pages of speaker cable exchanges has tweaked my interest. Crutchfield has many $ levels of AudioQuest cable, are they worthy, should I pick my price point and order?
    With my setup should I be able to tell the difference? Currently using C&E CNE62270 100-Feet 12AWG Enhanced Loud Oxygen-Free Copper Speaker Wire $40 from Amazon and Deadbolt Banana Plugs, 12-pair, By Sewell Direct $30? Anyone's 2 cents appreciated.
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2015
    cbridle wrote: »
    I have no experience with those so I can't really say.
    What equipment??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    Just tired of the trolls, I am willing to bet on my actual experience, not what can be read on the net.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
