This joint needs some more vintage hifi
Typo, Tim Smith it's "Michell" not Mitchell. Beautiful turntable.
Actually the brand name for the Skeleton was "Transcriptor" (or was it "Transcriptors"?) :- )
He started selling tts under his own name later (at least, I think that's right).
It came with a Stanton 881EEE. And yes, it is spelled Michell not Mitchell. When i bought it (in parts) I walked out of the seller's house and slipped on some ice, and it flew up in the air but I caught it so not shattered tempered glass. That was added to the "blooper reel" of my life, which is getting pretty long and frightening at this point.Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
Well -- at least it's a high compliance cartridge :- )
Actually the 681EEE is held in pretty high regard indeed in some circles. -
It's actually a 881EEE rather than a 681EEE, so that is (at least) "200" betterNorh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
oops :-P
Here is a Carver Receiver I gave my daughter.
Handsome stuff, the ol' Carver hardware; thanks, Mr. W for sharing that.
I've been working though a backlog of trying out some of the 'second tier' (and lower) hardware here in the "new" (well, it used to be new) listening room... Yesterday's volunteer was an old dump-find Heathkit AR-19. This quasi-complementary, capacitor-coupled receiver, as is, sounds... pretty bad. Kind of wooly and rolled off; sort of that late-50s/early-60s console hifi sound. I am thinking new capacitors on the outputs would probably help... a lot. Guess it needs to go on the to-do list.
DSC_0275 by mhardy6647, on Flickr
DSC_0270 by mhardy6647, on Flickr
(yeah, it has at least one dial lamp out, it appears)
DSC_0279 by mhardy6647, on Flickr
AR-19 by mhardy6647, on Flickr -
Here is a Pioneer SX-3900 and CT-F950 that my Dad bought new in 1979. Now they are in my vintage room.
Neat-O! :- )
I have a CT-F900 (two, actually) but neither is nearly as pretty as your family CT-F950. -
Thought I'd share the current vintage shop system -
2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio -
harman/kardon Citation series components in the garage... cool. :- )
Here is an old monster HK Citation XX sitting on the crate it came in.
The AR-19 above had a Doppelgänger -- the AR-29. More powerful, and (I think) with a somewhat better tuner section, but otherwise cosmetically almost identical. Only the color scheme was slightly different.
This one, of course, was also largess of the Harvard town dump. It is unfortunately missing the shaft for one of the tone controls (the slide control itself is still intact and works). This particular unit sounds better than the AR-19 pictured a few posts above... but the tuner doesn't seem to be able to receive in MPX stereo.
DSC_0284 by mhardy6647, on Flickr
The AR-29 was in Heathkit's model line for considerably longer than the AR-19. The latter was replaced, ca. 1972, by the cosmetically identical, though presumably improved, AR-1302 (and, no, I don't have one of those).
AR-29 by mhardy6647, on Flickr
Just a wee update -- listening to a good-quality redbook CD on the AR-29 for the last half-hour or so (Rhino remastered/expanded version of the Dead's aoxomoxoa remix) on a pair of Dynaco A-35 speakers... and they're all sounding just dandy.
EDIT: For completeness, this is what the A-35 looks like (sans grille, of course) -- like the A-25, but in a larger cabinet with internal aperiodic loading between two subenclosures (woofer & tweeter). Nice loudspeakers.
DSC_9644 by mhardy6647, on Flickr -
Sweet sweet toys...
Mr.Ward's Citation with its crate is serious...
Here are some speakers you may recognize. I did a little refinishing on them.
I assume that's a before photo -- or are you into a shabby chic phase? ;- )
Last night's final listening volunteer -- not generally a big fan of Technics "ordinary" consumer products... but this ain't bad, actually (also hooked to the A-35s... 'cause I am pretty lazy).
DSC_0281 by mhardy6647, on Flickr -
A couple cartridges and some of my better 70-80's vinyl spinners: Sansui SR-838, Sony PS-X70, Pioneer PL-550, Denon DP-47F, Denon 37-F, Technics SL-5200, Technics SL-Q2. Thanks for looking.
Here is an AR4 I refurbished and built a solid walnut base for.
How about some vintage Marantz cassette decks?
Here is a rare one. A Benjamin Miracord turntable.
Beautiful AR tt.
The Miracords weren't actually all that uncommon in the US -- Radio Shack sold 'em for quite a while under their own brand (sort of). In fact, I had a couple of dump-find Miracord changers... long gone, now, though.
(1969)
(1973)
(1977)
Here is a Rek-O-Kut I rebuilt and made a tiger maple base for.
A friend had that Realistic/Miracord 45 with Optimus 5B (KLH clones) spun many a record on that system. Those 5B's performed very well (acoustic suspension). Plus RS gave them a lifetime warranty.
