Is there any speaker out there that can do what an SDA does???
245678
  • bobt
    bobt Posts: 280
    OK.. let me try and put this as simple as possible. I DON'T want to buy old speakers I have to rebuild. Used is fine if there like 5 years old or something. The speakers need to play loud and well in a 14X30 room and sit 15 feet back.
    The RTI 12's fill the room, have the bass. There just not all that warm, but the high end can get over bright.. again I think do to the tweeter. These are played between 12-1 o'clock on the pre, maybe a tad over..this depends on the CD.
    I want to keep the price at 3-4K, 3 would be better.
    The DF BP8080ST seems to have really good reviews.. is it a somewhat warm speaker, don't know.. are the tweeters not giving you too bright info.. don't know.
    There is also the Golden Ears stuff.. made buy the same guys from DT and 1 guy from Polk... But can they deal with the volume.. I don't know.
    Maggies are great, but suck the life out of the amp, and need a big sub.. so your looking at well past 3K.
    That's what i'm dealing with, so if you have any speaker recommendations. i'd love to hear them.
  • dpowell
    dpowell Posts: 3,081
    Can't help you there. None of Polk's newer speakers have the warmth of their older speakers and the RT series are too bright IMO. You don't have to rebuild their older stuff; you just won't get the max level of performance out of them if you don't.
    nooshinjohn Posts: 25,941
    bobt wrote: »
    Sounds like I would start with a better amp.
    My 1.2TL's have become very revealing speakers after the mods, amplifiers and the preamp issue solved.
  • bobt
    bobt Posts: 280
    No the amp is not a problem. Onkyo Integra M-5, adcom pre, jolidia tube CD.
    The maggy 3's new are 6K, add a 1500 buck sub.. your far beyond what I want to spend, even if you drop down to the lower level Mags..with the sub... too much.
    I like the martin Logan stuff too.. but again, with out the 1500 buck sub.. not happening.
    Now the LSi M stuff from Polk...nobody even on this forum seems to say there the best thing since sliced bread. Not going to go there.
    The other thing is i'm NOT looking for a speaker that needs subs... This is stereo only system.. nothing more.
    I'm stumped. You want a very specific set of requirements for your speakers, and you know what your options are, but those options are not good enough for you for a variety of reasons, so you are now seeking something else.
    Good luck in your unicorn hunt.
    The 1.7 Maggies would be better given the size of the room.
    http://app.audiogon.com/listings/planars-magnepan-1-7-2015-01-14-speakers-89120-las-vegas-nv
    These would be an amazing choice...
    I have heard these before, powered by some vintage Oinkers, as well as ARC gear. They are the reason I fell into the rabbit hole in the first place.
  • bobt
    bobt Posts: 280
    OK... good lord. The Onkyo in the Integra M 504 165 watts per. Works fine never has a problem. The Adcom is the 400 model..not great but not trash. The Jolidia has EH tubes in it right now, but that's not the point, nore is the cables or anything else.
    I'm looking for speakers that do NOT need a 1500 buck sub.
    I would like to keep the price at 3K for the speakers... meaning not an extra 1500 for the sub.
    edited January 2015
    http://www.ebay.com/itm/Polk-SDA-Stereo-Speakers-/251774220552?pt=LH_DefaultDomain_0&hash=item3a9ee9b908
    Toss in another grand for full upgrades and we have our problem solved. Accept no substitute. For the money you want to spend you will find nothing that will even remotely come close.
    As an aside, I am detecting just a touch of attitude in some of your replies. Please understand, that all of us that have responded to your original query have been down your path more than once. I have gone from SDA-SRS 1.2TL's to Magnepan MMG's to MG-20's, only to find my way BACK to 1.2TL's.
    No speaker, short of 15k can do what a set of properly modded 1.2TL's can do, ZERO, ZIP and NADA. For this reason, we have developed the most comprehensive set of mods, tweaks and upgrades that I have ever seen for a 30 year old speaker design. The performance these speakers are capable of is astounding, and why you see more than a few of us with gear that you would think far surpasses what these should be used with.
    The mods make these speakers new in every respect, and as I said above, I have had exposure to many LEGENDARY speakers in the multiple tens of thousands of dollars. The Only speaker I would have back would be the Magnepan MG20's, but the 1.2TL's will not be leaving any time soon.
    The M-504, while a good amp, was never a GREAT one imho, It too is considered vintage now and likely needs a recap or other maintenance to bring it back to full spec. I would also select a new preamp, as I suspect some of your issues have more to do with synergy than anything else.
    Cables are the most overlooked, yet VITAL parts of a high performance audio system. Budget somewhere between 15 and 20 percent of overall budget to address how your components talk to one another, as every part of your audio system is responsible for the sound you hear.
  • TNTsTunes
    TNTsTunes Posts: 751
    SRS's ;)
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
    TNTsTunes wrote: »
    SRS's ;)
    I know that, but they do convey a message.
  • ken brydson
    ken brydson Posts: 9,008
    bobt wrote: »
    Curious why you think you "need" to spend $1500 for a sub? This coming from a fan of big **** subs....
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited January 2015
    People try to be helpful and this is the attitude displayed. Why the heck does anyone even bother to try and help this guy is beyond me.
  • bobt
    bobt Posts: 280
    YES John.. I agree with you 100%....
    I have a set of SDA 1C's small problem is 1 driver is shot. 3 years ago maybe longer I had Polk send me new drivers... they were in a word JUNK,,, made were ever I don't know. They would POP if pushed to hard, They sent me another driver.. did the same thing.. did not matter what speaker they were put in, did the same thing.
    Now I have a call into polk to the only person that may have a clue about SDA stuff.
    He may know if the drivers are either good or bad at this point.
    If he tells me that these are now good drivers. I will spend the money....
    IF the driver works.. then I will buy 5 of them for back ups..LOL These are the nasty MW6511 which you can NOT find online for the most part. This is not an easy fix.
    I have tried to get the original driver fixed... LMAO... NOBODY will touch these speakers, I have tried all over the country... nobody will fix these drivers.
    So your right, these are great speakers as long as you can get them fixed....
    Your amp is part of the popping problem. You are pushing it to the point of clipping. I would suggest something on the order of 300 wpc plus, or going tubes. You also said that the Onk is a dual mono. Is it COMMON GROUND? That could also be the problem. The MW6511's come up on Ebay all the time.
    I suggest working the problem rather than tossing solutions around that have no value at this point. Seems like you want SDA's, so let's go that route and help you get the very best out of them.
  • bobt
    bobt Posts: 280
    Attitude.. REALLY? Give me a break. I probably have had more Polk speakers then you since the 1980's... Basic problem is I can't repair them. So I asked a simple question of what might be close...
    bobt wrote: »
    There are many here, myself included, that are willing to help solve the problems you might be having. Need a pair of updated crossovers? get me the parts and I will do them up for free plus shipping and a six pack of my favorite brew. Drivers??? yeah, we got that too. Larry's rings... check. wood refinishing... covered there too.
    We got your back man, just relax and know you can do it if you want to. Nothing sounds better than knowing you did it yourself and knowing you have more coin to spend on other stuff in your rig.
  • madmax
    madmax Posts: 12,434
    New drivers pop if you don't break them in before applying a lot of power (or high volume from a low power amp like the integra. They can also pop if wired in reverse of the rest of your drivers. 1.2s would go for at least 12K today, if sold new.
    Vinyl, the final frontier...
  • bobt
    bobt Posts: 280
    OK.. Again.. there is nothing wrong with the amp. I have had these speakers since new in 1986 or 1987.. whatever don't remember. They play great. I have replaced MW 6511"s before..no problem from Polk, I even replaced the cross over in 1 speaker
    from Polk...but now there is really no back up for these speakers.
    I tried 3-4 years ago to replace an MW 6511.. it was junk. Now you can say what you want.. I did something wrong, but moved the diver from one speaker to the other, it would POP. What I got before.... was good.. now, I don't know where it's made.
    I will try once again if the Polk guy tells me these drivers are good.
    If they don't work... then I need another speaker set up.. that's what i'm talking about.
    As far as putting in the drivers in speakers .. LOL I've done this a number of times and also a whole cross over.. so don't even bother to go there.
    I've fixed computers for years.. really big crap from the 70's to boot.
    Not like I can't replace a driver in a speaker.
  • bobt
    bobt Posts: 280
    OK mad max.. really.....your statement does not even may sense, and the Integra is NOT a low powered amp....
    F1nut Posts: 51,871
    Your amp is fairly low powered as amps go. Deal with it. The EH tubes in your Jolida are horrible. Wonder why you've replaced so many drivers? At 12-1 o'clock on the volume that amp is in the clipping zone.
    F1nut Posts: 51,871
    bobt wrote: »
    Makes perfect sense to me and likely every other person that has responded to you in this thread.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    bobt,
    I had a long and successful career in HR, where I had to deal with all sorts of employee relations issues. One common one arose when an employee "didn't know what he didn't know." When a person is in this state, it is impossible for him to learn or be educated. Ideas that differ from what he "knows" are summarily dismissed.
    It sounds to me like you are suffering from this condition with respect to the problem you articulated and for which some very wise and experienced folks on this Forum have generously offered their advice. In response, you ramp up the volume and truculence of your replies.
    Do you already "know" the answer that you want? Have you already dismissed whatever they suggest? Or, perhaps, you don't really want help; you just want to complain about your plight.
    I don't know, but that is my perception of the "attitude" others have noted.
  • bobt
    bobt Posts: 280
    Good god... lets's put it this way... either the MW 6511 driver works... or it does not
    Which makes the SDA1C work ... or it does Not..... is there something that nobody gets out of this?????
    IF it does not work, then what is the point???
    F1nut Posts: 51,871
    Tony, this one is for you 'cause I know you know....LOL
    You can lead a horse to water, but you can't make him drink.
  • Faustin
    Faustin Posts: 1,151
    This thread may get picked up as a pilot for a new weekly sitcom. Hilarious.
  • ken brydson
    Gawd I miss the bozo list....
  • Moose68Bash
    bobt wrote: »
    bobt,
    I got it.
    I also got a pair of 1Cs in 1989, that worked very well for over 20 years, driven by a Perreaux PMF2350 amp that I purchased at the same time I purchased the 1Cs. I never had a problem with the drivers -- or the tweeters or crossovers, for that matter.
    A couple of years ago I jumped head first down the "rabbit hole" and upgraded the tweeters to RDO-194s and had Vr3 Mods upgrade the crossovers. I did all the other "standard" mods at the same time. The 1Cs are now driven by a vintage Perreaux PMF3150 (300W/channel RMS into 8 ohms).
    These modernized 1Cs "sing," and they fill my basement with sound when I crank up the volume to about 50% of maximum. My basement is roughly 2,800 sq ft of area with lots of "stuff" but no interior walls. No problems with the drivers or tweeters. Great sound day after day.
    "What is the point???" to borrow your question.
    The point is that the problem is not likely with your drivers. If you open your mind to the advice you're getting from the "wise men" on this Forum, you might actually identify your problem and solve it. So long as you continue to point the finger at the MW 6511 drivers you have blown, you may never define your problem -- let alone solve it.
    edited January 2015
    Bob...
    I love a good car analogy. Let's say you have a 1965 Corvette that you bought new, and you have loved like a baby. You have cared for it, done all the proper maintenance and such, but now she's got a blown motor. It still runs, but has none of the qualities you fell in love with but the body style, and even that is getting tired.
    You want a new car that will give you all the fun and excitement you had with the old, but your budget is the same as what you had when you first bought it. You are not going to get anything close to what you have for the money, but you just don't feel like restoring it.
    Now lets flip this to your speakers. There is not a single part of them, besides the drivers, that has not exceeded their lifetime, and the same can be said of your amplifier. They need to be restored. In order for them to be returned to their previous glory, they need to be recapped, wiring inspected, and updated where appropriate. New tubes for the preamp is also a very wise move, as those tubes are not doing you any favors, as Jesse pointed out.
    No other speaker is as well regarded here, outside of the TL's as the SDA-1c, and many here prefer it to the big boys. We are not trying to bust your chops here, but rather trying to help you understand that as these speakers are now 30 years old, there are a few things needing to be done to make them go another 30. Your crossovers could very well be the reason you are having driver issues, so lets help you tackle those first. We can also help you with selection of a new amp. It is entirely possible that you can take the speakers you are ready to give up on and turn them around, get that new amp and still be well under your budget that you set for new speakers.
    I would not even consider getting new speakers until that amp was at least sounded out by a qualified technician, or replaced with something else.
  • bobt
    bobt Posts: 280
    I would have to guess you do not get IT, the divers Polk sent me at the time,, made in 2000 something I don't know were it was made but did not work... they POP if pushed to hard\
    Not a problem of the amp or any thing else.. there bad,
    What Polk may send me this time If the guy from Polk tells me it's good,
    Maybe this will work. If not i'm looking for a better speaker.
    I would have not liked mr F1 NUT. He should shut up... But of course he has something to say.
    I have been a computer guy for years, I have been a musician, for even more.
    I have played music across the country. I've played in the red onion in ca, In Chicago
    pretty much all over the place... . Been in the studios .. analog 24 track.
    If you think I don't know what i'm doing.. get a grip.
    If you think your pile of 30K lists of posts .. of i should know crap is for the most part stupid...
