This joint needs some more vintage hifi
1…1718202223…62
    mhardy6647 Posts: 35,562
    Actually the CR-1000 is a little too disco for me with all the slide controls -- oh-so-fashionable ca. 1974 they were. Other than that, it's a very nice piece of hardware with a remarkably good tuner section for a receiver.
    Aesthetically, I am probably most partial to the CA-1010 and CA-2010 integrated amplifiers as the sine qua non of the massmarket Yamaha hardware (some of their statement separates are more elegant and/or more impressive, but still out of my price range... at least in terms of what I am willing to spend for vintage solid state stuff).
    11535696185_165df1328f_b.jpgDSC_6689_z by mhardy6647, on Flickr
  • sucks2beme
    sucks2beme Posts: 5,703
    /quote]
    The price range is always the issue. 10 years ago you could play with these and not worry about it. Anymore, the $$$ becomes a factor.
    I like to buy stuff non-working. I've seen broken stuff going for
    hundreds of dollars. The 1150 was $100 BROKEN (the balance slider
    was GONE). The only reason I jumped was the guy who sold it to me
    said it was the only thing wrong, It was a guy I know, so lower risk.
    The KR-7600 was more of a crap shoot.
    edited August 2014
    The price range is a factor that has to be balanced against... shall we say... desire to acquire.
    E.g. I'd have no issue at all in paying current market price for a Marantz 8B in good working and cosmetic condition from a reliable, local seller. Absolutely no problem at all...
    9612442175_d4349ea751_b.jpgMarantz8B by mhardy6647, on Flickr
    That one's not mine, but I did the re-hab on it and I've gotta tell you it's the best sounding commercially-made vacuum tube amplifier I've had in my home (and I am not, a priori a big fan of the push-pull EL34 "sound")... even with the cheap-jack "cannon fodder" Sovtek output tubes installed in it while I was workin' on it, it sounded great.
  • Mikey081057
    Mikey081057 Posts: 7,127
    I love the vintage Yamaha receivers too.... and I am a big fan of their old amps as well... they are way under appreciated...The only thing I don't like about much of the vintage stuff is the connectors....RCA and Speaker connections don't seem to age well. And yes the 8B is a classic perhaps even a museum piece.
    Garage | Polk Monitor 5B's
    Don't complain ; - )
    ...And yes the 8B is a classic perhaps even a museum piece.
    Well... except that they deserved to be used not just gatherin' dust.
    The other classic commercial amp I'd like to get to know better is the h/k Citation II (FWIW).
  • sucks2beme
    The citation 16a is one that I can't seem to get my hands on.
    As far as the Kenwood goes, some more work tonight found that the
    preamp jumpers were causing issues. After some cleanup, the bass
    has improved on the Kenwood. Who'd think that could cause that
    much of an issue? I still need to pull it down all the way. Some of the pots are
    coupled to the back via long shafts. I've got to pull the back off to get to
    them. Such is life with old stuff.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    Those old HK units are built like a tank. The build quality screams McIntosh. I had my hands in a citation pre-amp last week, and they sound very nice. We ended up replacing the unshielded input leads and changed the volume control to an alps. With a little chassis and knob modification it looks like no one even touched it from the outside.whgwn4g6rio5.jpg
  • Mikey081057
    Jeez that is very sweet ... that my get my vote for Vintage P O R N of the year...
  • gmjungbluth
    My ESS AMT 1s. Neat speakers
    HT System:
    Marantz NR-1403
    Front: Klipsch CF-4
    Rear: Paradigm Atom V3
    Center: Boston Acoustic VR12
    Sub: Bowers & Wilkins ASW600
    2Ch:
    Restored Fisher 500C
    Yamaha P-500 Turntable
    Living Room:
    Harman Kardon 3380
    Restored Polk Monitor 7B
    Bedroom:
    Harman Kardon VR-3750
    Cambridge Soundworks Ensemble
    Polk PSW10
    In and out of rotation:
    KLH Model 6,
    Polk LSI7
    NAD 7100
    The h/k preamp and the ESS speakers are very nice...
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    The ESS AMT 1A's are what I grew up listening to on my dad's system. Not for everyone, but it certainly pushed me towards a quality speaker with nice bass and detailed highs. He still has them, and I'm acquiring parts as I can to rehab them in the future. The HEIL tweeters are really nice and you see the same principles being applied to a lot of new offerings.
  • dudeinaroom
    I wouldn't mind giving those ESS speakers a listen. That H/k was nice mhardy, save ofr the couple of blemishes on the back under the tubes near the input jacks, it was in pristine condition. We fired it up before freshening it up and it sounded congested. After it just sung right, very nice sounding vintage pre. I wouldn't mind having a citation I like that to rotate through the mix.
  • dudeinaroom
    edited August 2014
    Here is/was a basket-case of a Scott 290 amp. I had to rewire much of it, as a chunk of the wires were burnt from the heat of the dual rectifiers. Most of the wiring in that thing ran between those 2 hot tubes, now there are 2 in that location, and only because that is were they need to connect to. All other wires were ran around the outside of the tubes. We also greatly increased the wattage dissipation of the dropping resisters to help cool things down under the chassis. I wish I would have gotten pics of the lk-150 I did about a week or so ago as it was very very clean, and also another nice sounding unit. I should note that the 290 in the pics above had a "tacoed" chassis, as well as the far right control on the face was smashed back in about 3/8 of an inch. A little bit of wood and a hammer can make things straighten out pretty decently.
    edited September 2014
    Finally had some bandwidth to test the trifecta of MX5050 MkIII-2 decks. They all three work pretty darned well and sound quite good, as is.
    The two on carts are pretty grungy, but it's a Velveteen Rabbit rather than a Curt Cobain kind of grunge... they were clearly much loved ;- )
    DSC_0056 by mhardy6647, on Flickr
    Nice thing about these decks -- they're half-track decks, but they come with a quarter-track head stack, too. A switch under the head cover selects the 2 vs. 4 track playback heads. Easy as that.
  • boston1450
    boston1450 Posts: 7,759
    Just got my Yamaha CR-1000 & love it. Cant wait to use it this weekend
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    Randy-Maine
    by David WMG
  • Glen B
    Glen B Posts: 269
    I recently got this minty Technics SU-A6 preamp, with MC phono.
    SUA61.jpg~original
    SUA62.jpg~original
    SUA63.jpg~original
  • boston1450
    Randy-Maine
    by David WMG
    I took advantage of a rainy morning today to -- finally -- "restore" the other knob inserts on my dump-find EICO ST-40 integrated amplifier (pp 7591A, as was its big brother the ST-70). Years ago, I had found some brown textured paper at a Michael's craft store that was a pretty darned good match for the missing inserts.
    I feel much better now.
    15468965421_db80b78dd4_b.jpgDSC_0198 by mhardy6647, on Flickr
    15285518097_425a71d194_b.jpgDSC_0200 by mhardy6647, on Flickr
    ST-70 on the left, ST-40 on the right
    oh and I spent an hour or so listening to it via a pair of Dynaco A-35XL speakers.
  • boston1450
    edited October 2014
    Looks very nice Mark. We use to have a shed at our local transfer station & a year ago they locked it up. I use ta enjoy going to get rid of trash/recycles. Use ta get some goodies too
    Randy-Maine
    by David WMG
  • jcaut
    jcaut Posts: 1,849
    I recently acquired and restored a couple of significant-to-me, Realistic receivers.
    I would have been about 11 years old in 1981, and my dream receiver was the STA-2080. But I didn't get one, couldn't afford one, etc.. It took a few years but by 1984-'85 I had saved up enough to buy the "new for '84" STA-860. I ended up selling my original a few years ago, but almost instantly regretted it. Found one recently for $59 that I couldn't pass up. A few weeks later I acquired a working-but-overheating STA-2080. I worked it over and here it is along with the 860. I tend to like to keep the original look when it comes to dial lighting on these old receivers, but many of them- including this STA-2080- desperately needed cooler-running lamps, as the heat was taking a toll on the plastics. I tried and tried, but I just couldn't get the warm-white LED's to look right. I finally threw that approach out the window and went for a cooler look with blue tinted meter lighting. I think it looks nice. (The 860 lighting is all LED, too, but maintains the original look.) p0e80sdv4j7p.jpgftxzfnjkqzns.jpg
    edited October 2014
    Those old Realistics are nice! I have a couple myself. An STA-2200 (first RS unit with Mosfet power transistor construction).
    And, one of my favorite looking pieces below, the STA-95, but the 2080 is more powerful, bigger, and has POWER METERS! And those new lights are "sure" pretty!
    Will put all my RS stuff together in a room eventually. Probably the STA-95 (or 2200) some Nova 8s, LAB 395 TT, SCT 33 cassette deck, and a CD 2300. Pretty much a nostalgia system but I was a lot older than 11 in '81! Reminds me of everything I never had in college/and graduate school!
    cnh
  • George Grand
    George Grand Posts: 12,256
    Very nice Jason.
  • pumpkinman
    pumpkinman Posts: 10,546
    This was given to me recently as an "I don't want it anymore" Well it now has a happy home.
    Proton D1200 power amp from1988.
    Sorry it 's not a better pic.
    P-man
    Because I am The Pumpkinking
  • Tbone289
    Tbone289 Posts: 661
    She's a beauty! B)
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
    edited October 2014
    ^^ That R/S receiver (RS-2080) is, I believe, the model with the MOSFET outputs; I can't ever remember hearing one... but they're said to sound quite good.
    edited October 2014
    I think the 2080 has an FM stage with MOSFET, but the first advertised RS with MOSFET power outputs for amplification was the STA-2200 below. I could be wrong, but the advertising seems to tout these transistors in the '81 catalog? It's the only receiver that year to list that whereas the 2080 and others mention FM MOSFETS? Again, not a hundred percent sure here?
    cnh
    Nor am I...
  • jcaut
    jcaut Posts: 1,849
    edited October 2014
    Thanks for the comments! So the consensus is that the lighting scheme looks okay? I do like it, but I feel a little bad about it not looking original. The original bulbs on the dial used a blue coating to make them less yellow, but the meters used a transparent blue filter to accomplish the same thing. With the yellowing of the plastics from heat, warm white leds just made everything look kind of sick yellow-green. That's pretty much how the incandescent lamps looked, too, when I bought it, but I remember the lighting looking a lot "whiter" when these were new. As shown above, I just used regular "cool" white leds, one on each end of the dial and two per meter.
    And the 2080 used regular BJT outputs, 2SD745 and 2SB705. It looks like it's pretty similar to the STA-2000 in layout and construction, but was made in Korea instead of Japan. Most people seem to think it sounds better than the STA-2000. I don't know, but it sounds real good to me.
    Despite being built a few years after the "peak", that STA-860 is no slouch either. Advertised as 65wpc @8 ohms,20-20Khz 0.03%THD. I drove mine hard, even being a dumb teenager and doing "DIY" Dj gigs with it on multiple occasions driving 4 Ohm (probably lower) loads with no problems. I'm not really what I would call an audiophile but I have been exposed to some nice equipment and I've spent a lot of money in pursuit of higher end audio. And I don't regret any of that, but when I got this 860 and hooked it up for a listen it was kind of like "ahhhh!" Perhaps it's just because it's what I grew up with.. I got a chuckle out of it, actually. Now if I had a set of Mach One's to go with it....
    Always thought those Proton amps were cool, too! Never heard one though.
    I think that LEDs are the way to go in relamping old stuff for several reasons -- heat and longevity being the primary ones. Generally speaking, I prefer the color of modern LEDs to the warm glow of incandescent.
    Sorry I got my "what receivers had MOSFET outputs" all confuzzled and confusticated! :- p
    It's neat that you've had the 860 since it was new!
