Dreadnaught Avel-Lindberg 1000VA Transformer Group Buy?
1151618202124
  • drumminman
    drumminman Posts: 3,396
    It'll be a few weeks for me as all the parts to finish the Dreadnought and CRS+ mods are yet to arrive.
  • motorstereo
    motorstereo Posts: 2,338
    nspindel wrote: »
    So how many people actually have wired it up and tested already? Curious if anyone else has gotten as far as motorstereo and is able to tell if they notice a difference over the straight cable?
    As I mentioned mine got completed yesterday. The first song I played was a mild disappointment. 2nd song got better and it seems with each passing hour now there's been noticeable improvements. I don't know why but the bass seems more pronounced now and I haven't had the want or need to use my 18" sub. Mids are also cleaner as I've been able to pick out a few phrases on recordings that I couldn't make out before. And yes the soundstage seems to have gotten a bit wider also. I can actually tell the difference in the sound as soon as I walk in the door even though I'm behind the rig. And this is the difference from the A1 interconnect that I'd had. The A1 was a noticeable improvement over the straight wire. One other area I noticed a change for the better is that the speakers seem to be a bit more sensitive also. I had been looking for another Mcintosh mc2500 for a bit more wpc but that idea is on hold now as of yesterday. I feel quite certain that this one of the better upgrades that I've made on those tl's in the few years that I've owned them.
  • nspindel
    nspindel Posts: 5,343
    Anyone here moving up from the 800VA?
  • drumminman
    Motostereo, I experienced each of those things when I built my first Dreadnought with an 800VA A-L. It sounded like I had a more powerful amp, the midrange was cleaner, the bass was more tactile and a little cleaner, voices sounded more pure, more natural, better transients (the pluck of a guitar string, a stick hitting a drum or cymbal). And all of that improved yet again when I built my 1000VA Dreadnought.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    nspindel wrote: »
    When I get my new transformer installed, it will replace a 670VA Toroid of Maryland transformer. This is not the same as an upgrade fro the A-L 800VA transformer, but I'm expecting good things!
  • jonicont
    jonicont Posts: 281
    I'll be moving up from the 800 when the damn thing gets here!
    DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
  • motorstereo
    drumminman wrote: »
    It's nice to know that I am not alone in hearing all these improvements. I've been playing the rig for a few hours each day as it was obvious to me that there's a break in period going on here. The changes in the sound have slowed down a bit now and I'm wondering now how long this break in period will take?
  • drumminman
    Re: burn in, not exactly sure. Seems like around ~200 hours, give or take. IIRC most of the changes occur around 150 hours, but mine improved in more subtle ways up to around 200. There is alot of copper in that tranny.
  • motorstereo
    Hmmm; 200 hours of burn in; I've got quite a ways to go. Right now they're the best I've ever heard them sound and it's nice to know there's even better sound on the horizon.
  • Moose68Bash
    My recollection is that at around 200 hours with the A-V 1000VA transformer in my system with the SRS1.2s I experienced a very noticeable and fairly sudden "opening up" of the sound. and, there were appreciable improvements along the way.
    I get impatient; so, when my wife and I go out, I leave the rig playing from my iPod on shuffle during burn in periods. [As an aside, it seems that inevitably when we return, the track being played is one that I had sort of forgotten -- a pleasant surprise in most cases.]
  • nspindel
    I left mine playing while I went away on vacation. Burn in was real easy!
  • Moose68Bash
    That's the way to do it! Take a vacation and also get a component burned it.
    A real "twofer.
    F1nut Posts: 51,763
    You nailed it.
  • drumminman
    Has anyone built and burned in a Dreadnought and then gone back and lined the case with copper foil for EMI rejection? Curious about how much of an audible effect/improvement the foil provides.
  • Moose68Bash
    I've lined both of my Dreadnoughts with Dynamat, but not copper foil.
  • Mine arrived last Friday. Thank you!
  • jonicont
    jonicont Posts: 281
    It's here
  • drumminman
    I did the same, but some are going for EMI shielding too. Wonder if it makes an improvement.
  • westmassguy
    westmassguy Posts: 6,850
    Aluminum is good for RF shielding. That much copper could certainly act as an antenna. Copper is good for Electro-Mechanical Interference, caused by adjacent AC lines, poorly shielded transformers, certain types of consumer electronics, even florescent lighting. I certainly doesn't hurt to install it. Just be sure there's a barrier between the Aluminum, if unpainted, and the Copper Foil.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • jonicont
    jonicont Posts: 281
    Postman rings the bell. "Just checking if you are home, that package is heavy". Also has my new vinyl (Ty Segall--Manipulator--very electric--could be my #1 of the year). Anyway, sounding great out of the box. Tight bass, good imaging, wide soundstage. We'll see what happens after burn in
  • TNTsTunes
    TNTsTunes Posts: 751
    Mine came today. Felt sorry for the little old mail lady.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • vmaxer
    vmaxer Posts: 5,120
    Picked mine up today from the post office, girl said must be a car part, it's heavy....
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    How can something this small weigh so much?!!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • nspindel
    There's a reason the thing costs as much as it does, huh?
  • jonicont
    jonicont Posts: 281
    When burning in, does volume matter or is just providing a signal enough?
  • motorstereo
    jonicont wrote: »
    I was wondering the same thing. Just to be safe I have mine burning in at above average listening levels. Thankfully I have my speakers in a building separate from the house so this isn't a problem.
    I'm also still in awe at the sonic upgrade this thing has given me and I've still got a long ways to go on the burn in process.
  • nspindel
    jonicont wrote: »
    Great to hear!
  • Moose68Bash
    Guys, I have a question to which, unfortunately, I think I know the answer, but I'll ask fro input from those who undoubtedly know:
    Shouldn't there be continuity through both the primary and secondary sides of the transformer when it is properly connected?
    I installed my A-V 100VA transformer today; reassembled Larry's enclosure, and decided to test for continuity before I reinstalled the Dreadnought in my system. I got continuity on the secondary side, but not on the primary side.
    Yes, I should have checked before I reassembled the enclosure, but I was impatient.
    Before I take the enclosure apart to check without using the binding posts, I want to make sure I understand what these readings should be.
    Thanks.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Yes, there should be continuity on the primary and secondary side, but not between primary and secondary.
  • Moose68Bash
    Thank you, Ray.
    I was pretty sure that was correct, but I wanted to be certain before disassembling the enclosure again.
    Now, I guess I better hope that its a problem with one of my solder connections and not a problem with the primary side of the transformer. :\
