Dreadnaught Avel-Lindberg 1000VA Transformer Group Buy?
1141517192024
  • nspindel
    nspindel Posts: 5,343
    nspindel wrote: »
    I thought it might be useful in the interests of drumming up more participants to put up a good post explaining what this group buy is all about, with a few links to some highly useful threads.
    The original SDA design worked only with common ground amps. Some non-common ground amps allow you to strap the negative poles together, essentially making it a common ground amp, without a problem. Others do not, and very very bad things can happen if you do. You certainly couldn't use mono blocks with SDA's. Polk's later design iteration of the SDA's allowed for the use of a new cable they sold called the AI-1. You can still find them for sale on occasion on eBay or they come up here every now and then. The AI-1 allowed the SDA signal to pass between the speakers without requiring the grounds to connect by using an isolation transformer. However, like other parts of the crossover design, this cable was manufactured to meet a price point by using less expensive (i.e. inferior) components. It worked, and allowed you to use SDA's with non-common ground amps, but it didn't sound as good as using a straight cable.
    Enter DarqueKnight and his research into using much better isolation transformers. His original intention was to replace the original AI-1 he needed in a scenario where he was not using a common ground amp. He researched several different transformers and settled in on an 800VA transformer from Avel Lindberg for his original Dread:
    http://www.polkaudio.com/forums/showthread.php?73304-AI-1-Dreadnought-Preliminary-Results
    http://www.polkaudio.com/forums/showthread.php?74472-The-AI-1-Dreadnought-Project-Pt.1
    DK later discovered that improvements continued using an even bigger 1000VA transformer from AL, however these were not a stock part and required a minimum purchase of 10 units, hence these group buys:
    http://www.polkaudio.com/forums/showthread.php?131537-Plitron-1000VA-Transformer-Evaluation
    http://www.polkaudio.com/forums/showthread.php?129829-The-AI-1-Dreadnought-Project-Pt.2-Upgrade-to-1000VA-Transformer
    Somewhere along the line, he experimented with the Dread using a common ground amp, and discovered that when built with a boutique audio grade transformer like we're ordering here, the original AI-1 design actually sounds considerable better than a straight SDA connection when used with a common ground amp as well. That's when a lot of interest in these transformers came about, a lot of people including myself are using a Dreadnaught (either 1000VA or 800VA) with common ground amps and are loving the results.
    So this group buy is for the transformer. Sounds expensive for a transformer, but this thing is a massive hunk of audio grade copper. You'll need a case to mount it in. Save yourself time and get Larry's. You'll need to consider what kind of connectors you'll need. Save yourself time and get Speakons:
    http://www.polkaudio.com/forums/showthread.php?142058-A-slightly-different-take-on-the-Dreadnought
    Finally, you'll need to consider cables, and how they terminate on the speaker side. Personally, I replaced my pin-blade SDA connector with a Speakon and haven't looked back. You can also use a single binding post, connect the positive Dreadnaught cable, and connect the negative to the same negative post that you connect the negative speaker cable coming from the amp. Helps to use both a spade and a banana on the same terminal. I'd recommend going Speakon though!
    Hopefully I'll get paid three times today and we'll be at 15 paid units. Then we try to recruit 5 more over the weekend and get to 20!
    Here are all the cleaned up links from my above post:
    http://forum.polkaudio.com/discussion/73304/AI-1-Dreadnought-Preliminary-Results
    http://forum.polkaudio.com/discussion/74472/The-AI-1-Dreadnought-Project-Pt.1
    http://forum.polkaudio.com/discussion/131537/Plitron-1000VA-Transformer-Evaluation
    http://forum.polkaudio.com/discussion/129829/The-AI-1-Dreadnought-Project-Pt.2-Upgrade-to-1000VA-Transformer
    http://forum.polkaudio.com/discussion/142058/A-slightly-different-take-on-the-Dreadnought
  • motorstereo
    motorstereo Posts: 2,328
    TNTsTunes wrote: »
    Yes; thanks that's the one; and thanks to Jesse also for posting the pic of how it should be wired.
  • nspindel
    TNTsTunes wrote: »
    I wonder if mines going to get shipped to me or GlennDog first????
    Remind me which city, state you're in?
  • TNTsTunes
    TNTsTunes Posts: 751
    Waterford WI 53185
    nspindel wrote: »
    TNTsTunes wrote: »
    Waterford WI 53185
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • motorstereo
    I had thought that they were being wound at Avel's here in the states (not that it really matters). Now I know why it took all this time but I'm betting it'll be well worth the waitvjnb6l7ic8jh.jpg
  • nspindel
    I don't have a Waterford WI address on my list. Did you guys ask me to change that address or did you go straight to Melanie? I know Glen had originally ordered three, but then changed to two.
  • TNTsTunes
    I'm not sure what Glen did about shipping address changes. If he didn't contact you odds are it's being sent to him first and he'll send it to me. He did have Larry send me the case for it directly to me. I'll have to send Glen a message.
    F1nut Posts: 51,746
    TennMan wrote: »
    Did you consider adding a switch to the case to bypass the transformer? That way you could do an A/B test without swapping cables.
    1. Adding another connection increasing the likelyhood of more noise on the line.
    2. Not one person that has added the transformer has gone back to using their SDA's without it, so there really is no point.
  • TennMan
    TennMan Posts: 1,267
    Thanks F1.
  • agfrost
    agfrost Posts: 2,467
    TennMan wrote: »
    TennMan wrote: »
    A/B not really the purpose.
    1) First, at one point I thought I'd have my Speakon connector on the speakers before the transformer arrived, and I wanted a cable so I could still listen.
    2) If I opt to get different SDAs later on down the road, I'd like to be able to sell mine with an interconnect, so I have that in reserve.
    Looking forward to doing the last bit of work when my shipment comes in!
    Jay
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited October 2014
    Hey, Neil,
    My Avel-Linberg 1000VA transformer arrived a few minutes ago.
    Again, many thanks for executing this group buy for us.
    PS: It almost gave the USPS delivery woman a herniated disc!
    PSS: I didn't post a picture because mine looks just like motorstereo's, including the "Made in Sri Lanka" sticker! :)
  • MrBuhl
    MrBuhl Posts: 2,419
    Mine just arrived - thanks Neil - man - I have SOOOooo much more SDA work to get completed, (rings to install, spikes to install, toroid to figure out), time to get crankin!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • drumminman
    drumminman Posts: 3,396
    Neil,
    My tranny was sitting at the garage door when I arrived home today. Got my Hepta Litz inductors earlier this week. Need a few more bits and pieces and I'll be ready to finish my CRS+ upgrades.
  • Sea
    Sea Posts: 317
    Got mine too! Thanks nspindel.
    Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
    Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
    Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
  • agfrost
    Sea wrote: »
    Ditto.
    Jay
  • PSS: I didn't post a picture because mine looks just like motorstereo's, including the "Made in Sri Lanka" sticker! :)
    Somehow despite the picture I didn't realise the magnitude of this transformer until it arrived. I would suggest a banana for scale but that wouldn't help convey the weight! Time to finally get around to ordering the speakons and misc. hardware...
  • Moose68Bash
    Good idea!
    A banana for the dimensions, and sitting on a scale to show the weight!
  • Sea
    Sea Posts: 317
    I have seen it somewhere but I cannot find it again. Can anyone explain the origins of the name Dreadnougt? I understand the historical significance, I mean as relates to the AL-1.
  • drumminman
    IIRC Darqueknight came up with the name.
  • westmassguy
    westmassguy Posts: 6,850
    drumminman wrote: »
    An awesome choice, whoever came up with it.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Sea wrote: »
    I called it the "Dreadnought" because the user would not have to be afraid of using any high powered non-common ground amplifier with their SDA's.
  • Sea
    Sea Posts: 317
    Thanks DarqueKnight for the response and the research.
  • Sea
    Sea Posts: 317
    Today I wired up my transformer as listed in F1nuts thread.
    Red/yellow right plus
    Black/orange right minus
    Grey/brown left plus
    blue/ violet left minus
    No sound from sda drivers. Double checked continuity of cables....ok
    I have no contunity from left to right coming out of the box
    BUT, I do have contunity between the plus and minus on each side.
    Is that normal? I have checked and rechecked but I am afraid I have made some stupid oversite
  • drumminman
    edited October 2014
    Based on your description you have the AI-1 wired correctly. Sea, have you changed any of the wiring at your binding posts, or from the binding posts to the Xover ?
    Which SDA speakers are you connecting the Dreadnought to?
  • Sea
    Sea Posts: 317
    Yes, But it was working before. I put speakons in and made a cable a few weeks ago. It has worked fine. Today, I cut that same cable in half and put another pair of speakon connectors on. I wired the speakons at the binding posts like before. The blade to negative and the pin to positive on the speakon female.
  • nspindel
    Great to hear that everyone is finally receiving their transformers! Happy to have been able to help you all out.
  • Sea
    Sea Posts: 317
    I found my problem. I had one of the connectors wired on 2- instead of 1-. I knew it would be something stupid.
  • motorstereo
    I just finished up wiring up my dreadnaught and making the speakon cables and their connections. This was a really fun way to spend a rainy Saturday and well worth the 12 hour effort. So far I'm quite pleased with the sound improvement over my old A1 interconnect. Once again thanks to Neil for making this possible. Also to Darqueknight and F1nut for the easy to understand instructions on how to do yet another worthwhile mod on these fine old speakers.
    Now the fun starts once again in the listening and break in period.
  • stogie
    stogie Posts: 230
    Received mine yesterday. Thanks Neil for handling this group buy!
    Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
    Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
    Power Amp: Sunfire Architect's Choice Series II
    Preamp: Adcom GFP-750
    SACD/CD: Oppo BDP-95
    Tuner: Sansui TU-717
    TT: Technics SL-MA1
    Phono Pre: Emotiva XPS-1
    Music Server: Mac Mini w/JRiver - iPad w/JRemote
    DAC: Eastern Electric MiniMax Plus
    Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
  • nspindel
    So how many people actually have wired it up and tested already? Curious if anyone else has gotten as far as motorstereo and is able to tell if they notice a difference over the straight cable?
