Let me have it....tell me I'm crazy....but I use Romex 12/2 for speaker cable
12346»
  • headrott
    headrott Posts: 5,496
    Apexpro wrote: »
    So is cable 'burn in' a real thing or just a myth?
    Only one way to find out for yourself............
  • headrott wrote: »
    Apexpro wrote: »
    I have to disagree. I think enough people know whether or not it helps and have a ballpark idea. Otherwise what's the purpose of these forums? Maybe I'm incorrect in assuming this is for a free exchange of ideas and social interaction.
    If I am wrong I'll thank all for their help thus far and will stop bothering everyone.
    - Please don't clean up my mess. You'll only confuse me.
    APC 1500, Furman Rack Rider, Cambridge Audio Dac Magic Plus, Parasound P/HP 850, Adcom GTP-880, Luxman M-300, Threshold 400A Cascode, McIntosh MC2505, MC2205, MR-71, MX-113, Sony TA-3200F, Tascam 112 MKII, Sony TC-D5 Pro, Tascam CD-200, Thorens TD-147, Kenwood KT-5500, Kenwood KT-7500, Realistic Minimus Sevens, Behringer MS40s, Boston Acoustics A40s, JBL 830Ts, 'Double' Advent Loudspeakers, Klipsch KSW12 sub, Bose 901s, Polk SDA 2s, Polk SDA 1Cs
  • headrott
    edited September 2014
    Apexpro wrote: »
    headrott wrote: »
    Apexpro wrote: »
    We can TELL you anything, but for you to believe it, it takes first-hand experience. There is no other way to believe except to experience it yourself.
    By us telling you that burn in is fact MAY help convince you to experience it yourself however, which is where forums come in handy.
  • WLDock
    WLDock Posts: 3,073
    Apexpro wrote: »
    I need to quiet the back room down. Large heavy curtains will help a lot, I have a few dozen '24 egg' crates I could paint and put on the back wall, and maybe book cases on a side wall.
    Any suggestions about inexpensive wall covering material?
    Egg crates might work...but please don't do it. Make some better looking ones for yourself: http://acousticsfreq.com/blog/?p=62
    http://www.acoustimac.com/acoustic-insulation-materials/acoustic-insulation/owens-corning-acoustic-insulation/
    http://metrosupplycollc.com/Acoustical_Insulation.html
  • WLDock wrote: »
    Thank God I don't have to do the eggcrates. Thanks for the tips! I'll have to get the lady friend to do some fabric shopping for me.
  • No, egg crates didn't work way back then and they won't work now! They were only effective in a narrow frequency band, which is not what you want.
  • I'll keep using them for what God intended. Trays for reloading pistol ammo. ;)
  • Hey! The smiley face worked.
  • Msabot1
    Msabot1 Posts: 2,098
    Depends on the room you were going to use the set up in....A main room in your home I would not suggest using those....a basement studio or such would be different...that fiber material that those are pressed out of and the pattern lends itself to very good sound baffling....
  • WLDock
    WLDock Posts: 3,073
    Also, if you have bass issues don't for get bass traps.
    I plan to make some of these myself at some point.
    http://www.teresaudio.com/haven/traps/traps.html
    http://www.amerisafe.net/en/insulation-products/pipe-insulation
  • WLDock wrote: »
    Brilliant! Why didn't I think of that?!
    Toolfan66 Posts: 18,207
    WLDock wrote: »
    Thanks for the links...
    I'm in...
  • Interim report:
    I started with 16AWG O2 free stranded speaker wire as the baseline and listened to a variety of music from Jeff Beck to Bach. I used Bose 901s as the first speaker and then switched to SDA 2s and repeated the same CDs. I'm only using CDs for this test.
    After establishing the baseline I switched to Nakamachi cables. Some have said these aren't much better than the 16AWG O2 free cables and so far I have to agree. I haven't been able to tell any difference using the 901s. I'll be switching to the Polks this weekend to complete phase II.
    I received my cables from Doug yesterday and can't wait to get through with phase II and on to phase III. Doug's cables have silver connectors and are masterfully crafted. I can feel a difference in heft and have to believe they'll carry a better load and with the silver connectors make a better connection. It's hard to look at them and not immediately hook them up, but I need to be methodical about the process.
    Stay tuned.
  • For now I'll stick with the $20 dollar 16AWG O2-free with gold plated bananas, the used $70 Naks, and Doug's $250 set of twin 14AWG Canare cables with silver coated connects.
    If I can tell a difference with Doug's cables I'll consider others, but I want to finish this 3 wire test first.
    The problem with this test as I see it, is you picked 3 different cables all similar, all roughly in the same price tier, so I would expect your results to be minute as well with the Canare holding an edge above the other 2.
    If your going to do a test, and the goal of that test is to decipher if you can hear a difference, then you need 3 different cables, different price catagories, different build/design...different sound signatures.
  • If someone will lend me cables I'll definitely try different price points, but I don't have the means to spend $1,000 on a test.
    I sense I'm already being dismissed before I even finish my tests.
    Apexpro wrote: »
    Not dismissing....just suggesting you could have done better in your core selections. There's an awful lot of real estate in cables between what you have and your suggested 1000 buck cables....especially on the used market.
