Dreadnaught Avel-Lindberg 1000VA Transformer Group Buy?
Sent you an email Neil. I'll have payment out in the morning when I get off work.
Yup got it. So you're going to pay tomorrow, at which point we'll have 14 paid, and hopefully I hear from South Dakota Po. If I don't, I'm still going to put in the order for 15 units, since it's actually cheaper to order 15 than it is 14. Someone will show up in the next 12 weeks who will want it before they're actually built and shipped.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
I expect they will show up a day or two after the group buy has concluded just like the previous group buys. I know the stragglers will appreciate your consideration.
Polk should order about 50 of these to avoid broken hearts in the future.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Well I can only afford 1 at the moment but I may grab that second one as well next week.
DarqueKnight wrote: »Polk should order about 50 of these to avoid broken hearts in the future.
You know, if Al Ballard was still there he would have made that happen. Don't hold your breath now though. -
Payment sent
And also Larry make that 2 cases for me with speakon. If I can't swing 2 of the 1000 I'll settle for an 800
Confirming payment received for 14th unit. So I will definitely be ordering 15 on Monday, and assuming someone comes along and pays me for it, you'll all be getting a bit over $26 back.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
scubasteve4sq wrote: »And also Larry make that 2 cases for me with speakon. If I can't swing 2 of the 1000 I'll settle for an 800
im assuming that the 800 would fit into the same case since the 1000 is larger correct? -
Correct.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
South Dakota Po payment received. We are good to go for 15 units.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Neil,
What's the harm in waiting 1 more week, so more can "pile on" the opportunity?
The Polk purchase of 50 is quite good, but it'll prolly never happen. I will commit if it will helps to make it to 20
GAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
It's up to you guys, I'm in no rush. I have one already
Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
I am ok with waiting.Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c -
I can wait
Well, you guys get almost $50 back each if you get 5 more units.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Worth the wait in my opinion. I'm sure there are other people who will want to get in on this.
Especially considering it's been almost 2 years since the last buy.
Here are some quotes from Matthew polk to consider
"The original isolation transformer was successful at eliminating the issues of SDA with non-common ground amps but at the cost of a significant compromise of the SDA sound stage. We later figured out how to do this right with the transformer incorporated into the SRT controller.
The transformer is a 1:1 ratio and allows the L-R and R-L SDA signals to be derived while isolating the grounds of the two amp channels. The inverted portions of the SDA signals only need a bandwidth from a little below 100Hz to 1.6kHz. It's helpful if the transformer has more bandwidth on the top end since the high-end cutoff is controlled by a low-pass in the cross-over. At the low end, however, it's best if the transformer windings have a very high inductance as measured with the secondary open, around 14mh, and a very low DCR.
In the mid-range where SDA operates, the SDA drivers on one side operate in series with the SDA drivers on the other side with the signals passing through one set of SDA drivers then through the transformer and then through the set of SDA drivers on the other side. However, at low frequencies the positive part of the signal passes through the SDA drivers and is shunted directly to ground by an inductor in parallel with the transformer. The result is that the SDA drivers operate in parallel with the stereo drivers at low frequencies but operate in series with the other side to produce the SDA difference signal in the mid-range. If the DCR is too high, as it was in the original isolation transformer, it will reduce the level of the SDA signal and alter the bandwidth. If the inductance isn't high enough, also the case in the original, it will raise the low-end cutoff of the SDA signal further reducing the SDA soundstage and allow the SDA drivers to produce too much upper bass thereby muddying the sound.
The transformer in the SRT controller had a DCR around .3 ohms and an inductance around 14mh as best I recall. Current carrying capability before saturation is also an issue and was not adequate with the original. I think it was only about 3 amps which would be about 60 watts to the SDA drivers and not enough. I don't recall exactly what it was in the SRT but seem to recall something like 10 amps which would deliver about 600 watts to the SDA drivers.
As a practical matter we found the only way to get a low enough DCR was with a 1:1 toroidal transformer. These are available off the shelf but expensive. Because of the efficiency of the toroid the cores must be much larger to avoid saturation.
Hope that helps.
-msp
Yes, I did mean 5 amps. The transformer will have to handle nearly the entire amplifier output for any signal that is primarily in one channel or the other. The impedance of the sda drivers in series is around 6.5 ohms. So, a 5 amp rating will deliver up to about 160 watts to the sda drivers before saturation. The inductance determines the frequency at which the transformer will shunt low frequencies to ground allowing the sda driver to produce the same low frequency signal as the strereo driver in that cabinet. 14mh puts that point well below 100 Hz. That means that the sda signal will be preserved at full strength down to 100 Hz which is important for best imaging. Higher DC resistance just attenuates the sda signal and the bass. I think the transformer in the SRT system had a DCR of 0.3 ohms, 14mh inductance and saturation current around 7.5 amps.
-msp -
I'm pretty sure this transformer is a 10amp rating correct? The 800va is a 7amp
Either way it should provide more than enough headroom for your amplifiers on the sda dimensional drivers. -
No rushDynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
No Rush!! As I do not have speakers yet
just planning for the future. If you think you may get some SDA's in the future I would jump in. 2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
I remember seeing a post, maybe in this thread, from F1Nut, recommending that the SDA interconnect cable be the same as the stereo speaker cable. I also remember hearing or reading that some people shield the SDA interconnect cable. Opinions?
I also noticed that there are variety of female speakon connectors for case mounting. I truly have not compared to see if the hole patterns are the same. Does anyone know which type or types the Larry cases are precut for?Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
I believe the holes are all the same size because the connectors are cross compatible. Ie:you can use a speakon 2 conductor in a 4 conductor socket.
The face plates are drilled out for a D size chassis connector, but there are many choices and they are not all the same. This is the one you should use, http://www.neutrik.com/en/speakon/speakon-chassis-connectors/nl4mp-uc
It's sealed (very important at the speaker end) and high current rated unlike the rest. Make sure the cable connector is also rated for high current, such as this one, http://www.neutrik.com/en/speakon/stx-series/nlt4fx-bag
You will also need M3 (metric) screws, lock washers and nuts to properly mount the sockets. I recommend stainless steel. They are available from Fastenal.
To mount the transformer use either a brass or stainless steel bolt, fender washer, lock washer and nut.recommending that the SDA interconnect cable be the same as the stereo speaker cable.
Only makes sense to me, but not required.I also remember hearing or reading that some people shield the SDA interconnect cable.
Speaker cables are generally not shielded. I believe you are thinking of the original AI-1, which sounds a lot better wrapped in ten layers of aluminum foil, aka the baked potato. -
Forgot to mention, these flanges give it a nice finished look. http://www.neutrik.com/en/speakon/speakon-chassis-connectors-accessories/scdp
Great information. Thank you so much!Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
I used this SpeakON on my last dreadnaught: http://www.parts-express.com/neutrik-nlt4mp-bag-speakon-stx-4-pole-male-chassis-connector-black-chrome-metal-housing--092-340Home Theater/2 Channel:
dhsspeakerservice.com/ -
Here's where we are. We have 15 paid units. GlennDog has committed to a unit if it gets us to 20, so we're basically at 16.
The 20-unit price point is the same as the 15-unit price point, more extreme in fact. It is cheaper to buy 20 units than it is to buy 19, as the price for all 20 units drops by another $22.95. So if we get three more units besides GlennDog, we might as well order 20.
I just spoke to Melanie, and because they kick off the work order for the cores fairly quickly after the order is placed, it's not really possible to add to an existing order while holding your place in the manufacturing queue. Since everyone seems comfortable with a wait, I suggest we give it another week to see if we can get any more interest so we can bump the quantity up to 20. Once we finalize the order, everyone will be getting a refund from me.
If we can't get to 20, the people who jump in at least are getting it at the discounted 15-unit price point.
So..... Who else wants in? Unit price is now $266.14 plus shipping.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
GlennDog, do you definitely want in? Or are you just looking to get in if we get to 20 units?Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Oh you've already mucked it up just fine.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
I am ok with waiting, really wish we could get 25.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
