A slightly different take on the Dreadnought
13»
  • nspindel
    nspindel Posts: 5,343
    edited December 2013
    I'm guessing you typed that from your cell phone! I take it you meant "hardware to mount them." :lol:
    F1nut Posts: 51,749
    nspindel wrote: »
    The 4 pole versions are superior, they are built better and have a higher current rating. Why aren't you doing both ends?
    Do the chassis connectors include the screws I'll need?
    No, you will need M3 (metric) screws, nuts and lock washers for the panel mount. Fastnel carries them in stainless steel. They are cheap and there's no minimum order.
  • BlueFox
    BlueFox Posts: 15,251
    zane77 wrote: »
    Those parts will work perfectly, just add the ward ware to month them.
    nspindel wrote: »
    Sometimes "smart" phones are pretty stupid. :smile:
  • nspindel
    Ok, I will grab the 4-pole versions. Thanks for the tip. Not doing both ends because the Dreadnaught is already built with binding posts - using Speakons on the Dreadnaught side would mean drilling holes large enough to accommodate them, when the chassis already has holes drilled for the 4 binding posts. On the Dreadnaught side, I'm using bananas, which works just fine. I think the big advantage of using the Speakon connector will be on the speaker side, so I can eliminate the need for the spade.
  • nspindel
    Ok great, thank you!
  • nspindel
    Thanks again Jesse, ordered the 4-pole versions - NL4FX and NL4MP, along with the SCDP gaskets from Parts Express.
    I'm thinking these are what I need for the fasteners?
    http://www.fastenal.com/web/products/details/40924
    http://www.fastenal.com/web/products/details/40247
    http://www.fastenal.com/web/products/details/40142
  • vcwatkins
    vcwatkins Posts: 1,993
    Trey,
    Do you have more of the round 4-bp/1-speakon-hole plates like in your pic above (for 1.2's)? I need a pair, but didn't see them listed on your site. Scratch'n'dent is okay as well, if available.
    Thanks,
    Craig
    F1nut Posts: 51,749
    nspindel wrote: »
    Those screws are too short.
    Using the SKU's
    XM2510016A20000
    MN2510000A20000
    ML6330000A20000
    VR3 Posts: 29,425
    I have them available. They are new stock too :)
    Contact through the forum is very spotty for me. vr3mods@gmail.com
    Talk to you soon! :)
    F1nut Posts: 51,749
    edited June 2016
    An update on this thread. My Dreadnought sits on carpet and always leaned a little bit. Well, I finally got around to doing something about it by adding aluminum outriggers with stainless steel spikes. It now sits perfectly level. The cap nuts are temporary, I have stainless steel knurled knobs arriving Monday.
    Post edited by F1nut on
  • Mike Reeter
    Mike Reeter Posts: 4,315
    The "Finishing Touch" looks good Jesse!
  • GlennDog
    GlennDog Posts: 3,152
    Dang, Dog
    You never stop improving ...Nice work!
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    nooshinjohn Posts: 25,915
    You wouldn't by any chance have an extra one of these laying around, would you?
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,767
    So this is the thread where the idea for Speakon connectors for the SDA cable originated. I should have known Jessie was the originator. I also like the outriggers.
    I am glad you updated the thread as I had not read it.
    Harry / Marietta GA
  • gimpod
    gimpod Posts: 1,793
    That going to look killer with the stainless steel knurled knobs and as usual very nice job Jesse.
    Hey @F1nut I even speeled your name right this time. :blush:
    F1nut Posts: 51,749
    Sorry John, I don't.
    F1nut Posts: 51,749
    gimpod wrote: »
    'bout damn time! ;)
    F1nut Posts: 51,749
    The stainless steel knurled knobs came in. They were a bit too natural, so I polished them.
  • westmassguy
    westmassguy Posts: 6,850
    Glad you got you're.....................knobs polished Jesse :wink:
    Looks great.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    Toolfan66 Posts: 18,040
    Looks fantastic!!
  • machone
    machone Posts: 1,558
    Looks great!
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Fantastic work as usual. I'm skeptical about those old, old, speakers being worth the effort though. ;)
    F1nut Posts: 51,749
    I realized I made a mistake in my OP that needs to be corrected. The socket I used is the NL4MP-UC not the BAG version.
    This is the one, http://www.neutrik.com/en/speakon/speakon-chassis-connectors/nl4mp-uc
  • monepolk
    monepolk Posts: 1,154
    Good, I got the right one.
    Thread started 6 years ago?? Holy Crap were getting old...
