Basement Remodel/Theater Build
Nice setup. Where ya putting the LSiC ? Real nice basement conversion. Start to finish.
Thanks! I was planning on putting all 3 subs in and putting the LSiC on top of the center sub, but... it is looking like 2 subs is going to be a much better fit and still PLENTY of low end. After getting the screen and the mains placed, I just don't think I can fit all 3 without it being a major pain... I will probably go to Skylan, the company who made my other stands, and get something made up for the LSiC.
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
Outstanding!
One suggestion I would have...and please don't take this personally or think it's absolutely necessary...but I would have a
shaker with some dry gin martinis in there somewhere. But that's just me.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
No basements here in Dallas but would love to have one.
What is that you put on the floor? Looks like squares of plywood. Do you glue them down and then put carpet on top?
Moisture barrier ?
BTW, looks great !Speakers: SDA-1C (most all the goodies)
Outstanding!
Not sure why I would take that personally? Are you thinking a picture on the wall? Or the actual thing
I thought about a bar down there, but there really wasn't any room with everything else we are going to do with the room. But I will definitely have a refrigerator on the other side of the wall stocked with drinks :biggrin:
Moisture barrier ?
BTW, looks great !
The floor tiles are called dricore. They have HDPE on the bottom in a waffle grid pattern that lifts the tiles off the floor to create an area for moisture to evaporate or a minimal amount of water to flow. It also helps break the cold transfer from the concrete into the floor. It makes a huge difference.
I will say, after getting my projector back up, I really want to go 1080p and something with more lumens... Properly configured the Sharp only puts out about 350-400 lumens if I remember correctly. The picture quality is amazing, but I could use a little more output. But... That will have to wait a few months! I need to save up some $$ and recover from this over budget project!
dcmartinpc wrote: »I will say, after getting my projector back up, I really want to go 1080p and something with more lumens... Properly configured the Sharp only puts out about 350-400 lumens if I remember correctly. The picture quality is amazing, but I could use a little more output. But... That will have to wait a few months! I need to save up some $$ and recover from this over budget project!
Don
Lookin' good, man! Can you black out that window back there to help the projector???2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
double post2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
dcmartinpc wrote: »Not sure why I would take that personally? Are you thinking a picture on the wall? Or the actual thing
Don
Just joking around. Guess I had too much wine for dinner.
I was recommending the real thing (hehe).
Cheers!
CraigBeach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Cheers!
Craig
I could definitely be down with that!!! I am sure I will be enjoying a few adult beverages down there once all is said and done!!!
falconcry72 wrote: »Lookin' good, man! Can you black out that window back there to help the projector???
I am actually going to build some frames with blackout cloth on them to completely block them off... Just haven't had a chance yet.
In regards to the projector, I have to be extremely careful what I choose because this Sharp XV-Z12000U is one of the most cinematic projectors I have ever seen! The motion is so smooth and natural and still puts out an amazing picture! It was $12k when it came out several years ago, so it better be!!! Although I paid much much much less for it used!!!
dcmartinpc wrote: »In regards to the projector, I have to be extremely careful what I choose because this Sharp XV-Z12000U is one of the most cinematic projectors I have ever seen! The motion is so smooth and natural and still puts out an amazing picture! It was $12k when it came out several years ago, so it better be!!! Although I paid much much much less for it used!!!
Don
Don I think your overthinking a new PJ lol. If it was me, I would get everything installed and then start thinking accoustic treatments you can build yourself.
IMHO your like 90% to where you want to be all the way around. I would look at accoustic treatments, modding your current LSi's and be done with it.
There is always something better out there to chase, but that last 10% will cost you 90% more than all the gear you have now lol...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Don I think your overthinking a new PJ lol. If it was me, I would get everything installed and then start thinking accoustic treatments you can build yourself.
I know I know.... The projector is different though
I do think I am going to get in touch with VR3 to have him mod my 9s and my LSiC and go from there.
But the PJ I am looking at is a little over 2k and it won't be for another 6 months or so.
Good Day,
Great job on your basement reno the bold color looks fantastic.
We had done ours a couple of years ago it?s a lot of work and I can tell from the pictures you put a lot of effort into it.
If I could make one suggestion it would be to paint the closet door behind the TV / Screen the same color as the walls.
Our house is a spilt level and we had closed in the space underneath the stairs for some storage area. It?s little over 4? high; so to grain access I had cut a door down to fit and trimmed it out painted it white to match the other doors. Well we found it kind of distracting so we painted it the same color as the walls and it blends in to the point you hardly notice it.
Also I like the way you build your gear rack under the stairs looks perfect great use of space.
Cheers Roger -
dcmartinpc wrote: »I know I know.... The projector is different though
LOL, just have him do the 7 channel LSi, LSi 9's, LSiC, LSi F/X, LSi 7's.dcmartinpc wrote: »But the PJ I am looking at is a little over 2k and it won't be for another 6 months or so.
Well if you sell the Kuro your over halfway there
. JK I know you wouldnt sell that TV for a long long long time... "....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »LOL, just have him do the 7 channel LSi, LSi 9's, LSiC, LSi F/X, LSi 7's.
Only an idiot would sell there Kuro:cheesygrin: -
Good Day,
Cheers Roger
I like the idea about painting the door. I'll have to run it by the wife
Its been a long project, and even longer waiting to do it!! But I'm almost there!
Very nice job Don and nice to see you posting again, But I have to agree that white door behind the TV looks out of place and might be a distraction while watching TV. JMO.
Glad to here those crossovers for your SDA SRS 2's are finely breaking in, It dose take awhile don't it.
BTW: I know it's a bit late but I think you forgot some things, A hide-a-way stage with flashing lights a disco ball and stripper pole for when the wife and kid aren't home and of course some kind of black velvet painting. I think it's federal law in order to keep your man card. :razz::cheesygrin:“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
dcmartinpc wrote: »I am actually going to build some frames with blackout cloth on them to completely block them off... Just haven't had a chance yet.
Don
That will definitely help. And If you can make that door darker, it would help a lot as well.design is where science and art break even. -
Carpet is installed!!! I was a bit surprised at the difference it made it the room, but it really took it to another level. I have noticed that I do definitely need some basic room treatments down here though
I took some pics of the empty room and then one with some gear setup with my cell phone so excuse the quality. Anyways, here they are! I can't wait to get my second sub and the rest of my speakers in place!
Don
That sub is huge. Definitely got to get my ears on that sucka.
And I'm the psycho who is going to run 2 of them!!!!Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
What's the dimensions of the room?
Rough dimensions of the entire room are 32x15. Minus the stairs and a bathroom. The ceilings are 7.5 feet.
Damn. That's a big sub. Cabinet looks taller then the TV!
You don't need the Skylan stands. Just use the subs lol"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
EndersShadow wrote: »You don't need the Skylan stands. Just use the subs lol
I was actually thinking of just lying a board across the subs with some blue tack and calling it a day!!!
Got any close up pics or better pics of the sub w/ passives? Running dual TC sounds myself just wish they were the 5400 or 5100.
