Basement Remodel/Theater Build
2
  • chumlie
    chumlie Posts: 8,658
    edited May 2012
    Nice setup. Where ya putting the LSiC ? Real nice basement conversion. Start to finish.
  • dcmartinpc
    dcmartinpc Posts: 844
    edited May 2012
    chumlie wrote: »
    Thanks! I was planning on putting all 3 subs in and putting the LSiC on top of the center sub, but... it is looking like 2 subs is going to be a much better fit and still PLENTY of low end. After getting the screen and the mains placed, I just don't think I can fit all 3 without it being a major pain... I will probably go to Skylan, the company who made my other stands, and get something made up for the LSiC.
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
  • vcwatkins
    vcwatkins Posts: 1,992
    edited May 2012
    Outstanding!
    One suggestion I would have...and please don't take this personally or think it's absolutely necessary...but I would have a
    shaker with some dry gin martinis in there somewhere. But that's just me.
  • thsmith
    thsmith Posts: 6,082
    edited May 2012
    No basements here in Dallas but would love to have one.
    What is that you put on the floor? Looks like squares of plywood. Do you glue them down and then put carpet on top?
    Moisture barrier ?
    BTW, looks great !
  • dcmartinpc
    edited May 2012
    vcwatkins wrote: »
    Outstanding!
    Not sure why I would take that personally? Are you thinking a picture on the wall? Or the actual thing :smile: I thought about a bar down there, but there really wasn't any room with everything else we are going to do with the room. But I will definitely have a refrigerator on the other side of the wall stocked with drinks :biggrin:
    Don
  • dcmartinpc
    edited May 2012
    thsmith wrote: »
    Moisture barrier ?
    BTW, looks great !
    The floor tiles are called dricore. They have HDPE on the bottom in a waffle grid pattern that lifts the tiles off the floor to create an area for moisture to evaporate or a minimal amount of water to flow. It also helps break the cold transfer from the concrete into the floor. It makes a huge difference.
    Don
  • dcmartinpc
    edited May 2012
    I will say, after getting my projector back up, I really want to go 1080p and something with more lumens... Properly configured the Sharp only puts out about 350-400 lumens if I remember correctly. The picture quality is amazing, but I could use a little more output. But... That will have to wait a few months! I need to save up some $$ and recover from this over budget project!
    Don
  • falconcry72
    falconcry72 Posts: 3,580
    edited May 2012
    dcmartinpc wrote: »
    Don
    Lookin' good, man! Can you black out that window back there to help the projector???
  • falconcry72
    edited May 2012
    double post
  • vcwatkins
    edited May 2012
    dcmartinpc wrote: »
    Don
    Just joking around. Guess I had too much wine for dinner.
    I was recommending the real thing (hehe).
    Cheers!
    Craig
  • dcmartinpc
    edited May 2012
    vcwatkins wrote: »
    Cheers!
    Craig
    I could definitely be down with that!!! I am sure I will be enjoying a few adult beverages down there once all is said and done!!!
    Don
  • dcmartinpc
    edited May 2012
    I am actually going to build some frames with blackout cloth on them to completely block them off... Just haven't had a chance yet.
    Don
  • dcmartinpc
    edited May 2012
    In regards to the projector, I have to be extremely careful what I choose because this Sharp XV-Z12000U is one of the most cinematic projectors I have ever seen! The motion is so smooth and natural and still puts out an amazing picture! It was $12k when it came out several years ago, so it better be!!! Although I paid much much much less for it used!!!
    Don
    EndersShadow Posts: 17,713
    edited May 2012
    dcmartinpc wrote: »
    Don
    Don I think your overthinking a new PJ lol. If it was me, I would get everything installed and then start thinking accoustic treatments you can build yourself.
    IMHO your like 90% to where you want to be all the way around. I would look at accoustic treatments, modding your current LSi's and be done with it.
    There is always something better out there to chase, but that last 10% will cost you 90% more than all the gear you have now lol....
  • dcmartinpc
    edited May 2012
    I know I know.... The projector is different though :smile: I do think I am going to get in touch with VR3 to have him mod my 9s and my LSiC and go from there.
    But the PJ I am looking at is a little over 2k and it won't be for another 6 months or so.
    Don
  • polk500
    polk500 Posts: 1,171
    edited May 2012
    Good Day,
    Great job on your basement reno the bold color looks fantastic.
    We had done ours a couple of years ago it?s a lot of work and I can tell from the pictures you put a lot of effort into it.
    If I could make one suggestion it would be to paint the closet door behind the TV / Screen the same color as the walls.
    Our house is a spilt level and we had closed in the space underneath the stairs for some storage area. It?s little over 4? high; so to grain access I had cut a door down to fit and trimmed it out painted it white to match the other doors. Well we found it kind of distracting so we painted it the same color as the walls and it blends in to the point you hardly notice it.
    Also I like the way you build your gear rack under the stairs looks perfect great use of space.
    Cheers Roger
    edited May 2012
    dcmartinpc wrote: »
    LOL, just have him do the 7 channel LSi, LSi 9's, LSiC, LSi F/X, LSi 7's.
    dcmartinpc wrote: »
    Well if you sell the Kuro your over halfway there :wink:. JK I know you wouldnt sell that TV for a long long long time...
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2012
    Only an idiot would sell there Kuro:cheesygrin:
  • dcmartinpc
    edited May 2012
    polk500 wrote: »
    Good Day,
    Cheers Roger
    I like the idea about painting the door. I'll have to run it by the wife :smile:
    Its been a long project, and even longer waiting to do it!! But I'm almost there!
    Don
  • gimpod
    gimpod Posts: 1,793
    edited May 2012
    Very nice job Don and nice to see you posting again, But I have to agree that white door behind the TV looks out of place and might be a distraction while watching TV. JMO.
    Glad to here those crossovers for your SDA SRS 2's are finely breaking in, It dose take awhile don't it.
    BTW: I know it's a bit late but I think you forgot some things, A hide-a-way stage with flashing lights a disco ball and stripper pole for when the wife and kid aren't home and of course some kind of black velvet painting. I think it's federal law in order to keep your man card. :razz::cheesygrin:
  • newrival
    newrival Posts: 2,016
    edited May 2012
    dcmartinpc wrote: »
    Don
    That will definitely help. And If you can make that door darker, it would help a lot as well.
  • dcmartinpc
    edited May 2012
    Carpet is installed!!! I was a bit surprised at the difference it made it the room, but it really took it to another level. I have noticed that I do definitely need some basic room treatments down here though :smile:
    I took some pics of the empty room and then one with some gear setup with my cell phone so excuse the quality. Anyways, here they are! I can't wait to get my second sub and the rest of my speakers in place!
    Don
  • leroyjr1
    edited May 2012
    That sub is huge. Definitely got to get my ears on that sucka.
  • dcmartinpc
    edited May 2012
    leroyjr1 wrote: »
    And I'm the psycho who is going to run 2 of them!!!!
  • leroyjr1
    edited May 2012
    What's the dimensions of the room?
  • dcmartinpc
    edited May 2012
    leroyjr1 wrote: »
    Rough dimensions of the entire room are 32x15. Minus the stairs and a bathroom. The ceilings are 7.5 feet.
    Don
  • Drenis
    Drenis Posts: 2,871
    edited May 2012
    Damn. That's a big sub. Cabinet looks taller then the TV!
    edited May 2012
    You don't need the Skylan stands. Just use the subs lol
  • dcmartinpc
    edited May 2012
    I was actually thinking of just lying a board across the subs with some blue tack and calling it a day!!!
    Don
  • leroyjr1
    edited May 2012
    Got any close up pics or better pics of the sub w/ passives? Running dual TC sounds myself just wish they were the 5400 or 5100.
