New horn speakers are in!
edited September 2012 in 2 Channel Audio
I had to save and wait, but the new speakers are finally in the house! Dana and Kevin from Soniphase (a local horn speaker building company) helped me piece together an awesome new pair of speakers as I run everything 2-channel. The bass bins are cherry wood, patiented corner horns loaded with custom Eminence 15" woofers, and strong down to 35Hz. The mids are an Eminence PSD:3006 loaded in a patiented Smith horn, with a custom Eminence tweeter mounted under the mid. The crossover is mounted in the mid/high unit, and all the horns are wood and built right here in the Pacific Northwest.
Dana has been helping me tune the speakers now that they are in the room and very room dependant; as corner horns are with phase and such. I'm just about finished matching the levels of the highs/mids to the woofer, and the overall system sensitivity will be around 105db.
The corner horn bass is taking a little to get used to coming from direct radiating Klipschs, and a little less punchy then I expected. However, I haven't found any music yet that they can't handle or keep up with. Symphony music is amazing detailed with great dynamics, and no mud or compression of detail or instruments.
I'll post more pictures of the detailed parts and update as I continue to tune the speakers, but I can't be happier paired with the 6L6 integrated amp.
Post edited by zingo on
Welcome!
«13456
    edited May 2012
    zingo wrote: »
    ...the overall system sensitivity will be around 105db.
    Wow!
    They look great. Have fun gettin'em tuned up. Got any close up pics of the wood?
    edited May 2012
    Looks great! Congrats!
    edited May 2012
    They definitely have panache...
    edited May 2012
    I'll take a better picture of the finish of the bass bins as they are awesome; dark stained and polished cherry. The tops horns are black, but it works with the overall look. I actually have tops that can go over the top horns also finished in cherry, that would make the speakers look similar to Klipschorns. However, they do make the speakers look a lot bigger, and stand taller.
    edited May 2012
    That's a fine looking set of speakers you have there. I bet the bass on them is thunderous with the 15's
    edited May 2012
    beautiful workmanship. nice
    2ch.
    RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT
    Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    edited May 2012
    those look awesome Jake... congrats ;)
    After GTG party @ jake's :mrgreen:
    edited May 2012
    Why are they mounted to the ceiling?? LOL!!
    I love horns...
    edited May 2012
    On my PC the picture is correct, on my iPhone it's upside down. I have no idea...
    edited May 2012
    Wow! That's what I'm talking about. Full horn systems kick so much ****. At 105db sensitivity, it's time to look at some SET, especially those using DHT's ;-).
    I think you'll enjoy the bass horn more than direct radiator. I also started with Klipsch's direct radiator bass (RF series and Cornwall) before getting the La Scala. Horn loaded bass is superior to my ears.
    Thanks for sharing a pic. They look fantastic. Enjoy the new speakers and congrats!
    edited May 2012
    zingo wrote: »
    I'm on my iPad ..
    edited May 2012
    105 dB sensitivity :eek::eek: the speakers look amazing!
    edited May 2012
    organ wrote: »
    I found a semi-local guy who builds single-ended 6L6 amps that run a single 6L6 per channel, and a single 6922 for the input. Being that I really like my PP 6L6 amp now, I'm going to give that one a try.
    edited May 2012
    organ wrote: »
    The bass is very different than the direct radiating, but I liked the sound of my uncle's Klipschorns, so thought I'd go for something similar; obviously better. The bass is funny because it's not as punchy as I would have hoped with pop music and similar, but it is impressively over powering when it comes to classical music and "real instruments". I was listening to Josh Groban this morning where he had a symphony behind him and the effect was awesome! His voice was clear and completely unaffected by the booming music going on behind him and vibrating the room. The things I love about the speakers top to bottom is that they never sound compressed, or stressed; they always sound very natural and effortless no matter the material or volume.
    edited May 2012
    Those are some really nice looking speakers. Bet vinyl sounds great with those tubes and horns.
    edited May 2012
    Very nice speakers,I love it your dog gets a prime spot right there with you.Dan
    edited May 2012
    edited May 2012
    zingo wrote: »
    That's what I love about big horns. No compression and sound is effortless.
    I think the reason you're not getting as much punch with pop music is due to the extremely high efficiency. It makes everything much more revealing. So the compression used in most music can easily be heard with different materials. Good pop recordings should sound superb,
    You're right about "real instruments". I find this is the area where horn loaded bass really shine. It's so much more robust and powerful. I'm on my second pair of horn loaded bass and love it.
    edited May 2012
    organ wrote: »
    I respectfully disagree, it's more about the speaker's FR and interaction with the room than overall efficiency. Moving those coffins around a bit may help.
    I'm not negging high efficiency as it does have more positives than trade offs...if you have the space. I'm gunning for(real world) low to mid 90's for my next build.
    edited May 2012
    ... SE 2A3... or, with 105 dB sensitivity, even SE 45 :-)
    edited May 2012
    ^ ohhhh that's perty!
    Congrats Jake! I bet those sound sweet!
    --Gary--
    edited May 2012
    ... SE 2A3... or, with 105 dB sensitivity, even 45.
    I'm sure those would sound great, and no issue with too little power. Have you ever heard a SE 6L6?
    edited May 2012
    very cool stuff Zingo, good to see a little variety around here. I don't listen to horns very much but I'm sure they sound great!
    edited May 2012
    Face wrote: »
    That's cool. Just something I noticed with my rig. I'm on my second pair of bass loaded horns and the typical commercial pop stuff just sounds too compressed. But good pop recordings like K.D. Lang sounds fantastic.
    You're right, I wasn't thinking about room interaction when posting that. Zingo's room will have a big impact on overall sound because those bass horns uses the walls in his room as horn extensions like the Klipschorn. But judging by the pic, he does have a pretty good spot for them. Not easy to play around because he needs corners for them.
    edited May 2012
    Currently the woofers are running on motorboards with a 3" mouth. I have a second set of boards that have a 6" (I believe) mouth that I'm going to try. Dana thought that might add more punch to the bottom end. We will see...
    edited May 2012
    Cool. Keep us posted.
    edited May 2012
    Will do. I'm unsure how the wider mouths will effect the top end as it is supposed to raise it, but I'll have to see. The woofer is run up to 600Hz right now I believe, but obviously you don't know the effect until you try it.
    Custom horns are way too much fun. :razz:
    edited May 2012
    I like horns a lot and you have something very special there. In many ways similar to the system in my sunroom. I made custom CNC mid horns based on a JBL 2397. Wood is 1" buginga and the fins are CNC aluminum.
    edited May 2012
    Wardsweb wrote: »
    I think that little pic you posted is just the tip of the iceberg. Don't you have some massive horns in your living room not to mention high end audio gear in every room in your house. I think your bathroom rig is probably better than what I will achieve in my lifetime lol
    edited May 2012
    The picture posted shows horns similar to Jake's Soniphase. Both three way systems using horns for mids and highs. I have a conventional bass bin while he is using a corner loaded folded bass horn. His mid horn varies a little from mine as the fins on his run the full length of the horn and the horn does not flare in the vertical plane. A horn system like this will be very open, airy, a bit forward and a lot of depth. It will be very articulate with speed and a "real" sound, like you're there.
Welcome!
Welcome!
