The reason why receivers cant work for two channel music reproduction
1246710
  • mantis
    mantis Posts: 17,561
    edited May 2012
    Hearing is just fine. No mistakes here, my system sounds "stellar" & there's no need for separates in my book. Just because you feel the need for separates doesn't mean others simply follow suit. I can't believe how you guys just assume that separates equal better sound. Total hogwash.
    I gotta take that one step further as I have done a few tests that shocked the hell out of me.
    I'd challenge anyone to a blind test using a few different receivers , pre and amp , then using some of the receivers as a preamp into said amps.
    I own Intergraded , amps , receivers of all kinds of levels and as much differences there are between them all , you'll be surprised what preamp or receiver makes for the best pre. using internal amps on some receivers don't sound as good in 2 channel as a outboard amp does depending on how hard given speakers are to drive. It's also a balance as to which IF said speakers will gain a noticeable difference using a external amp or pre and amp .
    It's all a matter of synergy in ones given system. There is no absolute. Some pre's suck and so do a lot of receivers. Some amps suck as well.
    Dan
  • gdb
    gdb Posts: 6,012
    edited May 2012
    heiney9 wrote: »
    More like on the edge of the looney bin.
    Awwww, you butthurt now ?
  • gdb
    gdb Posts: 6,012
    edited May 2012
    I've got a 1985 vintage, mos fet, Kyocera R-851 receiver That I will happily put up against many separates of the same era & price point. (approx. $800.00 IIRC) A curtain and a chair would tell the story.:wink:
  • 62caddy
    62caddy Posts: 137
    edited May 2012
    After listening to literally dozens of different 2 channel systems that utilized both seperates and receivers, my experience has been that overall system performance rests with innumerable other variables that had little to do with the number chassis in the setup.
    Keep in mind none of the receivers were manufacturered past the early 1990s and most were either TOL or near TOL in their day. None were AVRs. Again, few would dispute that manufacturers tend to best of what they've got to offer in seperates however there were a number of excellent 2-channel receivers that more than held their own against a comparable stack of seperates while costing significantly less and taking up less real estate.
    Once again, I feel that to denigrate an entire subcategory of gear is incredibly simplistic, in poor taste and insulting to the judgement of those who choose that route.
    Main:
    McIntosh: MC 2155, MC 2125(x2), MR 80, C 32, MQ 101; Snell J7; Polk: RTiA7, RTiA9;
    Pioneer PL-518; A/T 440 MLa; Yamaha CD
    Vintage:
    McIntosh: MX110Z, MC 2505, MC 240, Thorens TD 145; Shure V15III; Altec 14, Boston T1000; Yamaha CDX 393 CD; Yamaha Cass
  • newrival
    newrival Posts: 2,016
    edited May 2012
    Stellar two channel and receiver in the same sentence.......hilarious!
    There are plenty of "stellar" receivers and reasons why a person would want one of them instead of stereo separates.
    This place is going down the toliet, fast.
    don't be so hard on yourself
  • sucks2beme
    sucks2beme Posts: 5,691
    edited May 2012
    Nothing like limiting the competition!
    Like I said, most receivers aren't that good. But there are some that are.
    Hardly the norm. And HT stuff gets even harder to find as far as holding their own.
    It comes down to the point that most makers of gear put their best efforts into
    separates. Receivers aren't normally where they apply the good stuff. I'm sure
    anyone could build a great receiver. But for the most part, they don't.
    Kind of like a 4 door sports car.
  • newrival
    edited May 2012
    sucks2beme wrote: »
    I don't think companies are putting better effort into their separates. I think they put as much effort into their AVRs. They just have to spread out the same amount of money over a much larger number of components and functions.
    Based on Trey's original post, I take the argument to apply Pre/Pros, as he asserts that "All the freaking processing and adjustments and room correction BS is a musical tone sucker..." is the reason AVRs cannot "work for two channel music reproduction."
    There is no one here that can make an argument that no Pre/Pro can perform with top tier 2 channel preamps.
    F1nut Posts: 52,005
    edited May 2012
    Receivers are consumer grade electronics. If you think otherwise, you're delusional or you've just never heard what stellar really is.
  • 62caddy
    62caddy Posts: 137
    edited May 2012
    Unless specifically constructed for commercial/industry use, everything is consumer grade electronics.
    And I am not delusional, sir.
    Main:
    Vintage:
    nooshinjohn Posts: 26,002
    edited May 2012
    gdb wrote: »
    Who's got the ban-hammer today?
    F1nut Posts: 52,005
    edited May 2012
    62caddy wrote: »
    Commercial/industry use would be considered pro gear. Your Pioneer/Yamaha/MAC 4300 would be considered consumer grade. Your other Mac gear could be considered audiophile grade. I hope that clears up your misunderstanding.
    So, you've just never heard what stellar really is?
  • gdb
    gdb Posts: 6,012
    edited May 2012
    I wonder if it's Senator McCarthy ?! FYI that term has been used generously on here by the "family, core members" so, it must be permissible.
  • 62caddy
    62caddy Posts: 137
    edited May 2012
    I've heard the McIntosh 2Kw reference system which to my knowledge, is classified as consumer electronics. High-end consumer electronics but consumer electronics, nevertheless. Would I compare what I've got to that? Of course not.
    After decades of following hi-fi, I've yet to hear of a consensus of what constitutes "audiophile grade" or not, let alone an industry accepted definition. In my humble opinion, it's a distinction that ought not to be made for innumerable reasons.
    I had tried a fully refreshed McIntosh C32 preamp against the pre of the 4300 and really didn't hear much of a difference, contrary to my expectations. Maybe the rest of the system isn't good enough- I dunno. At any rate, I'm extremely satisfied with the level of performance and utility of the 4300 for the time being- particularly relative to its cost vs that of seperates of the same level of quality.
    Main:
    Vintage:
  • sucks2beme
    edited May 2012
    newrival wrote: »
    Agreed. But again, few are doing it. Most consumers want ease of use and lots of channels.
    And that's what they getfor their money. I know of a number of integrated amps that are great.
    Not many receivers fall into this group Certainly not HT stuff as a rule. I prefer to look at the
    electronics on their own merit, not by what they are.
    heiney9 Posts: 25,506
    edited May 2012
    mantis wrote: »
    Blinded, unblinded, one legged..........I'll put my separates rig up against any receiver and there will be no contest, end of story.
  • 62caddy
    62caddy Posts: 137
    edited May 2012
    heiney9 wrote: »
    The point being that the mere presence of seperates is hardly a passport to perfection any more than having a receiver is a guarantee of mediocrity.
    Point 2: It's all relative to cost: $20,000 worth of seperates vs a typical receiver is not an equal comparison. (Not to suggest that's what your's cost)
    Main:
    Vintage:
  • pearsall001
    pearsall001 Posts: 5,328
    edited May 2012
    Boy oh boy, you just can't help yourself can you?????
    heiney9 wrote: »
    You're on!!!!! My place or yours? Now don't go kicking & screaming when you flunk the test because you always can fall back on the premis that those tests are always invalid...pretty much a built in excuse to CYA.
    edited May 2012
    My place and I'll even supply the beer and munchies and burn something on the grill. There will be no flunking, I can assure you of that. I think if I can discern between which tubes are playing, I can pick out a receiver vs. my separates pretty handily.
  • pearsall001
    edited May 2012
    heiney9 wrote: »
    Split the airfare?
    edited May 2012
    Split the airfare?
    All kidding an peacocking aside, I think this would be a lot of fun. If I was independently wealthy I'd pick up 1/2 the airfare.
  • gp4jesus
    gp4jesus Posts: 2,019
    edited May 2012
    I'm satisfied w/my 2 channel/music performance.
    When I receive my tax refund, I'll finish my speaker mods w/YOUR advice for XO parts and move up to Happy!
    Tony
    *all connected w/Premiere ICs
  • rebuy
    rebuy Posts: 694
    edited May 2012
    IMHO you can get very good performance from some AVR's and receivers for two channel music. My Onkyo does sound better in stereo for music than it does with sound processing in 5.1. The stereo performance of the Onkyo does not come close to the sound quality of separates. A good pre amp and amp would put this 100 WPC Onkyo to shame. I would take a simple low power tube system any day over a SS amp.
    On this subject, I knew I was compromising by buying an Onkyo for SQ in music.
    It has always been my goal when picking a SS device to get one that has more a tube type sound for better sound quality.
  • 62caddy
    62caddy Posts: 137
    edited May 2012
    We're all after the same goal and the roads there are infinite.
    Whatever path is chosen revolves around dozens of criteria that vary from one individual to another.
    Generally speaking, I have a big problem with universal affirmative statements which are flawed more often than not.
    H9- I'd be more than happy to extend the same generous invitation if you're ever in the Scranton PA area. :)
    Main:
    Vintage:
  • Face
    Face Posts: 14,340
    edited May 2012
    62caddy wrote: »
    Yes, but compare either of those to a C48 or MA6600 and there will be a substantial difference.
  • 62caddy
    62caddy Posts: 137
    edited May 2012
    Face wrote: »
    Point of that was that some would call the C32 "audiophile grade" but not the MAC.
    The MC 2125 doesn't even have anything over the 4300's amp- IMHO.
    Main:
    Vintage:
  • Face
    Face Posts: 14,340
    edited May 2012
    I would hope not, the 2125 doesn't sound great at all. As for the C32...calling it audiophile grade would be very subjective.
  • Syndil
    Syndil Posts: 1,582
    edited May 2012
    gdb wrote: »
    Blasphemer! Burn him at the stake!
  • pearsall001
    edited May 2012
    heiney9 wrote: »
    It would be a lot of fun. I'm with you, airfare ain't cheap now a days. Maybe we could get Jesse to ainte up!!!!! :razz:
  • 62caddy
    62caddy Posts: 137
    edited May 2012
    Face wrote: »
    You've omitted the all-important part, "to me".
    **I've not been on Club Polk very long yet I'm truly saddened by the amount of elitism and closed-mindedness I've observed here coming from certain members. It is for this reason I've limited my participation in this forum. Finding this thread particularly in need for clarification, I chose to participate. During the discussion I've been told: Some of my gear is not "audiophile grade" (whatever that is); receivers "suck"; and finally the above statement that [my amp] "doesn't sound great at all."
    Well gentlemen- the only thing that sucks around here is the attitude of a few of which I've had more than enough. With that I think I'll be moving along.
    Main:
    Vintage:
  • Face
    Face Posts: 14,340
    edited May 2012
    Ah, I should have looked at your signature first, I apologize.
    For what you could sell your 2105 for, you could pick up a 2125 or similar for not much more coin and get much better sound. Each generation from Mac was a marked improvement, I've owned a 250, 2105, 2125, 7270, MX115, MX119, plus a few other models.
