New amp with minimal improvement
Stilly74
Stilly74 Posts: 194
edited February 2012 in Electronics
Well I have been powering my speakers just off the receiver and recently decided to get a separate amp to help power them.
I have a onkyo HT-RC 370 receiver
Rti 12(fronts) Csi a6 (center) and Fx 4 (surr) and the amp is a Emotiva xpa 5
I have the fronts setup running ch 1 and 2 to the tops and ch 3 and 4 running to the woofers. Ch 5 running center speaker.
Thing is I can't really tell much of an improvement . Did I just waste $1100 or is there something I'm missing here.
Post edited by Stilly74 on
«13456
  • SDA1C
    SDA1C Posts: 2,072
    Did you say improvement or difference?
    That's a rather important distinction. If you didn't hear an improvement I am not surprised. If you didn't get any more power or volume I would say something is amiss.
    Too much **** to list....
    heiney9 Posts: 25,405
    Stilly74 wrote: »
    What were you expecting as far as improvements and changes? What didn't you like about your old set-up that you wanted to change. The Emo isn't the greatest choice, but you should hear a difference, positive or negative. Are you sure all your AVR settings are correct, etc.
  • pyrocyborg
    pyrocyborg Posts: 524
    As far as I can tell, sound quality shouldn't be affected, except that as there is more power, it should be cleaner and less prone to distorsion. Having a better DAC could help, but considering that the your AVR is a good one (650-700$ range if I am not mistaken), it should already include something of value there.
    I just did something similar, I replaced my Yamaha entry level AVR with a NAD 326 integrated amp with a V-DAC. I guess most of the differences comes from the V-DAC in kind of "sound differences", but the sound is somehow better, cleaner on passages that were congested before while using the integrated amp (I guess). However, on most tracks, there is only minimal differences.
    What I can see is that I have a hell lot more power... way too much.
    Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
    Receiver: Denon X3500H
  • SDA1C
    SDA1C Posts: 2,072
    SQ shouldn't be affected? I have to disagree on that one. By that I hear you saying different amps don't sound different? Adding an amp (especially a generic one) will most definitely affect SQ. Good Or Bad depends on what you were using before.
  • pyrocyborg
    SDA1C wrote: »
    Well, for now I can't do any critical listening... my volume is either loud or mute... having kind of a problem here. However, I poorly explained myself. The SQ gains or differences aren't in kind of "qualitative" ways (it isn't warmer, brighter, or darker, or whatever... as amps add no real flavour so it doesn't actually sound different): it's cleaner, somehow more detailed so sure, it's noticeably better.
    But is it a night and day difference? No... Speakers will do that, in case you have the recommended power for them. I understand now why some people keep on teling that sound flavour comes from the speakers and DAC, not the amp.
    I bought a NAD as it was considered a "warm" amp, but as far as I can hear, this isn't exactly the case as it sounds exactly the same (if you qualify it on the bright/warm continuum) than my cheap "considered bright yamaha AVR". However as it is a better amp, there is better specs, much cleaner power, which could IMO help in detailling and giving more clean, precise bass (instead of muddy sounding one).
    pyrocyborg wrote: »
    Every piece of gear in the chain has it's own sound.........so I'll have to say you are wrong about not being any difference is sound. It's not just a matter of the ability to play a little louder. Also, you can never have too many watts, no such thing unless you have super effecient horns or something like that.
  • SDA1C
    SDA1C Posts: 2,072
    heiney9 wrote: »
    Even at that ...having too many and using too many are two entirely different things.
    pyrocyborg wrote: »
    I bought a NAD as it was considered a "warm" amp, but as far as I can hear, this isn't exactly the case as it sounds exactly the same than my cheap yamaha AVR. Better amp = better specs, cleaner power, which could IMO help in detailling and giving more clean, precise bass (instead of muddy sounding one) and in case of tubes amps, yeah, the tube sound.
    From experience I can 100% tell you it's not the NAD. It's something else in the chain that is causing you issues, plus if the NAD is brand new, it needs sometime to break in a bit. But what you have described so far in other threads, even broken in it's not going to change much. You now need to work on isolating the problem. If both amps sound about the same the issue is elsewhere in your system.
  • SDA1C
    SDA1C Posts: 2,072
    Agreed! There is something else screwy. What with the volume knob??
  • thsmith
    thsmith Posts: 6,082
    Ditch the bi-amping and see if that helps.
  • devani
    devani Posts: 1,497
    re-run calibration setup...?
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • Stilly74
    Stilly74 Posts: 194
    There is a difference in how loud it goes for sure. But I don't know , maybe I was expecting more. I find that the bottom end comes alive a lot sooner . Meaning you do not have to turn it up as loud as before to start feeling deep bass. Just thought that going from 90 watts to 200watts would have made a more dramatic effect on the speakers.
    Will try changing the biamping and see if there is any change but I don't think there will be.
    tonyb Posts: 33,065
    Agree, take the bi-amp thing away, put the metal jumpers back in and use one amp.
    An amplifier does pretty much what your describing. Better clearity, more dynamics, it's not going to magically transform the speakers into something they are not.
    Incidently, how did you have all this hooked up ? Did you have Y connectors splitting the signal ?
  • NewHTguy
    NewHTguy Posts: 584
    When I first connected my Parasound 2250 amp to my (now sold) Rti10s I felt the same way. However, my wife has a better ear and noticed the difference immediately and was able to point it out to me. With the amp there was a precision or realism that allowed instruments to sound like instruments, not just notes. Listening to Tori Amos I could hear the timbre of her piano. In other recordings I could hear flaws or sounds that I never noticed. You might not care about such details, but I suspect if you listen carefully you will hear them. Having said that, I do believe I have reached my personal diminishing returns for amps, at least given my ability to hear subtle differences and nuances. If I am to spend money now it will be on speakers. The differences there are much more dramatic IMHO.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • Stilly74
    Stilly74 Posts: 194
    No y connectors . Just straight single RCA's from receiver to amp
  • erniejade
    erniejade Posts: 6,321
    In my opinion, sometimes, no matter how good or bad the amp is, it will only put out as good of sound as the premp signal sends. SO in my opinion, if you have a good solid amp but, the pre is ok but not great, your not going to hear all the detail or sound that you would want out of any amp. About the only difference you might hear is a litle louder, or a little more bass or a little clearer highs depending on the speakers and the "synergy" of the system.
  • Joe08867
    Joe08867 Posts: 3,919
    I don't think it is the receiver. I think the OP expected something miraculous and got OK instead.
    Have you rerun the setup with the XPA in the mix? Or are you still using the old or factory settings?
    Biamping isn't hurting but it probably isn't doing to much to help either. You only have 1 front left preout and 1 front right preout on your receiver. So you must be using a y splitter to get the signal across the two channels of the amp, or you have it hooked up in a weird way.
    What you should expect. More dynamic ability, less distortion, easier to drive at lower volumes, cleaner tighter bass. So far you are hearing most of this from what i can read from your posts.
  • kuntasensei
    kuntasensei Posts: 3,263
    Stilly74 wrote: »
    I had the same question as Joe08867... How are you running signal to separate amp channels for woofer/tweeter if you're not using Y connectors to split the output from the receiver?
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Stilly74
    Stilly74 Posts: 194
    The receiver has 7 preouts. There is a setting in the receiver to use the surround backs as biamping the front highs. So the wiring is setup as follows
    Have ch 1 on amp wired to center
    Have ch 2 and 3 wired to front speakers woofers left and right
    Have ch 4 and 5 wired to front speakers highs left and right
    So basically have 200 watts running to highs and 200 watts running to lows in each speaker
    And for an update I have found the problem . Front speakers were set to 80 htz instead of full band . Now I can tell a big difference. Love the new sound that comes out of these speakers.
    Next purchase Lsi m 707's
    F1nut Posts: 51,678
    You would have heard that difference with just the AVR too.
  • Stilly74
    Stilly74 Posts: 194
    Before running the amp the fronts were set to full band. Not sure why but after amp was hooked up they were set to 80
  • cfrizz
    cfrizz Posts: 13,415
    That amp will run the 707's just fine.
  • bobsauto49
    bobsauto49 Posts: 973
    ^ I Agree^ Or the Emo isnt supposed to run the new LSIM's? New technology or something?
    "Everything I ever did in my life worthwhile I caught hell for"
  • deronb1
    deronb1 Posts: 5,021
    The bass is going to be the biggest difference. I doesn't take too much to power the tops, but getting the lowend to jive with the tops is huge in and of itself. I had to get over 200wpc to make it work for my 12s as well. Don't run in bi-amped and see what you think.
  • Stilly74
    Stilly74 Posts: 194
    The emotive xpa 5 will run the 707's just fine. I have spoke with Polk about this already. The 707's can be run at 4 or 8 ohms. The amp will push 300 watts per/ch at 4 ohms. It never surprises me when someone needs to chim in cause they think you have to have a
    Adcom or sunfire amp cause they cost much more--- there for they must be much better. Maybe they do sound a little better but what ever. I'm not running a theater room here for the general public. There is always something bigger and better.
    F1nut Posts: 51,678
    Sure it will run them, but so will a JVC receiver. It's about the sound......it's always about the sound.
    Huh?
    nooshinjohn Posts: 25,879
    Stilly74 wrote: »
    That's because they are better. As you point out, there is always something better. Emo is great starter gear, but as your listening skills improve, the upgrade bug will bite you too. I am looking towards Mcintosh for my next move.
    Tony M Posts: 11,567
    Come on John, you've surpased the McIntosh level as soon as you fire up your self made beauties!!
    Unless your just talking about a pre-amp.
    I talked to a young man and he and his father researched alot and bought Emotiva amps also. One hates Bob Carver for some reason but that's fine. We all learn and live. I know Emo is growing considerably per their low cost per figures output or what-ever. Bob Carver did the same thing years ago with lower cost per figures output and low noise and all that.
    When I hear smart people do research and buy Emotiva and are pleased, I'm glad for them. Maybe one day I'll get an Emotiva piece and compare it to what I've heard over the years and judge for myself.
    I still remember the Tube amp a friend used to power gigantic speakers while he played along on his keyboards and Lesley powered speaker. I don't know about quality from the tube amp since we rocked out to kansas and such but I know their power and might get one one day just to play with if the price is low enough. Flea amps and the little guys are getting cheaper every day and the used market is too.
    God I love audio, and I hate eletrical problems!!!!! I've just spent 100.00 on old equipment to try and get them to work only to find out they don't make the nessesary part anymore and the cost of another would run more than it's resale value. Strike two. Let's see what happens on my third atempt at getting a vintage subwoofer to quit humming. Again I hope it's less than 100.0 total.
  • Stilly74
    Stilly74 Posts: 194
    I'll just keep enjoying the sound I have right now and the extra money I have in the bank..... Starter gear...maybe...but sounds great to my ears
  • kuntasensei
    fastz28 wrote: »
    and besides that i dont like how they run there forum, if you say anything against emo watch out sometime they will delete a neg.. post Ist like a cult over there. silly74 dont drink the kool-aid. emos are good starter gear.
    Well, we're no better here. You can't even mention Emotiva here without it degrading into basically what this thread's doing now. It adds nothing to the conversation about the OP's questions, and usually just sounds like people trying to make them feel remorse about their purchase. I used to see the same thing when SVS first got started making subs. The fact of the matter is that these direct-purchase brands are a great value for people to step into audio beyond what's available in your average Best Buy, and that's the demographic they're marketing to.
    It's like if you buy a really nice Chevy that you enjoy driving. You're always gonna have wise-asses saying you should have bought another more expensive car because it's qualitatively better... but ultimately, the Chevy gets you to your destination. And if you can afford something better later, that's awesome... but for now, enjoy the hell out of what you have.
    Equipment list:
    Emotiva XPA-3 amp
