SDA Custom Circuit Boards
124
  • CNWDI
    CNWDI Posts: 91
    edited September 2011
    After looking back through this thread and related ones for the 40-somethingth time I'm a little confused still. It would *appear* that I *can* use these boards to do the full update and TL conversion on my stock 1987ish vintage CRS+ pair (single tweeter; B/B interconnect)...am I right? (The "main" post states that these are only for P/B CRS+ but there's enough other info that I think I can make it work with mine...)
    Current polk speakers:
    Family room 5.1: TC265i R/L, VM10 Center, RC65i surrounds (couldn't match the TCs)
    Basement non-dedicated 7.1 HT: SDA-CRS+ R/L, 255c-LS Center, LSiFX surrounds, RC80i in-ceiling rear surround, plus Wharfedale 12" sub (some day I'll get around to building 15" F-20 sub).
  • gimpod
    gimpod Posts: 1,793
    I don't think so. Polk made 3 versions of the CRS+'s as far as I know.
    1. 1986 Single tweeter, B/B IC, Dual board crossover, MW6510 stereo driver, MW6510 dimensional driver.
    2. 1987 Single tweeter, P/B IC, Single board crossover, MW6503 stereo driver, MW6511 dimensional driver.
    3. 1986 Single tweeter, P/B IC, Single board crossover, MW6510 stereo driver, MW6511 dimensional driver.
    One way to tell for sure is to pull both drivers and see if there both MW6510's also look at the crossover and see if it's of the dual board design. If this is the case you've got the 1986 version and these boards wont work for you.
  • mole'
    mole' Posts: 3,160
    i have a set for my 2.3TLs and i can tell you guys these boards are top notch....
    A++++ work here
    mole'
  • CNWDI
    CNWDI Posts: 91
    gimpod wrote: »
    Based on everything I can see, looks as though you're correct. So the next question is: If I really want to redo my crossovers and go full-up 4.1TL, and I'm removing the drivers anyway to add TOOL's rings, should I attempt to procure two MW6511s? It looks as though if I do that plus the RDO198 tweeters plus the new boards, I can do the full-up conversion with these boards.
    Sort of a crazy way to do it, but I can still end up with a very nice "new to me" set of speakers for ~ $600 it would seem...The only other option would be to try to re-engineer the crossover mod to work with a very different driver (4ohm -vs- 8 ohm) and as a EE after comparing the 1986 and 1989 schematics I'm not thrilled with re-engineering things...
  • gimpod
    gimpod Posts: 1,793
    If you really want to TL your CRS+ I think your best bet would be to pick up a pair of single board 2B crossovers with the big round 16mH inductors. Hears a link to what TOOLFORLIFEFAN did with his 1986 B/B CRS+'s
    http://www.polkaudio.com/forums/showthread.php?t=122119
    BTW in that list of mine post #94 number 3 should read 1989 not 1986 :redface:
  • chandler9a
    chandler9a Posts: 878
    Got the boards yesterday Tony, Thanks!
    Toolfan66 Posts: 17,995
    Tony I mailed out your rings today..
  • Conradicles
    Conradicles Posts: 6,332
    edited October 2011
    Gimpod, you got a set of boards for the SDA-2B?
    edited October 2011
    I would never do another SDA upgrade without these boards.. I even have an extra set for my goodie box of SDA parts!!!
  • gimpod
    gimpod Posts: 1,793
    edited October 2011
    Why yes I do. PM sent.
    Thanks for the plug.:biggrin:
    F1nut Posts: 51,690
    edited November 2011
    Ya'll better grab some of these before they go the way of Larry's rings....gone forever.
  • SDA1C
    SDA1C Posts: 2,072
    I'll take a set for the 1c if you have them.
    Thanks, 1c
    Too much **** to list....
    Agreed!!!
  • SDA1C
    SDA1C Posts: 2,072
    Thanks Gimpod, its's paid
    1C
  • SDA1C
    SDA1C Posts: 2,072
    Whoa! Got mine today. These are as professional as they come. Thanks, Gimpod, for a great product and smooth transaction :)
    1C
  • headrott
    headrott Posts: 5,496
    Got my boards as well Tony. Thank you very much!
    Greg
  • gimpod
    gimpod Posts: 1,793
    SDA1C wrote: »
    1C
    headrott wrote: »
    Greg
    You guy's are more than welcome and thank you.
    Don't forget if you have any questions or need help just ask. I'll be more than happy to help out.
  • SDA1C
    SDA1C Posts: 2,072
    Hi Gimpod,
    I have to ask man. Is there any reason we don't replace the inductors? It seems to me you could build the board complete and not remove anything from the old board(other than the big coil on the back).
    Thanks, 1C
    F1nut Posts: 51,690
    I can answer that one. It's been tried and the original inductors are better.
  • SDA1C
    SDA1C Posts: 2,072
    Ok fair enough. What makes them better? I just checked the sonicraft website and found the replacement would be huge! is that the only reason?
    F1nut Posts: 51,690
    Sonics....always the bottom line.
  • SDA1C
    SDA1C Posts: 2,072
    uh huh....thanks
    1C
  • Face
    Face Posts: 14,340
    edited December 2011
    It would be difficult to source new inductors with the same values(mH, DCR) as the old ones.
  • dorokusai
    dorokusai Posts: 25,576
    It's been tried in a very limited number of xovers from what I've read, like 2 or so public folks on here. Didn't another Polkie rave about the changes in another thread? I'm not sure who that was tho...
    I don't have any issues nor poor experience with replacing inductors, never have and its been years. I'd want a much larger perspective on this if I was a newbie mulling the idea over.
  • gimpod
    gimpod Posts: 1,793
    Ok boys and girls I have 8 pairs of boards left not counting the ones I'm holding for the following members Conradicles, fbm211, heiney9, jmitchnh, knie0012, mikekipina, newrival, Outfitter03. After these are gone there going to be gone. See post # 89 for ordering info.
    On board level inductor replacement I have to agree with F1nut & Face, Sorry dorokusai.
    Here's a link to a thread by DarqueKnight who tried this for the low pass section and his experience in doing so.
    First the rings now the boards!!! I have two extra sets that I'm hanging on to just because I figured this would happen soon.
    If anyone is on the fence I would snag them now as this is a must have IMO for xover upgrades!!! You will not be disappointed.
    Larry.
  • brgman
    brgman Posts: 2,859
    Got mine!
    In about a month the gaskets will be done with as well.
    A year from now our stashes will be worth MILLIONS!!!!
    I’M OFFENDED!!!!
  • Polkersince85
    Polkersince85 Posts: 2,883
    Get the wifie a $10 gift card from Walmart and then buy a set of these for yourself. While she is not talking to you would be a great time to solder up the crossovers. You won't regret it.
  • gimpod
    gimpod Posts: 1,793
    MAN you just about made me spit a mouth full of coke cola all over my monitors. It did get up in my nose though:lol:
  • toucanet
    toucanet Posts: 581
    PM Sent for one pair (for 1.2TLs).
