SDA Custom Circuit Boards
gimpod
These boards were designed to use bigger Caps & Resistors like Sonicap & Mills and work for the following SDA's with a single board crossover and a Pin/Blade IC cable.
SDA 2B (1987 Blade/Blade IC with single board crossover)
SDA 2B/CRS+ (Pin/Blade IC)
SDA 1C
SDA SRS 2 (1987 Pin/Blade IC with single board crossover)
SDA SRS 3.1TL
SDA SRS 2.3
SDA SRS 2.3TL
SDA SRS 1.2
SDA SRS 1.2TL
Now there are somethings you need to be aware of.
First: Mounting (This only affects the SDA SRS 1.2/TL and the CRS+).
Because of the size of the new boards (10" x 5 1/4" vs 5 3/4" x 4 1/4") the only place I can think of to mount them in the CRS+'s is on the bottom of the enclosure and extend the leads (P & R) up to the big 16mH inductor. Now that brings us to the SDA SRS 1.2's, I might suggest that you could mount the board on the crossover plate plug everything in and then slide the top in at an angle then move the whole assembly up so you can slip the bottom in and then bolt in place (it should be able to fit through the cabinet opening measuring 4-3/4" high by 14-3/16" wide) and if that doesn't work you could mount the bare crossover plate first then slide the assembled crossover through the hole for the PR and then bolt in place.
Second: Let me ensure you that these boards are electrically identical to the originals with two exceptions, there is no place for the 750pF Silver Mica bypass cap(C4) for C3 it's not needed with the newer/better cap's you can buy today and nobody uses it anyway also I added a jumper (J4) for the Non-TL 2.3's & 1.2's to make things a little easier.
Ordering & Shipping:
If you want more info about the boards, schematics and what parts you'll need go check out www.gimpod.com.
Thank You ~ gimpod
P.S. These pictures do not do them justice
SDA 1C
SDA SRS 3.1TL
SDA SRS 2.3
SDA SRS 2.3TL
SDA SRS 1.2
SDA SRS 1.2TL
- Cost $100.00 a Pair including shipping.
- These boards will be for Club Polk members ONLY!.
- Payment will be by PayPal (as a gift please) or USPS money order.
- Shipping will be by USPS Priority Mail.
- Just PM me your order and we'll go from there. Also once you put solder to these THEY ARE YOURS
Thank You ~ gimpod
Post edited by gimpod on
Pm'd,, paid,,and praised.
Have you guys seen the webpage--just mouse over the board of your needs--Tony-- top shelf man,, top shelf!!!!JC approves....he told me so. (F-1 nut) -
Your website has everything someone would need to know to rebuild their SDAs with your new boards; congratulations!
Not sure if it matters but the 1C's came with a 2 piece crossover board and a single crossover board.
My 1C's came with the single board!!Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
My 1C's have the single board as wellJC approves....he told me so. (F-1 nut)
Payment sent per PM.:biggrin:
Payment has been sent. Nice job!>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Great contribution to the community, Gimpod!
But no love for the SDA-SRS's? :eek: (The originals, not the 1.2 or 1.2tls). -
Tony,
You should see some funds in the account. Thanks for your time and efforts in seeing this through.
Happy Trails,
NathanHome Rig
SDA 2.3TL's front and center
Polk 1000p Center
Pioneer Elite SC35 Receiver (Pre/Surround
Sunfire Cinema Grand 5X200-Back in the mix.
OPPO BDP-93
Squeezebox
Stepped up to name brand Speaker Cables and interconnects!
Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
Sales Rating #1!! -
Ok, I just pulled the passive in my 1C's and the previous owner did an awesome job with Sonicaps, etc. But hot glued the **** out of the caps and inductors. If I buy these boards I'd probably go full tilt with Clarity ESA's, etc. Where can I get the stock inductors?
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Payment sent Gimpod... thanks!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
I also placed an order. Now just need to wait for the SoniCaps to go on sale again.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808 -
nooshinjohn wrote: »Payment sent Gimpod... thanks!
LOL...so guess your not selling the SDA's"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Wow what a nice job!!! Guess I'll TL the SDA-2B's soon...
TOOLFORLIFEFAN wrote: »Not sure if it matters but the 1C's came with a 2 piece crossover board and a single crossover board.
I have the dual boards and blade/blade IC. I believe my 1Cs are the transitional version of the 1B to 1C. Any experience/thoughts re. problems moving to the new boards because of this?➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Funds on the way big Tone!
Thank you very much for sharing your efforts with us!
:biggrin::cool: -
My 1C's came with the single board!!Ok, I just pulled the passive in my 1C's and the previous owner did an awesome job with Sonicaps, etc. But hot glued the **** out of the caps and inductors. If I buy these boards I'd probably go full tilt with Clarity ESA's, etc. Where can I get the stock inductors?
use rubbing alcohol to remove hot glue from nearly anythingI have the dual boards and blade/blade IC. I believe my 1Cs are the transitional version of the 1B to 1C. Any experience/thoughts re. problems moving to the new boards because of this?
JayCee I think it's very possible to do this, I have a pair of these dual board crossovers for the 1C's as backups and I believe they are part wise (in values) identical to the single board crossovers. If you can give me a couple days to dig them out, trace through them and work out a plan of action for you. You've got my e-mail and I'll PM you my Phone Number in case you need any extra help.
BTW: If you guys could please put you screen name and shipping info in the message section on PayPal.
Thanks a whole bunch guys
I'm out for the day got stuff I have get ready for shipping.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Thanks!➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Everyone who has ordered and paid should be receiving there tracking #'s shortly.
Still have more boards for sale.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Paid and cant wait to see them. Does anyone have pictures of them with the caps and resistors put on?
paid too-- wonder if the claritys' would fit on the board?JC approves....he told me so. (F-1 nut)
george daniel wrote: »paid too-- wonder if the claritys' would fit on the board?
Don't know the physical size of them, but they will be an easier fit than the stock boards. Hopefully you guys will start getting your boards by this weekend.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
george daniel wrote: »paid too-- wonder if the claritys' would fit on the board?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Don't mean to gloat, but I got mine today (one of the advantages of living just up the road from where they were shipped). Man, they are beautiful and verrrry sturdy! Now they're just going to sit there in the box with the Sonicaps taunting me until I tear apart the old crossovers. Can't wait!
Thanks again, Tony... these are fantastic! -
^^Reported for gloating.
Man that was quick they when out yesterday morning. :eek:
If I must say so myself they do look nice don't they.:redface:“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
They sure do... I've never seen PCB's in black before. I was thinking of cutting a window into the speaker cabs and replacing it with some lucite and badass red LEDs to show them off! :cool: -
ESA's fit on the stock board with some stacking, you could probably get MR's to work on these boards using the same method.
OK Mr Enabler--what mix of Claritys would you use for 1C's,,I'm gonna guess--ESA's and MR in the tweeter section.JC approves....he told me so. (F-1 nut) -
Well, you could change things up and go with all MR's. :biggrin:"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Somehow I knew you would say thatJC approves....he told me so. (F-1 nut) -
gimpod:
Received the boards today in great shape. Excellent work sir - thanks!
-greybeard -
Got mine today as well and they look great!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
