Polk Audio SDA CRS+ Mods...
VR3
VR3 Posts: 29,762
edited October 2011 in DIY, Mods & Tweaks
Yep - modding these bad boys...
Possibly RDO tweets
Modded crossovers - Clarity Cap SA and Mundorf resistors and upgraded binding post
Going to have a Walnut veneer with a solid Walnut trim piece on the front...
Semi-Gloss finish.... should be pretty!
Oh yeah!
«13456
    txcoastal1 Posts: 13,520
    edited June 2011
    Lets see some pics...starting now and sticky this thread
    VR3 Posts: 29,762
    edited June 2011
    Yeah... right now they look like as my friends say... "bo-bo"
    edited June 2011
    just keep us posted...plug 'em and give a listen make some notes...start your mods and and keeps us updated...looks like a cool project
    VR3 Posts: 29,762
    edited June 2011
    Should be fun. Pretty simple veneer job too... Its all in the prep work though
  • halo71
    halo71 Posts: 4,644
    edited June 2011
    You are not gonna sell these as soon as you finish them are ya? :tongue:
    --Gary--
    VR3 Posts: 29,762
    edited June 2011
    lol
    To be honest - most likely.
    I like getting the gear, fixing it up a bit then moving it along.. its like drugs but with sound...
    I figure I took in a set of CRS that were butchered at a Polkfest - I can restore their beauty and let someone enjoy them - where as they will sit in a corner around here for eternity never used! :)
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2011
    Are they Pin/Blade? I've got a pair that I would like to upgrade/refinish, but they are earlier single tweeter models with B/B, and haven't dug too deep on what it would take. I will watch with interest.
    VR3 Posts: 29,762
    edited June 2011
    These are P/B
    I am going to use Walnut veneer
    VR3 Posts: 29,762
    edited June 2011
    Sid pulls a reversal!
    And Wa la! No vinyl!
    EndersShadow Posts: 17,765
    edited June 2011
    ^Naked speakers need a R rating and a censored tag on em :wink:
  • Conradicles
    Conradicles Posts: 6,437
    edited June 2011
    Trey I vote for a really lite oak finish. If not oak, still something very lite in color.
    Get er' done!
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited June 2011
    V-
    how do you remove the veneer? I'm guessing a heat gun and just peel, but I'm also thinking that would be too easy- so what are the steps in the process and what to be careful about when doing it? TIA
    VR3 Posts: 29,762
    edited June 2011
    Really just a heat gun and pull -- just make sure you are not aiming the gun at the drivers or other parts of the cabinet you do not want to remove...
    And the vinyl that was on here was from Parts Express and it came off like tape. The stock veneer will not come off that easy - period. It is bonded to the wood and you will have to spend lots and lots of tedious hours removing that vijnyl.
    VR3 Posts: 29,762
    edited June 2011
    Ordered parts -
    SDA cap is Solen, Midbass cap is Clarity Cap PX, Tweeter cap is SA - Mundorf resistors...
    I am also going to remove the plastic clips and solder directly to the board, bypass the polyswitch, replace jumpers with DH Labs wire...
    Internal wiring will be upgraded as well... as well as the connectors that go to the woofers to gold plated disconnects...
  • nspindel
    nspindel Posts: 5,343
    edited June 2011
    That sucks - not looking forward to it. I'm starting a pair of crs+'s soon enough, planning on maple veneer as well.
    VR3 Posts: 29,762
    edited June 2011
    Yeah manufactures make their vinyl and veneers so strong they basically become one with the wood - like Obi Wood Kanobi (har har har)
    Do SDA owners generally get rid of those plastic clips? I must admit - that is the cheesiest feeling connection I have ever seen..
    edited June 2011
    If your talking about the speaker clips then I think the answer is yes. Most upgrade them to ones capable of using bananas or spades w/ I believe....
    VR3 Posts: 29,762
    edited June 2011
    Nah I mean the plastic connectors on the board that snap together...
  • nspindel
    edited June 2011
    Actually the cheesiest feeling connection I've seen on the crossovers I've done has been the standoffs that mount the board onto the inductor.
    VR3 Posts: 29,762
    edited June 2011
    I can agree with that....
    I think I am actually just going to solder all the connections - screw disconnects and plastic connects. Solder is where it is at.
    VR3 Posts: 29,762
    edited June 2011
    I do not think I am going to upgrade the tweeters though, I am going to leave that for the next guy. Simple plug and play
    But I do plan to dynamat the woofers and put new seals for the drivers!
    F1nut Posts: 52,406
    edited June 2011
    Those are Molex type connectors, absolutely nothing wrong with them.
    The original Polk vinyl will come off without any damage to the particleboard cabinet. Using a heatgun, start at one corner. Keep the heatgun moving, never hold in one place. Lift the vinyl from the corner until it stops coming up easily, heat the next area and repeat. You may find that a putty knife will help, but use it wisely as you do not want it digging into the cabinet. This isn't a 5 minute job either.
    VR3 Posts: 29,762
    edited June 2011
    Wouldnt we get a better signal just soldering them directly to the board??
  • gimpod
    gimpod Posts: 1,793
    edited June 2011
    Not that I've seen and there called "Universal Mate-N-Loc Vertical Pin Headers"
    IMO Not a good idea seeing how your planning on flipping these. It will just make it a PITA for the next guy to work on.
    On replacing the internal wiring and connectors I wouldn't bother, It's not worth the expense and wont increase the monetary value of the speakers.
    If you were going to keep them I'd say go for it.
    Just my $0.02
    VR3 Posts: 29,762
    edited June 2011
    Good point
    I will keep them the same
  • Conradicles
    edited June 2011
    No TL upgrade?
    VR3 Posts: 29,762
    edited June 2011
    I actually asked a member about that and he said it was not a necessary upgrade.
  • dorokusai
    dorokusai Posts: 25,661
    edited June 2011
    I believe a member redid a pair of RTA12's with new scotchlocks and gold terminals that looked pretty good.
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited June 2011
    Is this the RTA 12 thread you mean, doro?
    http://www.polkaudio.com/forums/showthread.php?t=116480
    Geoff727 is the reason I don't post pics of my work... the man truly knows his way around a speaker cabinet.
  • dorokusai
    edited June 2011
    Yes, that's it. That was an excellent restoration.
