Polk Audio SDA CRS+ Mods...
VR3
Yep - modding these bad boys...
Possibly RDO tweets
Modded crossovers - Clarity Cap SA and Mundorf resistors and upgraded binding post
Going to have a Walnut veneer with a solid Walnut trim piece on the front...
Semi-Gloss finish.... should be pretty!
Oh yeah!
Possibly RDO tweets
Oh yeah!
Lets see some pics...starting now and sticky this thread2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Yeah... right now they look like as my friends say... "bo-bo"- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
just keep us posted...plug 'em and give a listen make some notes...start your mods and and keeps us updated...looks like a cool project2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Should be fun. Pretty simple veneer job too... Its all in the prep work though- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
You are not gonna sell these as soon as you finish them are ya?
--Gary--
lol
To be honest - most likely.
I like getting the gear, fixing it up a bit then moving it along.. its like drugs but with sound...
I figure I took in a set of CRS that were butchered at a Polkfest - I can restore their beauty and let someone enjoy them - where as they will sit in a corner around here for eternity never used!
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Are they Pin/Blade? I've got a pair that I would like to upgrade/refinish, but they are earlier single tweeter models with B/B, and haven't dug too deep on what it would take. I will watch with interest.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
These are P/B
I am going to use Walnut veneer- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Sid pulls a reversal!
And Wa la! No vinyl!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
^Naked speakers need a R rating and a censored tag on em
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Trey I vote for a really lite oak finish. If not oak, still something very lite in color.
Get er' done! -
V-
how do you remove the veneer? I'm guessing a heat gun and just peel, but I'm also thinking that would be too easy- so what are the steps in the process and what to be careful about when doing it? TIA2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer. -
Really just a heat gun and pull -- just make sure you are not aiming the gun at the drivers or other parts of the cabinet you do not want to remove...
And the vinyl that was on here was from Parts Express and it came off like tape. The stock veneer will not come off that easy - period. It is bonded to the wood and you will have to spend lots and lots of tedious hours removing that vijnyl.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Ordered parts -
SDA cap is Solen, Midbass cap is Clarity Cap PX, Tweeter cap is SA - Mundorf resistors...
I am also going to remove the plastic clips and solder directly to the board, bypass the polyswitch, replace jumpers with DH Labs wire...
Internal wiring will be upgraded as well... as well as the connectors that go to the woofers to gold plated disconnects...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »The stock veneer will not come off that easy - period. It is bonded to the wood and you will have to spend lots and lots of tedious hours removing that vijnyl.
That sucks - not looking forward to it. I'm starting a pair of crs+'s soon enough, planning on maple veneer as well.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
Yeah manufactures make their vinyl and veneers so strong they basically become one with the wood - like Obi Wood Kanobi (har har har)
Do SDA owners generally get rid of those plastic clips? I must admit - that is the cheesiest feeling connection I have ever seen..- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »Do SDA owners generally get rid of those plastic clips? I must admit - that is the cheesiest feeling connection I have ever seen..
If your talking about the speaker clips then I think the answer is yes. Most upgrade them to ones capable of using bananas or spades w/ I believe...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Nah I mean the plastic connectors on the board that snap together...
Actually the cheesiest feeling connection I've seen on the crossovers I've done has been the standoffs that mount the board onto the inductor.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
I can agree with that....
I think I am actually just going to solder all the connections - screw disconnects and plastic connects. Solder is where it is at.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I do not think I am going to upgrade the tweeters though, I am going to leave that for the next guy. Simple plug and play
But I do plan to dynamat the woofers and put new seals for the drivers!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Those are Molex type connectors, absolutely nothing wrong with them.
The original Polk vinyl will come off without any damage to the particleboard cabinet. Using a heatgun, start at one corner. Keep the heatgun moving, never hold in one place. Lift the vinyl from the corner until it stops coming up easily, heat the next area and repeat. You may find that a putty knife will help, but use it wisely as you do not want it digging into the cabinet. This isn't a 5 minute job either. -
Wouldnt we get a better signal just soldering them directly to the board??- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Not that I've seen and there called "Universal Mate-N-Loc Vertical Pin Headers"Vr3MxStyler2k3 wrote: »Do SDA owners generally get rid of those plastic clips? I must admit - that is the cheesiest feeling connection I have ever seen..
IMO Not a good idea seeing how your planning on flipping these. It will just make it a PITA for the next guy to work on.Vr3MxStyler2k3 wrote: »I think I am actually just going to solder all the connections - screw disconnects and plastic connects. Solder is where it is at.
On replacing the internal wiring and connectors I wouldn't bother, It's not worth the expense and wont increase the monetary value of the speakers.
If you were going to keep them I'd say go for it.
Just my $0.02“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Good point
I will keep them the same- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
No TL upgrade?
I actually asked a member about that and he said it was not a necessary upgrade.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I believe a member redid a pair of RTA12's with new scotchlocks and gold terminals that looked pretty good.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Is this the RTA 12 thread you mean, doro?
http://www.polkaudio.com/forums/showthread.php?t=116480
Geoff727 is the reason I don't post pics of my work... the man truly knows his way around a speaker cabinet. -
Yes, that's it. That was an excellent restoration.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
