Holy Grail
heiney9
heiney9 Posts: 25,091
edited March 2013 in 2 Channel Audio
I finally found my Holy Grail tube for the Dared SL2000A pre-amp. I've tried about a dozen different types and years of 12AT7/ECC81 variants. Some better than others. I also have tried about 1/2 dozen rectifiers and settled on the best one I've heard.
I have been very good lately not looking for or buying any tubes since I have enough to last me a lifetime at this point. But there was one type I had read a lot about but is very rare to find in the US. I have seen them for sale on Ebay from Europe but I never could find a great deal.
I already have my 3 favorite tube types so I wasn't going to spend an arm and a leg to try another type when I was unsure about how it would sound. I finally found a triple for sale here in the US from a seller I felt comfortable dealing with.
My former top contenders were the Telefunken ECC801S and Valvo (Hamburg) 6201 gold pins and 50's Raytheon 6414 triple mica blk plate.
The holy grail tube all 12AT7/ECC81 owners need to try is the Telefunken long plate 5965.
All I can say is WOW. This tube has the best bass response I've heard yet, deep, textured, extended and very "real" sounding and fast. The midrange is to die for! The highs are so smooth and detailed. That 3D "in the room" sound tubes provide (I call it soul of the music) is even more impressive. Didn't think it was possible to get even more delineation between instruments, vocals, drums, etc. The entire soundstage is expanded as if every sound has it's own place in space
I was blown away
Post edited by heiney9 on
«134567
    edited March 2011
    Brent Jesse has these right for sale right now.
    http://www.audiotubes.com/12at7.htm
    treitz3 Posts: 18,374
    edited March 2011
    Congrat's Heiney. The Holy Grail is hard to come by. Enjoy the music.
    edited March 2011
    You can see the structure better here
  • george daniel
    george daniel Posts: 12,096
    edited March 2011
    Congrats Brock,, I'm guessing that at this point,you have built up quite a stash.Thanks for posting this. :smile:
  • danz1906
    danz1906 Posts: 5,144
    edited March 2011
    Congrats!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    edited March 2011
    I have George. These are just absolutely stunning me right now. They sound so "right". Goose bump time. I am a fan of any Telefunken tube anyway, but these are special so far.
    The synergy is amazing. Hard to leave the sweet spot :tongue:
    edited March 2011
    This a mellow tube (not like Mullard mellow) that still has detail in spades and the sound sneaks up on you, the midrange is so "real". It's one of those tubes that you don't realize how good it is until you roll in something else and you start noticing little, subtle things missing.
    A keeper for sure.
  • PolkClyde
    PolkClyde Posts: 662
    edited March 2011
    Let me get out the check book,haha, I wish.
    PolkAudioClyde
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2011
    heiney9 wrote: »
    Does he allow local pickup?
    edited March 2011
    I believe he does. I know Doug (dkg999) has stopped in to pick up some tubes, IIRC.
  • CSM41
    CSM41 Posts: 55
    edited March 2011
    H9, have you tried them vs. the Psvane? If so, what did you find?
    #1 Pass F5/Dared Sl2000a/Nola Boxers/Basis Audio 1400/Audio Technica AT33EV Phono Cartridge/Cambridge Audio 640P-Hypno Modded/GF DAC09/CPU
    #2 Cayin A-50T /Hornshoppe Horns/Squeeze Box Touch/Simaudio Moon 100D DAC/Rythmic F12 Servo Sub
    edited March 2011
    Nope, I am not a big current production tube guy. I'd be willing to try a pair, but I just don't buy current production tubes. Of the current production tubes I have used none of them even comes close to the old production tubes, so I stopped trying. I know the Psvane get glowing reviews so it's probably not fair for me to dismiss them. But I've tried other current tubes that people swear by and sometimes wonder what they are hearing.
    They are on my list to try one of these days and if I don't care for them I can always flip them, I suppose.
  • rubin
    rubin Posts: 565
    edited March 2011
    Can these be used in a 12ax7 circut, or in a 12at7 circut ?
  • erniejade
    erniejade Posts: 6,315
    edited March 2011
    Congrats!!!! I bet it sounds amazing. That preamp is still on my to try list
    !!!! now i know what tubes to get right off the bat lol .
    edited March 2011
    rubin wrote: »
    12AT7.
    The 5965 is also a sub for the 12AV7 but ironically a 12AV7 can't be subbed for a 12AT7. Atleast it's not recommended.
    5965
    This industrial tube is close enough to the 12AT7 that audiophiles have started buying them up and commenting on the low noise of this tube. It most likely is because it has a lower gain, a mu of 47 compared to 60 of a 12AT7. It is kind of like using a 5751 in place of a 12AX7--the lower gain being the main difference. These tubes are still plentiful, and are really well made. GE made a fine version of this tube in their "5-Star" broadcast line. A few have an extra mica spacer on top, known as "triple mica" and noted for lower microphonics. There is also a rare Telefunken version of this tube with long plates.
    The 12AT7 is a high-frequency twin triode in a small 9-pin miniature glass package. This tube has a mu factor of 60, as compared to the higher gain 12AX7 with a factor of 100, and the 12AU7, with a mu of only 20. As you can see, it shares similar pin connections with it's cousins, but these tubes are not interchangeable. The 12AT7 is found in many high fidelity applications, as each triode section in normal use operates as a class A amplifier. They also turn up in line and microphone preamplifiers, musical instrument amps, and vacuum tube equipped recording equipment. By their design, they are inherently low noise, making them a good choice for these applications.
    What's hot these days with these tubes? Right now, most of the vintage 12AT7 tubes are a great bargain, as the spotlight is still on the vintage 12AX7 and 12AU7 varieties. Both the USA and West Europe versions of this tube are just as well made as their famous cousins, but they were used less in hifi gear, and more in professional preamps and recording equipment. Those of you with a hifi preamp using the 12AT7, as well as owners of pro line and mike preamps, will find a refreshing change from the usual high prices of other vintage twin triodes. Both the vintage USA and European versions of this tube are excellent. I can't think of any brand, even "off brands" that made a crummy vintage 12AT7. Of course, the stellar performers are still the big boys: Telefunken, Mullard, Amperex, and RCA.
    edited March 2011
    Yep, these are it! I've finally hit audio nirvana. These are the ones!!!!!
    A small note, since these are 17mm long plates they tend to be like the 7062 or 6414 in that they can be slightly mircophonic. One started a very low level howl which was quicklt abated with a tube damper. Been running them all day and the problem hasn't come back.
    These are simply the most fantastic tubes I've heard in the Dared pre-amp. Hard to describe their character beyond what I already said. These have it all!!!
    The synergy is off the charts on this one. :tongue::wink::biggrin:
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited March 2011
    Congrats Brock!
  • chargerman426
    chargerman426 Posts: 419
    edited March 2011
    heiney9 wrote: »
    12AT7.
    FWIW I have rolled everything from an 12AX7 in a 12AU7 spot to 12AT7 in a 12AX7 sport with no problems. The one thing that I try to maintain is the voltage step in amps. For instance if the path goes AX then AT stock I might go AT then AU to see if I like it.
    If life had more tubes it would be a lot smoother.
  • CSM41
    CSM41 Posts: 55
    edited March 2011
    heiney9 wrote: »
    I am not either, but I gave the Psvane's a chance and like them. I did the same thing with my Treasure 6CA7's. I am by no means saying the Psvanes are as good as those Tele's. They are about a Benjamin less in price *shrug*. Your report is so enthusiastic in favor of the new tubes that I might have to buy a pair of these Telefunkens myself. Like you said, flippin good tubes is easy.
    Since we have the same pre, it really is nice to hear your reviews. That said, you seem to have waaay more tube knowledge than I do. Keep 'em coming!
  • megasat16
    megasat16 Posts: 3,521
    edited March 2011
    heiney9 wrote: »
    Congrats Brock! It's nice to be on the other side! :tongue::biggrin:
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    edited March 2011
    Congrats Brock!
    Thanks Duell!
    edited March 2011
    CSM41 wrote: »
    I bought these for dirt!!! But, I have been waiting for about a year that weren't expensive. The wait was worth it. But I may try to pick up a spare from a dealer while he has them......we'll see. I hate paying a lot for a tube I want to try because if it doesn't work out it's too much money. Now I know these are great, I'm willing to spend a little more.
  • pearsall001
    pearsall001 Posts: 5,004
    edited March 2011
    Congrats Brock!! Sounds like you're tickled pink with your new find. Well worth the wait for sure. Enjoy!!! I might check it out for my dac.
    edited March 2011
    Actually just found out that there are two versions of this tube. The early version has two crimps for the plates and the chrome strip on the side of the plate has the center cut out. The later version has three crimps on the plate and the chrome strip on the side is whole except for two tiny holes.
    Early dates from the 50's, late dates from the 60's other wise they look the same. I have two late and one early. Now I'm on the hunt :eek: for an early to mate with the single I have.
  • inspiredsports
    inspiredsports Posts: 5,501
    edited March 2011
    Good Job! My PV-5 pre uses 2 5965's and I have Sylvania Gold's in there now. I'll have to see if I can find some of these Telefunkens to compare, but just blew my budget on 6 Mullard (Shield Logo) M8162/CV4024's for my amp.
    I'm surprised by the drastic bass improvement versus the 12AT7/ECC81's your pre came with as the 5965's have a 22% lower gain (a mu of 47 compared to 60).
    The lower gain from your pre must cause the amp to draw down into an output range where it is happier, and then the lower noise floor and improvements those 5965's facilitate must show through.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    edited March 2011
    The ECC801S is a little thinner sounding tube in the bass, still solid for sure. But this tube has such an organic texture and bass seems to extend forever. It's not just the gain in a tube that determines it's sonic characteristics. I have GE 6201's 5 star black plate that sound huge and have a tad too muddy bass compared to the Valvo 6201 and they have identical gain.
  • inspiredsports
    edited March 2011
    I've been trying to convince myself to sell my barely used quad of NOS Telefunken ECC801S's (probably 400 hours on what is said to be a 10 or 11,000 hour tube) as that would free up some cash to keep my habit going, but I know I will end up kicking myself if I do.
    At any rate, you've got me looking for funds and itching to try a pair of these now :biggrin:
    NAD SS rigs w/mods
    GIK panels
    edited March 2011
    Greg, you will kick yourself if you sell them. Keep them, I still like them but these 5965's are really pushing the right buttons.
  • CSM41
    CSM41 Posts: 55
    edited March 2011
    H9, out of curiosity, what do you use in the rest of your system? I know you have the Dared pre. I ask because IMHO, system/tube synergy makes a difference.
    edited March 2011
    CSM41, my gear is in my sig but I'll elaborate.
    I use 2 pre-amps. I have the Adcom GFP-750 which is both active and passive at the flip of a switch. I use that for shorter listening sessions and movies, etc. This pre has a processor loop (for HT) that allows me to run the Dared Sl2000A straight through. The processor loop is staight pass through (no degredation) and can be activated by remote or at the pre. This works incredibly well because I don't always have to power the tubes on for music, dvd's or background music. So I have the flexibility of active/passive and tubes. I use Signal Cable Analog II I/C's to connect the Dared thru the processor loop. MIT Terminator II cables from the Adcom pre to the amp.
    My source is (2) pieces, I use a Squeezebox Touch wireless music streamer which I bought an aftermarket linear power supply from Welborne Labs for, since the supplied walwart is a cheap switching power supply. I have all my music ripped in FLAC (lossless) format on a stand alone computer I use only as a music server. The digital output of the Squeezebox is fed into a heavily modded Adcom GDA 600 digital to analog converter via COAX, again Signal Cable Digital Cable. MIT Terminator II cables from the dac to the pre-amp
    My amp is a Pass Labs Aleph 30 single ended Class A amp @ 30wpc. I use the single ended inputs because I think they sound a tad better than the balanced inputs. Speaker cables are MIT Terminator II.
    I have a Marantz DVD player that is hooked to the Adcom DAC via coax and I use that for movies or in a pinch single cd's that I haven't ripped to my music server.
    Speakers are modded Polk Audio SDA 1C's w/ rdo tweeters, Sonicaps and Mills resistors. Power cables are all MIT Z II
