Building 400 wpc Tube Monoblocks....
May I state it those are Looking Bad A$$
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
txcoastal1 wrote: »beautiful...do you have an estimated completion date...I think most of us are almost as excided as you are
No completion date, as I would rather take my time and get them right. If I build more, the build time will be much less, but never rushed.disneyjoe7 wrote: »May I state it those are Looking Bad A$$
Yes Joe, you may.:biggrin:
Thanks!:cool:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Wow,very nice work and attention to detail..
They look very nice, good luck. You should invest in a variac.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
John,
That's a real work of art! Can't wait for the day you finally start them up and let us know how they sound. Cheers! -
John,
I'll take a wild guess and say that one, he won't say that they sound awful and two, due to the time and money time invested they will be the best amplifiers he's ever owned.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I knew there would be someone like you that would say this.:rolleyes: I have arraingements made for a fully independent review, which will be published, to take care of that one.:cool:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Dont worry It's just Manny being Manny.nooshinjohn wrote: »I knew there would be someone like you that would say this.:rolleyes:
Once they are completed I hope a couple of us Indy folks can get together to give them a listen (both on your LSi's and also SDA's).
Never heard tubes and what better way to start :biggrin:"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Once they are completed I hope a couple of us Indy folks can get together to give them a listen (both on your LSi's and also SDA's).
You guys are welcome here any time!:cool:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
John, What are the output tubes and what trannys ?
Looking good BTW.Speakers: SDA-1C (most all the goodies)
jencdnhome reportedSDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Well, that would be my story and probably most peoples.Speakers: SDA-1C (most all the goodies)
Looking good BTW.
The output tubes are Tung-Sol KT120's and the transformers are being custom wound by Bob Carver.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
P2P = PIA...
No better way of saying it. Point-to-Point wiring is a major pain in the ****! Thank God for the man that made the first circuit board!:cool:
Here are a few pictures of the wiring in progress...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Haven't gotten too much done this week. I am having a bit of trouble interpreting one of the tagboard connections. I have learned just why these amps can be so expensive, as they take a tremenous amount of time and brainpower to get them right. When you have a single functioning brain cell like I do, it can lead to synaptic meltdown.:cool:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Sorry for the LOOOONG delay between updates...
The long and short of it is that the schematics I had been given came from different dates, one as early as 2008 and another from 2010. This, combined with the dozens of pictures I have of the internals of these amps, led to a situation where Bob and I have been unable to effectively communicate about what to do next, and where parts should be located on the tagboards.
I have redrawn the schematics and the tagboard plot drawings and have forwarded them to Bob to have the corrected values written in. Once I have these back from him, I will be removing all the work I have done thusfar, and reordering new parts based on the revised plans. They should go quickly once I have the new set of plans.
The transformer covers are in primer right now and awaiting final paint, and the bottom plates are being powder coated. Thanks for the support guys and thanks for asking!
JohnThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Wow John this project speaks to my love of tubes, high power and OCD execution in build. While not at your level, here is a pic of my one off scratch built 2A3 power amp.
That is truly some beautiful work. Where did you get he endcaps for your project?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »That is truly some beautiful work. Where did you get he endcaps for your project?
If you are referring to the chassis wood, they came with them from IAG Audio (Horace Atkinson) out of Killeen Texas. They are solid oak. I stained them and finished with Deft lacquer. -
Absolutely gorgeous both the P2P and the visual finished product.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I got the bottom plates back from the powder coaters, and they look fantastic....
Bob and I spoke tonight, and he almost has the new schematics sorted out. I have also decided to essentially start from scratch on the parts and wiring once I have the new drawings. I expect things will go more quickly however as I will be working from the same page as Bob. These schematics and tagboard layouts will also be made available to anyone wanting to do this for themselves, and I will provide as much support as I can for anyone wanting to give these a shot.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Labor of love john . . . labor of love. Good luck.
SolidSqual wrote: »Labor of love john . . . labor of love. Good luck.
with a bit of labor pains in there as well
. Glad to see your pushing through it all. see you in a couple weeks.... "....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
John !!!!! Looks great!!!
Some updated pictures... I am still waiting for the transformers to make them work, but most of the other internal work is complete. The transformer covers are missing a piece of aluminum trim that will ring the bottom of them and the pinstriping work. The wood for the side panels also need to be finished, but the overall look is complete.:biggrin::cool: Every time I see them, I smile from ear to ear!
A few more...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
sweet !Speakers: SDA-1C (most all the goodies)
Absolutely stunning! Love the glass/crystal nameplate - very nice touch. Drooling . . .
Sweet! So now you know what the guy who built this felt like :biggrin:VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
