So your wondering about Power Cords?
Great idea, McLoki. I feel like I should be "in" this test since I started the post. However, I saw what I needed to order some for myself. Thanks - I will be following the reports of others and will weigh in my opinions, too.7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi -
- Jeremy
Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
Speakers: Polk Monitor 7A's, KEF Reference 104aB
Sources: ProJect Debut Carbon, Sonos streaming FLAC -
If it is not to late I would like to try this. Power cables are the last thing I have not yet tweaked, or even tried. I know just the company with off-the-wall power cable designs, but have not yet convinced myself to buy 6 power cables.
Offer is open until the test reaches the last person and the cords are shipped back to me. Consider yourself in.Great idea, McLoki. I feel like I should be "in" this test since I started the post. However, I saw what I needed to order some for myself. Thanks - I will be following the reports of others and will weigh in my opinions, too.
requirement is 50 posts (not crap ones either) and you would be about 8th or 9th in line. That gives you about 2-4 months to come up with 15 more decent posts (at a 1-2week trial per person). Hang around and I am sure you will make it with no problem. I will add your name to the list and if you aren't still around or haven't posted at least 15 more times in the next 3 months or so - I will skip you. Sound fair??
Never used it or heard of anyone who has. Signal Cable is a know quantity to me and that make it worth the slight extra cost. Just my opinion - Not saying its not the best deal in audio, just that I don't know.
This is very cool. People argue about upgraded any kind of wires without any practical experience. This is a very nice way to get some. Now you can honestly post if it made any difference or not.
Nice going man. I'm not in as I have been down this road more then most.Dan
I have two of the PC's...the Pangea AC-14 & the Pangea AC-9. I did a search on the designer, Jay Victor & he holds a boat load of patents on cable technology & design. He's very well known in the audio circles. But what really swayed me was this info found on PC Audio's site...http://www.psaudio.com/ps/products/description/perfectwave-ac-12-power-cable?cat=cables-accessories. PC audio relies heavily on Jay's patents & cable design for their best cables. I figured if Jay's knowledge is good enough for PC audio then why not give his cables a shot.
Be for warned though, the build quality, looks & especially the massive size of the AC-9 is off the charts at this price...hell even at the PC Audio cable prices these cables are a steal. I'm extremely happy with both of Jay's cables & highly recommend them.
The AC-9 is so massive that you need to allow extra length to get a good bend without too much pressure. At these prices they're worth a listen in your system. I know I'll be purchasing more. -
In, please~TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Not in, but very cool.Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk TSi500s Vr3 Fortress modded
polk CS20 center channel Vr3 Castle modded
polk Owm 3 surrounds
polk PSW505 -
Excellent work Michael. Not in as my SC & VD power cords are here to stay.Michael
NORTH of 60° -
hearingimpared:
Not trying to stir the pot, I simply believe many will hear improvements quicker as the PC gets closer to the source, that has been my experience (digital sources especially). There are differences in other components but the bang for the buck factor goes way down. -
You can keep me off the list. I plan on ordering 1 or 2 cords in a couple of weeks. I will continue to monitor what results polkies are getting from their tests and add my 2 cents after hooking up mine.7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Wow.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
I agree. Changes are subtle to almost non existent on the amps I own. The biggest differences I've heard while rolling PC's was on my Peachtree Nova. I believe the beefier the power supply, the less of a difference.hearingimpared:
Not trying to stir the pot, I simply believe many will hear improvements quicker as the PC gets closer to the source, that has been my experience (digital sources especially). There are differences in other components but the bang for the buck factor goes way down."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
pm'ed..HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
2 APC H-15s and a Panamax 5400 for good measure
Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers -
hearingimpared wrote: »I agree with your recommendation of source first. However, I noticed a definite improvement with my preamp and amp with an after market power cord and more so after it burned in. Definite decrease in the noise floor and the instruments and vocals were coming out of almost pure blackness.hearingimpared:
I don't think you are trying to stir the pot as I agree with your advice on going with the source first as that will reveal the benefit of an aftermarket power cord more so than preamps and amps. I was just sharing my experience. -
Not In but very cool effort by the OP and an excellent chance for some polkies to have first hand experience on the PC.
Lush, I also agree with your observations. That has been my experience as well.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
The choice is yours... The opportunity is open if you change your mind.You can keep me off the list. I plan on ordering 1 or 2 cords in a couple of weeks. I will continue to monitor what results polkies are getting from their tests and add my 2 cents after hooking up mine.
Good luck in your audio journey.
You are in.pm'ed..Mains.............Polk LSi15 (Cherry)
Not in but Kind offering. I've been happy w/Signal MagicPower Digital Reference on my pre, CDP and MagicPower for the amp.Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Nice offer....I have 2 jps p-cords,don't need any proof.
very nice of you Michael, after reading that thread I'm just gonna order one myselfpanasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
And we're off.... Cords shipped out to Huck344 this morning.
Tracking number will be PM'ed this evening.
Michael
Recieved a note from Eric that the power cords arrived and he will start experimenting with them soon.
NooshinJohn - I need you to PM me your address and a phone number (in case something comes up) so Eric can send them to you when he is done testing.
Eric - Take your time and try it in a few different components. I expect at least a week or two for testing - no rush.
Can't wait to hear opinions - one way or the other.
Michael
Ditto, indeed. -
Likewise, interested to read the feedback.
Mark, anyway to "sticky" this thread? thanks bro..I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Here is the current order of things.
Huck344 ***** Currently testing *****
nooshinjohn
Big Dawg
ben62670
Conradicles
polrbehr
Zitro
BlueFox
TNRabbit
Praedet
Let me know if I missed anyone. Opportunity is open until the final person concludes his/her testing and ships the cords back to me.Mains.............Polk LSi15 (Cherry)
Put me on the list too, if you don't mind.:)
I've seen the differences that IC's and speaker cables can make, but I've gotta say, I still have some doubts about power cables. I'd love a chance to try it out in my own rig.
Very nice offer.:)The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
The Signal Cable power cord is the bar standard for all my gear. It's the first thing that gets swapped and its modestly priced to boot.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I say the opposite for the Signal digital cord.
Agreed. Made a difference when used with my CDP.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
In. I changed my mind. If I get one of my own before I get the test one, I can see how it works with other components. Thanks again for the offer.
This will also bump this back to the top and hopefully get some more interest in the name of sonic science.7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Well, we are nearing 2 weeks for Huck344.... Forming any opinions yet?
BTW - CCurt and Squeeb you are both in.Mains.............Polk LSi15 (Cherry)
