How long can speakers last?
12467
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2009
    Mr2, you are really worrying about nothing & totally over thinking this.
    Yes you will be fine with a higher wattage amp than a lower one. As pointed out more speakers get blown by being turn up too loud on receivers that DON'T have the power to give them for that volume.
    Your ears will give out before the speakers do, unless you get crazy with turning it up then you will be deaf and won't need speakers! The speakers will only take the power that they need to operate to their full potential.
    It's important to make sure that the DO have the power that they need to do so.
    FORGET about break in. Just enjoy the speakers.
    It all boils down mostly to common sense.
    mr2sw21 wrote: »
    so what you mean is. Larger power amp and small power concern speakers that will never had a problem. Is it? Like if I have 140w per channel amp and I have 100w speaker I will be fine?
  • cfrizz
    edited April 2009
    Heiney for the most part, most people like/use SOLID STATE gear. This newbie I seriously doubt is talking about tubes. Hence we focus on SS power & usually more is better than less.
    You knew this but wanted to make it just a bit more confusing.
    This poor guy is confused enough as it is, so it's best to keep it simple. Let's wait until he thinks he's an audiophile before we start talking about tubes & crap.;):p:D
    heiney9 wrote: »
    Well what about my case where I have 30wpc and my speakers can handle 500wpc.
    The 30 watts I have now certainly plays louder, cleaner and has more dynamics than my previous 125 wpc amp and a 200wpc amp.
    How can this be?????????? Well, because there are no absolutes in audio and in many cases there are always several exceptions.
    A good rule of thumb (very loosely interpreted) is the more power the better, but that is not true in many cases as each individual circumstance will have a multitude of variables which make the above rule of thumb invalid.
    YMMV
    heiney9 Posts: 25,432
    edited April 2009
    I know Cathy, just throwing it out there. BTW, I have SS, not tubes. ;). Just showing that there are no absolutes. But it's a good rule of thumb to have more not less power.
  • thuffman03
    thuffman03 Posts: 1,325
    edited April 2009
    My Dad has a set of KLH that he has had since the mid 60's. After a refoam they sounded great!
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • mr2sw21
    mr2sw21 Posts: 115
    edited April 2009
    thuffman03 wrote: »
    waooo that surprise me. Nice.
  • seafire
    seafire Posts: 459
    edited April 2009
    heiney9 wrote: »
    YMMV
    Point taken on your class A rig ;)
  • woweu2006
    woweu2006 Posts: 68
    edited April 2009
    keep it in a refrigerator, and it will last 10000 years
    Sony BRAVIA W-Series KDL-52W4100
    Polk Audio LSI15 - Front
    Polk Audio LSIC - Center
    Polk Audio PSW10 - Sub
    Polk Audio R50 - Surround
    Playstation 3 80GB - Blu-Ray Player
    Denon AVR-989
    Denon 758
    http://californiammo.com/
    :D:D:D:D:D:D:D:D
  • seafire
    seafire Posts: 459
    edited April 2009
    I'm thrilled that you know how to Google, but that doesn't change the fact that catalyzed polyurethane is still NOT catalyzed lacquer. Nor does it change the fact that no one uses it on their speakers.
    Which part of I manufacture speakers don't you understand?.Which part of we use polyurethane clear coat don't you understand? Which part of the polyurethane we use is a two pack with catalyst and is not cured by oxygen don't you understand?.Which part of most in the furniture industry use this product don't you understand?
    F1nut Posts: 51,763
    edited April 2009
    seafire wrote: »
    All of it because you're full of ****!
    I know more about furniture and finishes than you could ever imagine, it's my business. The standard finish of the furniture industry since the '50's has been and remains today, lacquer.
    So, why don't you tell us what brand of speakers it is that you manufacture and back it up with proof that can be verified. Before you ask, there's a multitude of folks here, including folks at Polk Audio that know what I do. I've even done work for the Smithsonian and the White House, so don't you dare tell me what is what about furniture and finishing products.
    You're nothing more than a common troll and a total disgrace to this fine forum. It's time for you to leave!
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited April 2009
    seafire wrote: »
    Anyway for those that care we do not manufacture paint but use these 2 pack polyurethane clear coats on our real wood veneers ;)
    I prefer to use to use whatever your momma's using for lip gloss on my real wood veneer.
    HINT: there's an insult hidden in my last sentence. :rolleyes:
    HINT: there's only one sentence, so it shouldn't be too hard to find.
    HINT: I'm not a custom speaker manufacturer, but I've seen some on TV.
    ..... just helping to push the barrel over the falls at an accelerated rate.
    ...... almost time to post some Doors.
    HINT: I make no claims as to the appropriateness, timeliness, accuracy, or suitability for any purpose regarding any suggestions or hints contained in this post. Your mileage will vary, and objects will be closer than they appear in the mirror.
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    seafire wrote: »
    So you sweep the floors at some speaker manufacturing company. I guess that could be consider part of the manufacturing process. Everybody counts;)
    Keep blowing hot air.
    Ben
    Ben
    tonyb Posts: 33,072
    edited April 2009
    seafire wrote: »
    Now theirs a shot....
    Haven't seen this kind of trolling in a while.Seems whenever you open your trap,you remove all doubt,bubba.Just a real people person,eh? Time for Cathy to pay this dude a visit.
    mhardy6647 Posts: 35,005
    edited April 2009
    thuffman03 wrote: »
    Ummm... 1960s vintage KLH drivers would've had cloth surrounds, not foam.
    I'm just sayin'....
  • skrol
    skrol Posts: 3,450
    edited April 2009
    This thread has been a real hoot...
    I know that my RTA11TL's are certainly not the oldest around (circa 1990) but even before upgrading the tweeters and crossovers, they still sounded very nice. I have no idea how the sound compared to when they were new. Doesn't really matter anyway. Today they sound better than ever.
    Now I did commit the cardinal sin of applying conditioners (Meguires or Lexol rubber protectants) to the surrounds to the surrounds of my RTA11TL's before I'd heard that it was a no no. I had done this about once a year for at least 10 years. Please forgive me :o. Fortunately, I do not see any signs of degradation and they look like brand new.
    The Model (Monitor) 5A's that I just picked up (circa 1983) sound great and they are all original. The driver surrounds look like they have never been cleaned and are slightly brownish. What is recommended for cleaning the surrounds?
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • cfrizz
    edited April 2009
    He's not worth it. Besides I need to keep my blood pressure down.
    I was going to tell you all to put him on ignore. However, that would be too dangerous to innocent newbies who might take the garbage he is spouting as gospel & end up ruining their speakers!
    BLAST HIM Jesse!
    tonyb wrote: »
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2009
    Seafire-not a single person here is going to believe your claims of you being a speaker manufacturer, unless you tell us the name of this company and maybe post up some pictures of your work.
    I know I definitely don't believe you.:rolleyes:
    Also, from the sounds of it, I think Jesse's knowledge of these various finishes far surpasses your knowledge. It appears that all you did was look up some info on Google and copy/paste it here.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • seafire
    seafire Posts: 459
    edited April 2009
    First of all I am not going to advertise my speakers on the Polk Forum.That would be rude.I also said that we use polyurethane because it's very hard and durable.Do you honestly think I would post my speaker company name here when some people here are so aggressive and rude!.However I will post some pictures soon to shut some traps here!With regards to Jesse..he stated that polyurethane cures with oxygen.I just showed him that the 2 pack we use is different.Has it ever occurred to Jesse that industry standards differ all over the world!.So enough said of that
    F1nut Posts: 51,763
    edited May 2009
    seafire wrote: »
    We talk about and own all kinds of speakers here, so your reason has no merit. Simply an excuse because you're full of ****.
    Wait...you won't tell us the name, but you'll post pics!?! So, can we take it that you don't think enough of your speakers to put a name on them? And can we take it that you don't think enough of your speakers that you own Polk's!?! Again, you're full of ****.
    Excuse me! You said,
    seafire wrote: »
    Maybe their cabinets are finished with polyurethane wood varnish .In that case furniture polish is not needed.Maybe that's why :rolleyes:
    You didn't say anything about 2 part poly until after I corrected your comment, "Correct polyurethane is a catalyzed lacquer" by stating, "Polyurethane is nothing like cat lac as poly cures by reacting with oxygen while cat lac cures because of the acid catalyst. They also have very different thinners. While poly can be sprayed, I wouldn't recommend it. Cat lac, on the other hand, must be sprayed. Poly takes hours to dry, while cat lac is dry in minutes."
    Regardless, the fact remains that catalyzed polyurethane is still NOT catalyzed lacquer. Again, you're full of ****.
    Has it occurred to you that I deal with furniture from all over the world!?! Of course it hasn't because you're full of ****!
    It's hilarious to watch you twist as you get caught in lie after lie trying to cover up the last lie.
  • ben62670
    edited May 2009
    seafire wrote: »
    Shut up **** bag.
    Ben
    Ben
  • Rocco1
    Rocco1 Posts: 190
    edited May 2009
    I WANT PICTURES! keep it PG-13 though.
    Man Cave: 7.1
    -PS Audio Power Plant Premier
    -PS Audio Power backup
    -Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
    > Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
    >Sub = MK Audio 10'
    -PS3
    -Onkyo 5 disc cd player
    -Directv
    -Samsung 59' plasma flanked by 2 Samsung 43' plasma's
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2009
    well the only way I know to set the sea to fire is with an oil spill which might explain all the murky black smoke being let loose............
    RT1
  • comfortablycurt
    edited May 2009
    seafire wrote: »
    Um...I don't think it's going to be a big deal. It's not like you're posting an ad saying "Polks suck...buy my speakers instead!!!". Go ahead and post the name of your company and some pictures of your products.
    Obviously you won't do this though, as you're lying about the whole thing to begin with.:rolleyes:
    edited May 2009
    Sea.
    They're calling you out there. Ever see 'High Noon'?
    cnh
  • lightman1
    lightman1 Posts: 10,796
    edited May 2009
    Up yours, Kex...
  • seafire
    seafire Posts: 459
    edited May 2009
    It was my wife's birthday yesterday so I did not log in.However returning today I found all these lovely posts.
    The one thing I know for sure is that most of the name callers here have no real contribution to this forum anyway.
    I will post pictures of our speaker production and will not reveal my company or product names to this pack of slandering dogs!
    WHY? BECAUSE INSIPID FOOLS LIKE YOU NEED TO ROT IN YOUR OWN SEA OF SLANDER AND DO NOT DESERVE ANYTHING MORE!.
    I AM ALSO TIRED OF STOOPING TO YOUR CHILDISH LEVEL AND AM SOMEWHAT SURPRISED THAT THE MODERATORS ALLOW THIS TO CONTINUE.THE FACT THAT SOME DOUBT ME IS NO SURPRISE.AS I STATED BEFORE ----PACK MENTALITY AT IT'S BEST AND NO BRAINS TO TOP IT ALL BAAAAA BAAAAA
  • seafire
    seafire Posts: 459
    edited May 2009
    Kex wrote: »
    Unfortunately, it seems, speakers are never going to last nearly as long as the endless stupidity of some people. Fortunately, however, I get to listen to my speakers a lot more often that I have to ignore such stupidity. YMMV.
    Thank you Kex.It is people like you and many others that share your view and are complaining that has made me stand up and be counted.
  • seafire
    seafire Posts: 459
    edited May 2009
    TAKING CARE OF YOUR
    LSi SERIES FLOORSTANDING LOUDSPEAKERS
    The side panels of your new LSi Loudspeakers are finished in natural wood
    veneer. Clean these panels periodically with a soft cloth and furniture polish
    to remove dust and fingerprints. Avoid harsh detergents and cleaning fluids
    [figure 9]. Clean and dust the Gloss Black lacquer area with a damp cloth
    only. Do not use furniture polish on the Gloss Black lacquer. Carefully vacuum
    the grilles to remove dust.
    The above comes straight out of the Polk owners manual.So who were the clever dicks again that shot that down? I'm not even going to bother scrolling back :rolleyes:
  • seafire
    seafire Posts: 459
    edited May 2009
    No, I'm not.
    Ahhh, what do they know. They only produced the things. I'll be back, I'm gonna run out and buy a 5 gallon bucket of industrial strength furniture polish and get these things shining like a chrome bumper in the sunlight.
    YAWWWN :rolleyes:
  • seafire
    seafire Posts: 459
    edited May 2009
    Keiko wrote: »
    That's weird, according to polk they say NOT to use any type of furniture polish on the wood cabs. Just a cloth, dampened with water. I wonder why?
    Why? I will let you answer for yourself :rolleyes: hahaha
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2009
    seafire wrote: »
    Reported.
