How long can speakers last?
123457»
  • Systems
    Systems Posts: 14,873
    edited May 2009
    Thanks for the reply,Im in agreement on most points except the following.
    seafire wrote: »
    We have also used 1st order butterworth in some cases as it's very accurate with phasing and brilliant with impulse response and is in my opinion still one of the best sounding crossovers.That is if you have drivers that are perfectly matched in terms of natural frequency response and roll off.More than a two way configuration with this setup defeats the object though.
    I disagree,I think you are more likey to be successful using true 1st order crossovers with a 3way.This because it will be easier to achieve the approx. two octaves of driver overlap required.Done correctly 1st order BW can sound very good ,both Vandersteen and Theil have made some excellent 3 way 1 st order systems.
    Linkwitz 4th order is the best in most ways except for two things.Design complexity and it not being phase linear.Many will argue that it is not audible but my experience begs to differ.
    I prefer using 4th order LR's(especially actives) and do not feel that the fact it's not being minimum phase a comprimise.Flat summed amplitude response ,reduced lobing errors,and the ability to crossover at a lower frequency because the steep slope protects the tweeter etc. make it desirable.
    mulltiple driver configurations(3-4 way +) where lobing becomes critical.
    IMO lobing will be as much or more of an issue in a 2 way.
    Bessel on the low pass.We would then simply play with frequency overlap until we find the best phase coherency and flat amplitude response :)
    The John Bau I refered to in my previous post obtained a minimum phase reponse in his famous Spica TC50 's using a 4th order bessel low pass and a 1st order Hi pass.It was then(mid 80's) a unique design.
    Testing
    Testing
    Testing
  • megasat16
    megasat16 Posts: 3,521
    edited May 2009
    seafire wrote: »
    btw the speaker cable thread whipped your behind :d wishful thinking buddy ;)
    :eek: What did I do to get that kind of reply from you? :(
    Please be kind enough point out exactly what post did I get my behind whipped!
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • Lord Vader
    Lord Vader Posts: 167
    edited May 2009
    Leave Seafire to ME! He is no match for the power of the DARK SIDE!!! I must face him... alone!
  • seafire
    seafire Posts: 459
    edited May 2009
    GV#27 wrote: »
    I disagree,I think you are more likey to be successful using true 1st order crossovers with a 3way.This because it will be easier to achieve the approx. two octaves of driver overlap required.Done correctly 1st order BW can sound very good ,both Vandersteen and Theil have made some excellent 3 way 1 st order systems. I prefer using 4th order LR's(especially actives) and do not feel that the fact it's not being minimum phase a comprimise.Flat summed amplitude response ,reduced lobing errors,and the ability to crossover at a lower frequency because the steep slope protects the tweeter etc. make it desirable. IMO lobing will be as much or more of an issue in a 2 way.
    Good evening!
    Honestly...I was waiting for your reply all day as I knew it would make for an interesting read.
    On point one I agree in general except that I did mention that using SPECIFIC drivers in a 2 way 1st order can sound very good because of wide frequency band and good natural roll off.
    Using 4th order LK'S active is far less restrictive than passive as you can correct phase and amplitude electronically.
    Lobing on a 2 way is easy to correct if you have control of the seating position.I am referring to near field monitors with a fixed seating position.
    I had read about the famous SPICA TC50 but did not realize that I am honored to be speaking to the one and only! :eek: :D:D
  • seafire
    seafire Posts: 459
    edited May 2009
    megasat16 wrote: »
    Relax!! just read your sub post about the emo thread.Really I was just joking :rolleyes::rolleyes::rolleyes:
  • seafire
    seafire Posts: 459
    edited May 2009
    Lord Vader wrote: »
    Have another.....whatever it is your busy with :D
  • megasat16
    edited May 2009
    seafire wrote: »
    Really, the EMO thread is older than you in the Club Polk. :D
    And I don't recall my **** whipped in the EMO thread. I just didn't want to argue with a few guys who think that EMOTIVA amp are of World Reference quality. :D
    It'll be much like debating what is a World Class Speaker!
  • Lord Vader
    edited May 2009
    Seafart is a troll and he will be dealt with accordingly. I have sent probe droids to the far ends of the galaxy and soon he will be found. My lightsaber is ready...
  • megasat16
    edited May 2009
    Lord Vader wrote: »
    He is all yours! Like the rest, I gave up on him!
  • seafire
    seafire Posts: 459
    edited May 2009
    megasat16 wrote: »
    Hey! After posting I saw your add on on the bottom and I reacted in a friendly way....was really just joking :D
  • Lord Vader
    edited May 2009
    I ask with respect to all that everyone refrain from posting further in this thread. It is only together with our combined strength that we can destroy him...
  • seafire
    seafire Posts: 459
    edited May 2009
    Lord Vader wrote: »
    LORD one question before I go.
    Are you sure that you have the highest quality cable , crossovers and interconnects holding you together?I sure don't want to be around when your connections start failing :D
    BIDI BIDI BIDI
  • Systems
    edited May 2009
    seafire wrote: »
    Indeed you did,I stand corrected.
    And I agree that if done correctly true 1st order systems can sound good though I'm not entirely convinced that their phase accuracy in itself is as big of a sonic advantage as their proponents would have me believe.
    Using 4th order LR's active is far less restrictive than passive as you can correct phase and amplitude electronically.
    Yes the delay can be done electronically in an active setup,however with mine I chose to use a slanted baffle (approx. 10 degrees)to add the necessary delay to the tweeter.
    In a passively crossed over system using a flat baffle , the time lead of the forward mounted tweeter can be compensated for by adjusting the values of the components in the hi pass section of the crossover.Using a good optimisation software will make this an easy task.
    Huh,:confused:I'm not claiming to be John Bau,I just used his unique xover design as an example.
    Testing
    Testing
    Testing
  • Lord Vader
    edited May 2009
    seafire wrote: »
    BIDI BIDI BIDI
    I am quite certain that I possess the ability to end this destructive conflict and restore order to the galaxy. As for you, please leave and prey you annoy me no further. I will listen to my own advice and post in this thread no more...
  • seafire
    seafire Posts: 459
    edited May 2009
    GV#27 wrote: »
    In a passively crossed over system using a flat baffle , the time lead of the forward mounted tweeter can be compensated for by adjusting the values of the components in the hi pass section of the crossover.Using a good optimisation software will make this an easy task.Huh,:confused:I'm not claiming to be John Bau,I just used his unique xover design as an example.
    LOL "Easy" is a relative word.To my ear phase accuracy is very important as well as impulse response.Forgive me for thinking you are the one and only as your replies have been pretty advanced ;)
    I would really like to stay in touch with you sharing some points in the future irrespective of what happens here!
    Seafire :)
  • seafire
    seafire Posts: 459
    edited May 2009
    lord vader wrote: »
    i am quite certain that i possess the ability to end this destructive conflict and restore order to the galaxy. As for you, please leave and prey you annoy me no further. I will listen to my own advice and post in this thread no more...
    ignore ;)
  • superjunior
    superjunior Posts: 1,632
    edited May 2009
    Lord Vader wrote: »
    priceless :D
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • Systems
    edited May 2009
    seafire wrote: »
    It is easy to change component values in the software and quickly see the results.
    My priorities differ,most important is having smooth frequency response on and off axis.Next is the ability to handle dynamics without compression, and thirdly a wide listening window /lack of lobing errors.Generally speaking it is in these three performance aspects where 1st order systems usually fall short.
    Testing
    Testing
    Testing
  • POIDOG
    POIDOG Posts: 391
    edited May 2009
    Keeping it real boys, IMHO, speakers will last forever, especially if you never use them.
  • Lord Vader
    edited May 2009
    The power of the Dark Side has kept the troll know as Seafart away for the past couple days. I would be grateful if nobody posts further in this thread as the best way to destroy a troll is to remove it's food supply. Please consider this thead as being dead. I would hate to leave a permanent garrison here as I did at the Gas Mines of Bespin.
  • seafire
    seafire Posts: 459
    edited May 2009
    Lord Vader wrote: »
    My silence has nothing to do with you.Dream on as long as you call me insulting names :cool:
  • Knucklehead
    Knucklehead Posts: 3,602
    edited May 2009
    Vader,
    With all do respect, because I am but an Ewok, isnt what your doing trolling? I dont think the name calling is making this a better place and it certainly wont end this thread.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
    edited May 2009
    I store mine in liquid nitrogen!
    cnh
  • sucks2beme
    sucks2beme Posts: 5,686
    edited May 2009
    Getting back on subject. I've owned a lot of older speakers.
    I haven't bought a new set since 1977. The closest to new Ive bought
    since are demo RTI's from a CC showroom. So, any set I've
    owned is past it's prime. What if speakers falling out of original spec sound
    better? What sounds good to each one of use varies, so maybe a 10
    year old set sounds better to me than a new set would of?
    But, yes, cone edges and caps sooner or later give out. My Snell
    type E's had new woofers and crossvers put in before I got them.
    They sounded very good. So did the Valkyries, so do the Hales.
    And the Valkyries were early 80's built. Bottom line, you'll get tired of
    most speakers long before they are ready for the recyle bin.
    The other close to new set, the Rega R3's are going out the door soon.
    So worry not how old they are. Let your ears and eyes make the
    call.
  • Oblique
    Oblique Posts: 67
    edited May 2009
    I would say a really long time lol
  • mr2sw21
    mr2sw21 Posts: 115
    edited May 2009
    sucks2beme wrote: »
    call.
    I see.
    The reason why I post this thread is: before I am trying to buy some new set of speakers I want to know how long they they last. I really don't want to start some pretty expensive (to me) investment and they can only last of few years long. So I just want to do some research before I buy.
    But thanks all of yours input really appropriate them
  • wanedane1
    wanedane1 Posts: 1
    edited May 2009
    mr2sw21 wrote: »
    I have seen people post selling their 20 30 years old speakers and I have heard from my friend's house speakers they are 30 years old but still sound like in perfect condition. So I am wondering how long can speakers last? do they need tune up? I just got the VM serious can they last long?
    How long your speak been with you? Any special treatment you need to keep it up?
    i had my sda 10 year i got those from my dad he had from 14 year and as good as new
    edited May 2009
    Welcome to Club Polk!
    The question for some of us will be whether or not our SDAs will outlast their 'master'?
    cnh
    nooshinjohn Posts: 25,932
    edited May 2009
    cnh wrote: »
    cnh
    SDA's have no master, for if you love them as much as I do you end up spending all you can to care for them properly (amps,cd players/turntables etc.) They actually are there like a great mistress. They provide pleasure imeasurable:D
