The curse of the Treitz, expanding a networking journey
1…4567810»
  • Dr_Wu
    Dr_Wu Posts: 356
    erniejade, I agree on the RALs, and can say his digital coax is just as good
    I'd still like to hear what Tom and Trey say about their systems with only the Muon (ER out)
  • erniejade
    erniejade Posts: 6,327
    treitz3 wrote: »
    If that does to your system what it did to Trey's and mine? You are gonna LOVE that thing!
    I am hoping to extract that last little bit with it. The way you two make it sound, it might do more then that.
    I have had the EtherREGEN for a couple years now and the TeraDak power supply. Recently i canged the umbilical cable from the EtherREGEN to the TeraDak with one of Brad's RAL cables and, it did make a difference over the stock cable.
  • jdjohn
    jdjohn Posts: 3,448
    VR3 wrote: »
    Power over ethernet receive their power from the source component.
    i.e., a poe switch would receive power from the router.
    Typical PoE devices are security cams, which get their power via ethernet cable from a PoE switch, which also handles the data. This is clearly more efficient than the cams having a separate power supply. The power comes from the PoE switch, not a router. PoE switches can have either AC or DC power supplies.
    I came across a (cheap) PoE switch that has an AC power supply. Here are pics:
    You can see that it utilizes an AC power source...FWIW. I have it placed at the end of a ~25ft ethernet cable run, and before an ENO ethernet filter. My previous ethernet switch at that spot was a cheap D-Link model, powered by a wall-wart. The PoE switch weighs a pound of two, whereas the D-Link switch weighs ounces...again, FWIW.
    Although I haven't done any hard comparisons yet between the two switches, the PoE switch certainly did not disappoint during initial testing. In fact, it made me furrow my brow a bit upon initial listening...as in, 'am I hearing the improvement that I *think* I am hearing?'. More to come, but food for thought is: does a PoE switch perform sufficient signal isolation for a manageable price?
    treitz3 Posts: 20,366
    Jody, the one thing Trey and I have learned when it comes to NAP's? Everything affects everything.
    Everyone is at their own level/budget. Every system is different. Every noise/jitter situation is different. There are SO many variables in this equation that what works superbly for one, may only be a subtle change for another in their system.
    Trust your ears. For it is your ears that led Trey and I to the Muon filter. From that (unbenounced to you), your suggestion to Trey has resulted in 2 confirmed sales here on this forum and over 5 confirmed sales on other forums. So far, everyone but one has chimed back in and stated that they are "very" satisfied (at the least) with what they are hearing. During the chatter here and elsewhere, others who have already purchased the filter have chimed in confirming that it is truly an outstanding product.
    You, sir.....well, you caused a chain reaction. A "Domino" effect, if you will.
    And it was all because you suggested and offered your observations on a Muon ENO.
    Yes, we all blame you. ;)
    VR3 Posts: 29,756
    edited March 2023
    D a m N you Jody and your far reaching influence!!
    treitz3 wrote: »
    Correction. Make that 3 confirmed sales on this forum. (So far)
  • Dr_Wu
    Dr_Wu Posts: 356
    Could be more. Would still like to know if best result is adding to or replacing the ER.
    I will try my best to give you the results today.
    Hang loose...
    I was out mowing the lawn when I responded earlier. Glad I did because the rain just now started. I have some friends coming over in a little bit to audition the rig and after that, I should have the time to do it.
    I don't want to disturb anything with the rig until they get a chance to hear it, as it *may* change things.
    I believe (haven't really thought about it or looked at it yet) that I can simply take the AD master clock out of the equation and test it without that, then lose the ER, then lose the Muon Pro. I'll take notes with each loss and then add them all back in.
  • GlennDog
    GlennDog Posts: 3,158
    edited November 2023
    Tom/Trey
    I've skimmed this thread fairly thoroughly, yet I have a Q
    My rig is fairly simple and I want to keep it that way
    Muon products are discounted 10% for the next few days and I am eye balling the Muon Pro and cable approx a $2400 investment
    MUST I have a switch?
    As is . . . rig sounds great with the Baltic.
    present connection . . . . ethernet in to Lumin U1 Mini > into Lampi Baltic
    Adding the Muon puts the Lampi on the receiving end of the Muon Pro? Correcta MUNDO?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 29,756
    I am using the netgear s8000, cost me a hundy and seems to work perfect!
  • ChrisD06
    ChrisD06 Posts: 929
    You know it's my first time seeing this thread but I do want to note something very interesting:
    I listened to "Sing 2 soundtrack - I still haven't found what I am looking for" as Trey mentioned in his original post from January 19th and even on my Sennheiser HD559 with the blu-tac and felt pad mods, with Spotify as the streaming service, on my PC using the front panel audio jack and an unshielded in-wall ethernet cable, I'm able to discern the same details Trey initially outlined in his post.
    I was curious and so i decided to play around and I brought my headphones downstairs and just used my Onkyo AVR and the sound was beyond significantly better. The Onkyo is literally being supplied by an old Fire Stick that's slower than anything and it's all through WiFi.
    Ironically my computer has a better DAC than my Onkyo does and the Onkyo has dirtier power supplied to it, along with the fact that the internet supply to my Onkyo is objectively inferior on every metric. All streams were through Spotify at 320Kbps (lossy).
    Seems I have some playing around to do. I'm confused.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
    Glenn, you are correct. A switch isn't "needed" for the Muon Pro to work.
    Damn, I still owe @Dr_Wu his response. I am once again, time limited.
    Please hit me up next weekend, if you haven't heard from me.
    billbillw Posts: 8,346
    Dang, I just read through all this for the 1st time.
    To think I am just getting by with an Intel Wireless AC card in my thin client.. sheese. I should be embarrassed, but I'm not 😋
    No ethernet cabling anywhere near my 2-ch system and I don't feel like drilling through the floor.
    msg Posts: 10,650
    Lol, see, @billbillw? Shoulda stuck with the blue pill!
    msg wrote: »
    I'm not making any changes. My wifi is very strong and stable.
    For those who do not have the budget for a Muon Pro or the Muon? NA will will be launching ENO2 in March/April and this will be a big step up from the original ENO using our latest filtering technology, according to NA.
    audioluvr Posts: 6,079
    billbillw wrote: »
    Word for word? I'm impressed! I did the Evelyn Wood Speed Reading technique.
    audioluvr wrote: »
    billbillw wrote: »
    Probably a bit of skimming over minutia...definitely not word for word.
    mhardy6647 Posts: 35,562
    billbillw wrote: »
    audioluvr wrote: »
    billbillw wrote: »
    Lossy compression applied.
    (JK -- as they say)
  • rebelsoul
    Running a lhy sw-10 switch with a seperate lhy 10 mhz clock and a muon pro . And all I could say is wow .
    Can’t wait to see what this all looks like when you’re said and done!
    I am pretty much done at this point. With my streaming portion of the rig, that is. It ended up getting so complicated (even for me), that I ended up creating a Power Point spreadsheet.
    What's funny (or not), is we are all still awaiting the highly anticipated ERv2 years later.
    I will need to go through the list one final time to make sure it is correct, then I will present it. Hopefully, later today.
  • Dr_Wu
    Dr_Wu Posts: 356
    Re-visiting the NA products. I'm now converting the ethernet to fibre one meter after the router. If I understand it correctly, the NA products act on the ethernet signal. That suggests to me that the NA filter ought to be placed between the router and the ethernet/fibre converter. Is that correct?
    VR3 Posts: 29,756
    The filter should go before the streamer.
    Unless you have the pro, the muon standard only thru puts 100mbps
    Here ya' go. This is the most current layout of the streaming portion of my rig. I left out the 2 physical music portions of the rig, since this is all about the streaming aspect being (for the most part) done.
    The only things I have planned, as funds allow, is to eventually upgrade the cables leading to the subs and eventually have custom cables made for the 3 umbilical cords in-between the Power Supplies on the amp, pre and the streamer itself. The speakers will eventually be tri-wired with all cables being at the Takshaka level from Snake River Audio.
    I can say that this has been a really fun journey and streaming has gone from a barely enjoyable background music only to an extremely palpable and enjoyable, total immersion of music all around me. At this point, I haven't and don't have any yearning to change anything at all within the streaming portion of the rig. There is really no need. The cables I mentioned in the previous paragraph are not needed at all, but you all know me, I like to keep pushing the envelope. The gear, I am done with...unless something fails or breaks on me.
    If you look, there are actually 3 "moats", if you will, that thwart noise from being introduced into the amplification stage of the rig. The first one is a natural moat - the use of Wi-Fi via a mesh network, going over a dedicated channel (2.4GHz) just for the streamer itself, prioritized for optimum signal to the rig. The second moat is the EQUI-CORE 1000. It's a rather heavy isolation transformer that powers all of the support equipment for the streaming portion of the rig. The third moat is an Active Differential Isolation Moat (ADIM) that resides within the switch, which is the EtherREGEN v1 (Still awaiting the public release of the ER v2).
    What isn't included in the configuration above, besides the physical music portion of the rig, are the various noise thwarting devices that are utilized before and within the rig itself. Those include various conditioners outside of the room and within the room, 5 Puron's, 2 Main Stream - Master Class Dynamic Parallel AC Line Conditioners and one Snubway.
    The one thing I have learned is that there are many ways to configure a system for superb streaming and what works wonders on one system, may not work wonders on another. There are SO many variables to consider, it becomes unfathomable. I just thought I'd share where I ended up. This all started with a Bluesound Node 2 I bought while I was down in Atlanta vising Hi-Fi Buys many, many, many moons ago. It really blew up when I had upgraded some items over time and discovered how much a cheap, $14 Ethernet cable upgrade made to the sound. Now, I just sit back and enjoy. I can also now shift my focus to the vinyl portion of the rig. Something that has been somewhat neglected for quite some time.
  • newbie308
    newbie308 Posts: 846
    Good grief Tom! I'm sure it sounds amazing, but that's a lot of connections! Do you own stock in Caig's?
