50 year anniversary r200 signed by matt polk
1234568»
  • mantis
    mantis Posts: 17,671
    Braddles63 wrote: »
    I’ve been running them every day since the 16th either with music when I’m home or with the tv when not. Minimum 6-8 hours a day. I suspect they are what they are now.
    I’ve tried them in two rooms and two systems.
    Don’t get me wrong they are good. Very forgiving and easy to listen to. Maybe a little too refined at times. But it lacks the character of a stand mount imo. My R700s is lighter on its feet overall. Has more air around vocals and controls its bass better. Now I’m all my years if you were to compare a stand mount and floor stander it should be the other way around. Especially considering the crossover parts in the 200. For me they tried too hard to make the 200 sound big. You shouldn’t have to pull a stand mount speaker halfway out into the room for it to have some balance.
    But once they are in the right spot they do sound good. But not great. So at this stage I’m a bit disappointed.
    Thanks for sharing and the pictures, nice room you got there. I think the best way way really evaluate them is to remove the R700's all together and Run Audyssey. Then make sure they didn't get set to Large and if they did , Manually set to small and cut them around 80-100hz. Blending them in with a good subwoofer probably would yield the best results. They might be doing some strange things in the room response. You could be getting very different reflections due to they are shorter than the R700's on those stands your using.
    I have net heard any of these Reserve speakers yet and really want to.
    Dan
  • Braddles63
    Braddles63 Posts: 191
    edited September 2023
    Called into a HI-FI shop today and by pure chance they had the R200 and the 200AE side by side. Both hooked up to the same entry level Yamaha 2 channel amp using the same speaker cables. One to speaker A and one to B. Identical stands. Was just in an open floor environment part of the shop so not the ideal acoustic environment but same for both speakers.
    I could stand back and the sales guy switched back and forth between the two for a few different songs. I could here a difference in the two quite easily. The AE were slightly more extended in the top end and slightly more prominent midrange. Sounded more mature and refined. Not night and day difference but noticeable. Just thought it was worth putting it here.
    I posted the above in the comments section of Andrew Robinson review of the R200AE.
    heiney9 Posts: 25,699
    So what was the final consensus? I have an opportunity to buy a pair of R200 AE's. I don't really need them. Perfectly happy with the R200's. I do love the cherry veneer.
    Are the AE's better enough to do the upgrade? Casual, near field listening in an office/bedroom rig.
  • stangman67
    stangman67 Posts: 2,330
    Don’t think the AE’s got very high marks from various opinions I have read on here
  • Unknown
    VR3 Posts: 29,744
    They didn't work for me near field. They required to much volume to open up. I don't listen very loud at my desk. I usually keep volume between 1 and 20 on the digital scale.
    VR3 wrote: »
    Near field in my case is about 3 feet on stands in a small room.
  • Braddles63
    Sold mine. Lost a heap of money.
    VR3 Posts: 29,744
    I sit 3 ft from my monitors on foam pads. They required way to much volume to open up in that application.
  • Hermitism
    Hermitism Posts: 4,351
    You sit on foam pads?
    msg Posts: 10,650
    lolol
  • rooftop59
    rooftop59 Posts: 8,120
    Hermitism wrote: »
    I'm sure you're familiar with hemorrhoids there herm...
    Game Room 5.1.4:
    Bedroom 2.1
    VR3 Posts: 29,744
    I mean technically the chair is a foam pad.. So.... Yes
    edited June 2024
    My new listening space will allow much more distance for listening as well as allowing them to be out in the room a bit more. I'm thinking both my current R200's as well as the R200AE will work better than my current situation.
    Just not sure if spending $700 on another pair of similar speakers is worth it. I wish I was already set-up in the new space w/my current R200's to know if it was worth it to upgrade.
    P.s. It drives me crazy knowing there is a better version of the R200's out there. I want them, but do I need them :p
    msg Posts: 10,650
    Ah, and therein lies the conundrum.
    We wouldn't be here at all if we went by "need" logic.
    Buy. Satisfy your curiosity. Sell the ones you like least.
    I didn't get a chance to fully audition the R200AE, but I noticed that they did sound sweeter out of the box than the R200. I hated the R200 at first. Both, with their port design, really needed a ton of room in my experience with them.
    Sound wise, maybe there's another speaker you'd like better, something less lateral-move-y. How much of your purchase decision would be to satisfy the collector in you? If zero, I'd pass, personally. For me they weren't better enough. Would have liked to have kept them, but I kept coming back to the fact that they wouldn't see use, since my systems are pretty well settled otherwise, and the R200AE simply weren't going to displace those other speakers.
    treitz3 Posts: 20,359
    Which one did we listen to at Troy's pad?
    VR3 Posts: 29,744
    The standard 200.
    The ae is the better speaker
    Ah, I haven't heard it. Therefore, I cannot comment. Thanks for answering my query.
    txcoastal1 Posts: 13,520
    treitz3 wrote: »
    Shut up Tom
    I feel the love....
