Do power cables make a difference?
  • FestYboy
    FestYboy Posts: 3,861
    I can totally appreciate @tonyb 's post, and I get it (to a point). But it also shows that the work hasn't been done yet, an I mean work by there isn't an established correlation between cable sonic signature (or any component for that matter) and how it sounds. Blind testing with a sizeable test group to establish a commonality would be required, then breaking it all down to find that "thing" that establishes the difference.
    I'll be ok with that up until it's time for me to make a purchase, then the objectivist in me is gonna have an issue. (My problem, not being imposed on anyone else).
  • kharp1
    kharp1 Posts: 3,453
    FestYboy wrote: »
    Seriously doubt that it would work that way. Being that it's ONLY A LINK IN A CHAIN you have to consider upstream and downstream components. Not all will work the same with every cord and it's geometry and makeup. Too many variable, which is what we've been saying all along.
    It's organic, more or less.
    F1nut Posts: 49,805
    ^ Bingo ^
    mhardy6647 Posts: 33,049
    edited April 2018
    We were actually busy out in the actual world ("meatspace" as some would have it) today :p but I wanted to say a word (ok many words!) about the Amp Camp Amp -- since the ACA got brought up in this thread (for whatever reason).
    As many folks here may know, do the the extreme (nay, the outrageous) kindness and generosity of an anonymous forum member, there's a rather tricked-out ACA -- one which was laid out and reduced to practice by the forum's own @ALL212 -- on a long-term visitation at our house.
    I've been listening to it exclusively for a week and a half or so, mostly on the Frankenaltecs (but also on some other highish-sensitivity loudspeakers). Nelson Pass designed the amp as an entry level exercise to teach (or at least to reveal) how simple a fine sounding amplifier can be, and how fine sounding a simple amplifier can be. The ACA breaks many of the de facto rules of modern solid state hifi design, being a single-ended solid state amplifier with very little (if any?) negative feedback. As such, it is inefficient (SE power amplifiers operate in Class A by definition), low powered (due to the simplicity and fairly low P/S voltage), and possesses fairly high output impedance (low "damping factor") and not particularly low distortion (of the harmonic kind, at least).
    In fact, on paper it "measures" a lot like a single-ended 2A3 amplifier.
    ... and it has some of the there-ness and soul of an SE 2A3 amp. It even does a little better in terms of bass (extension and definition) than my SE 2A3 amps -- probably because I didn't spend an order of magnitude more on the output transformers equipping the latter! Where the 2A3 amp beats the ACA (edit: to my ears and taste) is in the richness and palpability of the midrange. The ACA ain't bad at all -- but the 2A3 just plain has soul in the midrange that the ACA doesn't quite get.
    This being said, the ACA costs a fraction of a stereo 2A3 amplifier, and also costs a fraction of almost any (at least current production) solid state amplifier that would sound as good.
    The trade-offs are profound (the choice of appropriate loudspeakers will be much more critical for success with the ACA than a typical ss amplifier), but the opportunity to learn is great.
    Now, this has absolutely nothing to do with power cables (since the ACA is designed to run off of a laptop computer "brick" type power supply*) :p but either of the amplifiers mentioned above (ACA or SE 2A3) will quickly and emphatically reveal
    how important everything else in the chain can be to the final, audible product.
    _______________
    * It would of course be possible, and maybe quite interesting, to design and implement an old-school linear power supply for the ACA. :)
    gudnoyez Posts: 8,066
    edited April 2018
    Why they do yes they do. Here is one the OP should try out himself.
    http://forum.polkaudio.com/discussion/181548/shunyata-research-diamonback-powerecord-20a-c19-5-5ft-long#latest
    Try it out and see what you think. If it is not up your alley you should be able to resell it pretty easily. I should get this and try it out at that price.
  • mpitogo
    mpitogo Posts: 478
    @gudnoyez unfortunately my components are all C13. For sale is a C19. I was this -><- close to picking up an AQ power cable while at my local BB (for another Airport Express, AirPlay zone spdif to an MA5200) but then what do I upgrade to make the most difference? Preamp, Amp etc. Also they only had one left so I passed.
    Currently streaming some Tidal
    • Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
    • Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
    • Daughter's Bedroom 1-2.0 TBD Martin Logan Forte | Roku TV
    • Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • voltz
    voltz Posts: 5,384
    Of Course they do!
    Everything Matters!
    lord does even amp or speaker make a difference?j
    Here is just my thoughts! As I have went thru many different ones starting with the Pangea's and Franks Signal cables one..now I have Voodoo cable & PS Audi and Douglas Connections power cable and a Audio art I got from Marvin that sounded to good to ever sell!
    I trust what Marvin or Skip tell me to try and they have never failed me! so why have i never tried wireWorld or cullen? I never said I was the sharpest tool in the shed!
    treitz3 Posts: 18,340
    ......not according to some forums.....
    LOL
  • afterburnt
    afterburnt Posts: 7,892
    Yes power cables make a difference! If I didn't upgrade all of my power cables I would have money for the Sub that I want. I do need to upgrade all of my Sub power cables though.
  • voltz
    voltz Posts: 5,384
    but as so many others here have said so many times...
    Try them for yourself and make your own opinions on the subject!
    Don't trust me or any piece of paper...trust your own ears as that is all that matters in this game.
    If you don't hear a difference then maybe you setup can't hear any difference or your ears... consider yourself lucky as your going to save a lot of $$$ and stay away from that hole :p
    Enjoy your ride in the audio world! may it be a good one! Hope you find something special to listen to.
  • mpitogo
    mpitogo Posts: 478
    Do recording studios use upgraded power cables? I’m thinking maybe or not...
    F1nut Posts: 49,805
    edited April 2018
    Recording studios and the reproduction of music in a home are not the same. That said, some of best studios use high end cables including power cords from MIT or Shunyata.
  • BlueFox
    BlueFox Posts: 15,251
    One of many professional use of Shunyata power cables and power conditioners.
    "Located in the United Kingdom, Astoria Studio is widely recognized as one of the most respected recording studios in the world. Owned by David Gilmour of Pink Floyd, Astoria has served as recording venue to some of the most renowned recording artists in the music industry. Anyone familiar with the state-of-the-art production values on Dark Side Of The Moon, Wish You Were Here, Animals, The Wall, Momentary Lapse of Reason, The Division Bell, and David Gilmour in Concert 2002 DVD, can appreciate the meticulous nature with which the Pink Floyd albums are put together. Astoria Studio’s principles are renowned for reviewing every aspect of their recording chain continually. It was this perfectionist approach that led Astoria to seek out and implement Shunyata Research’s Hydra power distribution systems, PowerSnakes power cables and Aeros Series signal cables to their state-of-the-art recording equipment. Astoria’s principle engineers actively endorse Shunyata Research products to other studios and mastering engineers and have paved the way for may subsequent Shunyata studio applications."
    http://shunyata.com/professionals-comment/
    Clipdat Posts: 12,608
    Suh-weet.
    My Venom 14s should be shipping this week! :)
  • Joey_V
    Joey_V Posts: 8,520
    Just in general my experience
    Silver core metal - cleaner edges of music, less hash
    Larger gauge of power cable - more bass, warmth
    Just my 2 cents
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • machone
    machone Posts: 1,478
    Impressive
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • dolbyd
    dolbyd Posts: 430
    So I found another site talking about cables and found that Jay Victor is member of the site.
    I did a search on PS Audio and Pangea and found a member who thought they were the same cable due to PS Audio using Patents from Jay.
    This was his response.
    No, Pangea cables and PS Audio cables are definitely not the same. XLO is the best I can do. Pangea is the most cost effective, and yes, does not rely on different shape conductors. It is interesting how good they sound, because it proves the importance of the geometry itself, without relying on very exotic materials. PS Audio is a step up from Pangea, and does offer better performance, and does utilize my patented conductor shapes. Thanks to all for the enthusiastic response to Pangea. I am very happy to be able to offer something that offers so much performance for such a modest price. Correction: I do not own Pangea. I design and manufacture the cables. Pangea is owned by WS Distributing. Thanks for your support!!! - Jay Victor
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva X300, Sony 75" 940E, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA5 G2, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • mantis
    mantis Posts: 17,057
    I've been through power cords of all kinds of levels and I've noticed very little differences in overall performance. Cost vs performance gains in my opinion might not be worth the retail price. If you can get them used or a good discount then the value goes up.
    I use all custom power cords in my system for 2 reasons. 1 I like the small benefit in overall performance and lower noise floor and 2 I really like having correct length so I don't have a power cord mess behind my rack I gotta deal with. I upgrade and test gear all the time so having shorter power cords is golden.
    Dan
    I just put the Shunyata Venom 14 in place of the stock Marantz CD6004 cable. Listening now.
    First thing I notice is that the stereo image/effect is noticeably better. I can actually move around now and hear the stereo image shifting/moving as I move in and out of it.
    I've always thought that my system's stereo imaging was its weak point. The difference in imaging with this power cable on the CDP is NOT subtle. Wow.
    It doesn't make any logical sense in my mind in regards to how a power cable could make this much of an improvement in stereo imaging. But wow. Crazy.
    Tony M Posts: 11,017
    edited April 2018
    Clipdat wrote: »
    And you haven't spent a fortune on a power cable yet. Imagine a 500.00 one. I'm reading more and more confirmations on what a good power cable can do. ;)
  • alucididea
    alucididea Posts: 113
    edited April 2018
    So, I was hoping to ask a question on this topic and didn’t see a reason to start another thread...
    A couple months ago a finally purchased a Furman Elite 15PF i & an NAD M22 for my Polk LSIM 707s that were previously matched with my RX-A3070. Now I’m ready to purchase some cables and wanted to ask a question or two...
    I’ve decided to go with the Pangea AC 9 MKII Signature power cable for the M22. But I was wondering whether it would behoove me to also purchase the same cable for the Furman power conditioner. I’m also considering getting another for the AVR as well. Should I even bother for the latter 2? Honestly I’m probabaly not going to bother with the AVR, but probabaly will for the Furman. Just thougt I’d consider some other points of view before I pull the trigger.
    Also upgrading my HDMI cable and interconnects, as well. Though those are self explanatory to me.
    F1nut Posts: 49,805
    Same answer I gave in your other thread.
    I feel like I've joined some elite group of people who have "seen the light" regarding the changes that an aftermarket power cable can bring! I'm a believer now!
    pitdogg2 Posts: 24,583
    Oh you're in the group buddy trust me....
  • marvda1
    marvda1 Posts: 4,873
    alucididea wrote: »
    I think you might hate yourself for these heavy hard to control cables.
    I highly recommend Cullen cables as a better option.
    http://www.cullencable.com/
    you can discuss with Cullen which models are best for you.
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • BlueFox
    Clipdat wrote: »
    Good for you. This is just the start. Add in some decent power conditioning to go with power cords, and you are in a different game. Enjoy. :)
    tonyb Posts: 32,906
    I think the OP should upgrade his other cables first. I would normally go Speaker -interconnects=digital- then power cables.
  • K_M
    K_M Posts: 1,627
    I have read many internet claims of positive results with better cords.
    On the other hand.....
    None of the claims are ever substantiated.
  • mantis
    Clipdat wrote: »
    They don't make huge differences unless the factory cord is poorly constructed and picking up interference. This is where aftermarket power chords make bigger differences. EMI and RF interference sucks and can ruin your sound quality. Your amp could care less where the signal is coming from. if it comes in then it's in.
    Dan
