LSI owners your speakers suck!
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    Ben -- any chance I could pay for the parts and your labor for my LSi9s? Excluding shipping, what cost would I be looking at?
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
  • zingo
    zingo Posts: 11,258
    edited August 2008
    I read a review between a ton a caps including Sonicap; and it concluded that Sonicap and other premium brands did make a large difference in SQ over budget brands (as many members here would testify). He also mentioned though that the difference between the different levels of Sonicaps has high diminished return. The reviewer stated that two speakers built with different Sonicaps were distinguishable when being listened to side-by-side, but not with A/B listening; and the improvements were minor. Granted this is only one persons opinion, but it sounded pretty reasonable to me. Take Ben's advise and Gen Is are all you need if you want to go Sonicap.
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    mmadden28 wrote: »
    Thanks! What about the 260uf? What should I do about that-leave it as is or replace with big expensive poly? Another electro? I'm about to finish my partsexpress order.
    I wouldn't bother with the 260uf. You can do it, but you would have to order 4 100uf's, and 2 60uf's from Dayton. If you did that you should also do the 18uf in the bass circuit. This would be 2 of these.
    http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=027-434
    Ben
    Ben
  • ben62670
    edited August 2008
    Shicks18 wrote: »
    It would depend on the caps you wanted to use. I would definitely use the Sonicaps on the highs. For the lows you could order 2 10uf's, and 2 8uf's to make the 18uf on the upper mid bass. The 260uf you would have to go with another brand like Dayton. Like I said before the 260uf might be a very minimal performance upgrade. The mounting would be a real pain too. Hopefully Mmad can share the total price of the parts. I would charge $80 to do the upgrade. It took me about 4 hrs to do the upgrade. I have the silver solder, glue sticks, solder sucker, and desoldering braid covered. The hardest part is removing the old components. I can not stress enough that you need to be real careful removing them. I know I posted it before, but you need to clip all the leads that are soldered to the board before you even attempt to remove the components. I am not trying to scare anyone, but sometimes guys figure I can do it if I am careful. CLIP THE LEADS, take your time, and it will go just fine.
    Ben
    Ben
  • Face
    Face Posts: 14,340
    edited August 2008
    Do they use more glue now than in the Monitor and SDA days?
  • ben62670
    edited August 2008
    Face wrote: »
    The stuff they use is like the stuff they used to glue the SDA cabs together. With SDA, and monitor XO's you could just apply heat to the solder, and pull the components off the board. I used an old soldering iron to clean the glue from around the components to remove them. The I cut the legs off the components, and then "pried/shaved" them off the board with a razor blade. I know you can handle it. You just have to take your time, and be careful. One thing I can almost promise is if you don't cut the leads on the caps, and resistors you will pull up a trace off the circuit board.
    Ben
    Ben
  • Face
    Face Posts: 14,340
    edited August 2008
    Thanks for the heads up.
  • mmadden28
    mmadden28 Posts: 4,283
    edited August 2008
    Minimum Parts: $135.50
    Parts Express
    Part # Description Price Qty Ext. Price
    027-434 Dayton DMPC-18 µf Poly Cap $5.65 2 $11.30
    005-3 Mills 3 Ohm 12W resistor $3.50 2 $7.00
    Subtotal $18.30
    Sonicap
    -- Sonicap 1 µf (gen I) $5.80 2 $11.60
    -- Sonicap 12 µf (gen I) $19.60 2 $39.20
    -- Sonicap 8.2 µf (gen I) $15.60 2 $31.20
    -- Sonicap 10 µf (gen I) $17.60 2 $35.20
    Subtotal $117.20
    Grand Sub $135.50
    ____________________
    Pool: Atrium 60's/45's
  • mmadden28
    edited August 2008
    Optional parts: $115.82
    Parts Express
    005-1 Mills 1 Ohm 12W resistor $3.50 2 $7.00
    027-447 Dayton DMPC-100 µf Cap $13.88 4 $55.52
    027-444 Dayton DMPC-60 µf Cap $21.00 2 $42.00
    Subtotal $115.82
  • ben62670
    edited August 2008
    Did you brake out the big guns on those:eek:
    Ben
  • mmadden28
    edited August 2008
    Grand Grand subtotal with all parts:
    $251.32
    + about $19 shipping combined
  • ben62670
    edited August 2008
    Well now we have someone going full out!
    The part numbers are off;)
    Ben
  • mmadden28
    edited August 2008
    ben62670 wrote: »
    Nah, just did the calculations-for a possible minimal return and almost doubling the cost. I'll pass for now.
    I'm ordering just the basics (except I may tackle the 1ohm) :rolleyes:
  • mmadden28
    edited August 2008
    ben62670 wrote: »
    oopps-:eek: :o Just fixed it-still had a few seconds of edit time left :mad:
  • ben62670
    edited August 2008
    JUSTIN!
    I'll wait for you to remove the 3ohm and see what you think about taking that long sand cast 1 ohm off;) It'll come off.... in pieces.
    Ben
  • mmadden28
    edited August 2008
    ben62670 wrote: »
    JUSTIN!
    Yeah, well I figure I'll start with the 3 ohm, and if I decide to tackle it, at least I'll have the 1 ohm ready-Only $7, and I'm sure I can alwasy find a use for a 12w 1 ohm resistor around the house somewhere ;)--Oh I know for speaker impedance-drop testing :D
  • mmadden28
    edited August 2008
    mmadden28 wrote: »
    $251.32
    I couldn't edit the post---
    Update on Shipping-Parts Esxpress has a USPS 1st class option thats about $3 instead of the UPS min of about $9.
    So combined shhipping is about $13
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited August 2008
    ben62670 wrote: »
    I wouldn't even touch the 10w1r stock resitor. It will be real hard to get that off the board. It's 10 watts, and not in the signal path. Trust me you will make a mess trying to get that off the board;)
    I agree. I would leave the stock resistor in place, If you want to replace the stock resistor, just clip the leads as close as possible to the body of the 1 ohm resistor, desolder the leads from the board, then mount a 1 ohm Mills resistor on top of the stock resistor.
    I don't know if the leads of the Mills resistor will be long enough to clear the body of the stock resistor, but, if not, lead extensions are easy to make.
  • ben62670
    edited August 2008
    ....If you want to replace the stock resistor, just clip the leads as close as possible to the body of the 1 ohm resistor, desolder the leads from the board, then mount a 1 ohm Mills resistor on top of the stock resistor.
    Very good idea. The leads are plenty long enough. You have done stuff like this before haven't you;):D
    Ben
    Ben
  • DarqueKnight
    edited August 2008
    ben62670 wrote: »
    No. I just stayed at a Holiday Inn Express last night.;):)
  • mmadden28
    edited August 2008
    ben62670 wrote: »
    Ben
    +1 Duh. ;):p
  • mmadden28
    edited August 2008
    anonymouse wrote: »
    Looks like you swapped to 100uF and 60uf prices, so your grand total should actually be higher.
    Oh dammitalltoheck. That's why I should just go to bed when I've fallen asleep at the keyboard for the 8th time :o
    zzzz. type a word zzzz copy zzzzzz pastezzzzz calculate zzz finish calculation zzz edit part # zzz zzzzzzzzzzzz :rolleyes:
  • mmadden28
    edited August 2008
    ...then mount a 1 ohm Mills resistor on top of the stock resistor.
    In that config, since the Mills is now resting on the old resistor, wouldn't the old resistor then help dissipate any heat generated? :confused:
  • DarqueKnight
    edited August 2008
    I was assuming that the modder would put some type of vibration damping between the two resistors, in which case there would be no opportunity for heat dissipation.
    Even if the Mills is laid directly on the stock resistor, the heat sinking effects would be minimal due to the Mills' cylindrical shape. Only a very thin line down the length of the Mills' resistor body would be in contact with the flat surface of the stock resistor. Sort of like the point of contact between a perfectly circular tire and a road.
    Adding some form fitting thermally conductive mass to the body of the Mills might be a good idea.
  • Early B.
    Early B. Posts: 7,900
    edited August 2008
    Hey Ben -- how about an A/B test at the next Polkfest?
    "God grooves with tubes."
  • ben62670
    edited August 2008
    Early B. wrote: »
    Sure. I bet I can get Jerry to bring them back. We would just need some stock 15's. They are still here for now:)
    You mean PF08? Or another local one?
    Ben
    Ben
  • jerryj12
    jerryj12 Posts: 451
    edited August 2008
    Hey my speakers don't suck......:D
  • ben62670
    edited August 2008
    Jerry you trouble maker! You should have never let me install your tweeters in my SDA's! Now look what you made me do!
    http://www.madisound.com/catalog/product_info.php?manufacturers_id=153&products_id=8402
    A little better than the Polk models. The new Vifa ring radiator.
    Ben
  • Face
    Face Posts: 14,340
    edited August 2008
  • ben62670
    edited August 2008
    Try to not concentrate on the nipples, and focus on the diaphragms(both tweeters). You see what I see?
    Ben
