Which Dedicated Circuit to Install
13»
  • amulford
    amulford Posts: 5,020
    edited July 2008
    kolyan2k wrote: »
    might wanna change the runs from the poles first. they are only aluminum. dont see why one short run from panel will make something better when main is not even copper.
    He is right.
    99% of the mains I've seen are aluminum. I'm sure you can run copper instead, I think you'd need something like 4/0-3C twist with an aluminum runner to carry it. I'm pretty sure you'd also HAVE to get the power company to do it, too, for insurance. That's gonna be pricey...
  • janmike
    janmike Posts: 6,146
    edited July 2008
    That's what friends are for. :D
    Michael ;)
    NORTH of 60°
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2008
    never seen 4/0 copper, I pulled aluminum to the sub-panel for the HT room you heard Mike, the amp line in the shed comes from the same sub-panel.
    Works great, sounds great.
    DJ7--your receptacle is loose and it does not produce any current.
    RT1
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2008
    I seen 4/0 copper before, but my receptacle isn't the only thing loose ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • amulford
    edited July 2008
    I see it all the time. They don't use much aluminum industrially anymore...
    It ain't cheap, that much I can tell ya.
  • reeltrouble1
    edited July 2008
    r u saying u have become industrius now Ant.............
    RT1
